[petsc-users] [MPI GPU Aware] KSP_DIVERGED
Junchao Zhang
junchao.zhang at gmail.com
Tue Sep 17 11:09:44 CDT 2024
Did you "fix" the problem with OpenMPI 5, but keep petsc unchanged (ie.,
still 3.20)?
--Junchao Zhang
On Tue, Sep 17, 2024 at 9:47 AM LEDAC Pierre <Pierre.LEDAC at cea.fr> wrote:
> Thanks Satish, and nice guess for OpenMPI 5 !
> It seems it solves the issue (at least on my GPU box where I reproduced
> the issue with 8 MPI ranks with OpenMPI 4.x).
> Unhappily, all the clusters we currently use have no module with OpenMPI
> 5.x. Seems I need to build it to really confirm.
> Probably we will prevent users from configuring our code with OpenMPI-cuda
> 4.x cause it is really a weird bug.
> Pierre LEDAC
> Commissariat à l’énergie atomique et aux énergies alternatives
> Centre de SACLAY
> DES/ISAS/DM2S/SGLS/LCAN
> Bâtiment 451 – point courrier n°43
> F-91191 Gif-sur-Yvette
> +33 1 69 08 04 03
> +33 6 83 42 05 79
> *De :* Satish Balay <balay.anl at fastmail.org>
> *Envoyé :* mardi 17 septembre 2024 15:39:22
> *À :* LEDAC Pierre
> *Cc :* Junchao Zhang; petsc-users; ROUMET Elie
> *Objet :* Re: [petsc-users] [MPI GPU Aware] KSP_DIVERGED
> On Tue, 17 Sep 2024, LEDAC Pierre wrote:
> > Thanks all, I will try and report.
> > Last question, if I use "-use_gpu_aware_mpi 0" flag with a MPI GPU Aware
> library, do PETSc
> > disable GPU intra/inter communications and send MPI buffers as usual
> (with extra Device<->Host copies) ?
> Yes.
> Not: Wrt using MPI that is not GPU-aware - we are changing the default
> behavior - to not require "-use_gpu_aware_mpi 0" flag.
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7813__;!!G_uCfscf7eWS!ai2MqJBzpM6efcbqDSWP3wTdMXpLjCabfiqf3nJWv7JMm3lBkWsWTyi5UaKoGoNH9DCZwkWaLljMmNPNXQCBk3rS5-fw$
> Satish
> > Thanks,
> > Pierre LEDAC
> > Centre de SACLAY
> > +33 1 69 08 04 03
> > +33 6 83 42 05 79
> > ________________________________
> > De : Satish Balay <balay.anl at fastmail.org>
> > Envoyé : lundi 16 septembre 2024 18:57:02
> > À : Junchao Zhang
> > Cc : LEDAC Pierre; petsc-users at mcs.anl.gov; ROUMET Elie
> > Objet : Re: [petsc-users] [MPI GPU Aware] KSP_DIVERGED
> > And/Or - try latest OpenMPI [or MPICH] and see if that makes a
> difference.
> > --download-mpich or --download-openmpi with latest petsc should build
> gpu-aware-mpi
> > Satish
> > On Mon, 16 Sep 2024, Junchao Zhang wrote:
> > > Could you try petsc/main to see if the problem persists?
> > > --Junchao Zhang
> > > On Mon, Sep 16, 2024 at 10:51 AM LEDAC Pierre <Pierre.LEDAC at cea.fr>
> wrote:
> > > > Hi all,
> > > > We are using PETSc 3.20 in our code and running succesfully several
> > > > solvers on Nvidia GPU with OpenMPI library which are not GPU aware
> (so I
> > > > need to add the flag -use_gpu_aware_mpi 0).
> > > > But now, when using OpenMPI GPU Aware library (OpenMPI 4.0.5 ou
> 4.1.5 from
> > > > NVHPC), some parallel calculations failed with *KSP_DIVERGED_ITS* or
> > > > *KSP_DIVERGED_DTOL*
> > > > with several configurations. It may run wells on a small test case
> with
> > > > (matrix is symmetric):
> > > > *-ksp_type cg -pc_type gamg -pc_gamg_type classical*
> > > > But suddenly with a number of devices for instance bigger than 4 or
> 8, it
> > > > may fail.
> > > > If I switch to another solver (BiCGstab), it may converge:
> > > > *-ksp_type bcgs -pc_type gamg -pc_gamg_type classical*
> > > > The more sensitive cases where it diverges are the following:
> > > > *-ksp_type cg -pc_type hypre -pc_hypre_type boomeramg *
> > > > And the *bcgs* turnaroud doesn't work each time...
> > > > It seems to work without problem with aggregation (at least 128 GPUs
> on my
> > > > simulation):
> > > > *-ksp_type cg -pc_type gamg -pc_gamg_type agg*
> > > > So I guess there is a weird thing happening in my code during the
> solve in
> > > > PETSc with MPI GPU Aware, as all the previous configurations works
> with non
> > > > GPU aware MPI.
> > > > Here is the -ksp_view log during one fail with the first
> configuration:
> > > > *KSP Object: () 8 MPI processes type: cg maximum
> iterations=10000,
> > > > nonzero initial guess tolerances: relative=0., absolute=0.0001,
> > > > divergence=10000. left preconditioning using UNPRECONDITIONED
> norm type
> > > > for convergence test PC Object: () 8 MPI processes type: hypre
> HYPRE
> > > > BoomerAMG preconditioning Cycle type V Maximum number of
> levels
> > > > 25 Maximum number of iterations PER hypre call 1
> Convergence
> > > > tolerance PER hypre call 0. Threshold for strong coupling 0.7
> > > > Interpolation truncation factor 0. Interpolation: max elements
> per
> > > > row 0 Number of levels of aggressive coarsening 0 Number
> of
> > > > paths for aggressive coarsening 1 Maximum row sums 0.9
> Sweeps
> > > > down 1 Sweeps up 1 Sweeps on coarse
> 1
> > > > Relax down l1scaled-Jacobi Relax up
> > > > l1scaled-Jacobi Relax on coarse Gaussian-elimination
> Relax
> > > > weight (all) 1. Outer relax weight (all) 1.
> Maximum size
> > > > of coarsest grid 9 Minimum size of coarsest grid 1 Not
> using
> > > > CF-relaxation Not using more complex smoothers. Measure
> > > > type local Coarsen type PMIS Interpolation
> type
> > > > ext+i SpGEMM type cusparse linear system matrix =
> precond
> > > > matrix: Mat Object: () 8 MPI processes type: mpiaijcusparse
> > > > rows=64000, cols=64000 total: nonzeros=311040, allocated
> > > > nonzeros=311040 total number of mallocs used during MatSetValues
> > > > calls=0 not using I-node (on process 0) routines*
> > > > I didn't succeed for the moment creating a reproducer with ex.c
> examples...
> > > > Did you see this kind of behaviour before?
> > > > Should I update my PETSc version ?
> > > > Thanks for any advice,
> > > > Pierre LEDAC
> > > > Centre de SACLAY
> > > > +33 1 69 08 04 03
> > > > +33 6 83 42 05 79
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240917/36346f17/attachment.html>
