[petsc-users] Residual at the fieldsplit level
miguel.salazar
miguel.salazar at corintis.com
Tue Sep 17 10:48:39 CDT 2024
Is this the expected behavior though? I am not sure if it might be an issue with the Firedrake implementation. Getting a minimum example on PETSc like this one is not trivial
Miguel
MIGUEL ANGEL SALAZAR DE TROYA
Head of Software Engineering
miguel.salazar at corintis.com<mailto:miguel.salazar at corintis.com>
Corintis SA
EPFL Innovation Park Building C
1015 Lausanne
[cid:2024-08-1609_02_11-re_mailmigrationfromgoogletooffice365-sebastien.gobel at corintis.com-co_4456a1bf-dd3e-46b7-85f9-21f278e66a79.png]
Here at Corintis we care for your privacy. That is why we have taken appropriate measures to ensure that the data you have provided to us is always secure.
Date: Tuesday, 17 September 2024 at 16:58
To: miguel.salazar <miguel.salazar at corintis.com>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Residual at the fieldsplit level
Ok. Please ignore my last message about fieldsplit_0_fieldsplit_0 I misunderstood
On Sep 17, 2024, at 10:52 AM, miguel.salazar <miguel.salazar at corintis.com> wrote:
That is correct
Corintis SA
1015 Lausanne
<2024-08-1609_02_11-re_mailmigrationfromgoogletooffice365-sebastien.gobel at corintis.com-co_4456a1bf-dd3e-46b7-85f9-21f278e66a79.png>
From: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Date: Tuesday, 17 September 2024 at 16:49
To: miguel.salazar <miguel.salazar at corintis.com<mailto:miguel.salazar at corintis.com>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
So firedrake_0 is the object prefix of your SNES object?
On Sep 17, 2024, at 10:37 AM, miguel.salazar <miguel.salazar at corintis.com<mailto:miguel.salazar at corintis.com>> wrote:
>In my reading, it says
>Residual norms for firedrake_0_ solve.
> 0 KSP Residual norm 4.621368953027e+02
> so the residual in the first (0th) split does correspond to the outer-most KSP residual norm (not printed but equal to the SNES at the first iteration of Newton.
> It is the residual norm of the first field of the first field that is 1
>Residual norms for firedrake_0_fieldsplit_0_ solve.
> 0 KSP Residual norm 1.000000000000e+00
Is the residual of the outer solve (it is being printed).
Is the residual of the first field. I am not sure what you are referring to with “the residual norm of the first field of the first field”
Miguel
Corintis SA
1015 Lausanne
Date: Tuesday, 17 September 2024 at 16:24
Initial residual: 462.13689530272404
0 SNES Function norm 4.621368953027e+02
1 KSP Residual norm 3.501082228626e-15
Residual norms for firedrake_0_fieldsplit_1_ solve.
0 KSP Residual norm 0.000000000000e+00
1 KSP Residual norm 0.000000000000e+00
1 KSP Residual norm 1.612167203819e-12
1 SNES Function norm 1.599350481360e-12
Using the fieldsplit additive preconditioner, the problem converges in a single KSP iteration, as expected. However, I do not understand why the residual of fieldsplit_0 (1e+0) does not coincide with the outer residual (462.13689530272404). It should be the case given that only fieldsplit_0 has a non-zero residual contribution. The fact that it is just 1 is suspicious. Is there something about how the fieldsplit works that I am missing?
Or am I missing something
Barry
0 KSP unpreconditioned resid norm 4.621368953027e+02 true resid norm 4.621368953027e+02 ||r(i)||/||b|| 1.000000000000e+00
0 KSP none resid norm 1.000000000000e+00 true resid norm 3.501082228626e-15 ||r(i)||/||b|| 3.501082228626e-15
1 KSP none resid norm 3.501082228626e-15 true resid norm 3.501082228626e-15 ||r(i)||/||b|| 3.501082228626e-15
0 KSP none resid norm 0.000000000000e+00 true resid norm 0.000000000000e+00 ||r(i)||/||b|| inf
1 KSP none resid norm 0.000000000000e+00 true resid norm 0.000000000000e+00 ||r(i)||/||b|| inf
1 KSP unpreconditioned resid norm 1.612167203819e-12 true resid norm 1.589286585800e-12 ||r(i)||/||b|| 3.438995245681e-15
On Sep 17, 2024, at 1:04 AM, miguel.salazar <miguel.salazar at corintis.com<mailto:miguel.salazar at corintis.com>> wrote:
These are the new options (with ksp_monitor_true_residual)
solver_mumps_assembled = {
"ksp_type": "preonly",
"ksp_monitor": None,
"ksp_monitor_true_residual": None,
"pc_type": "python",
"pc_python_type": "firedrake.AssembledPC",
"assembled_pc_type": "lu",
"assembled_pc_factor_mat_solver_type": "mumps",
"assembled_mat_mumps_icntl_14": 200,
"assembled_mat_mumps_icntl_24": 1,
solver_fieldsplit = {
"mat_type": "matfree",
"snes_monitor": None,
"snes_type": "newtonls",
"ksp_type": "fgmres",
"ksp_rtol": 1e-1,
"pc_type": "fieldsplit",
"pc_fieldsplit_type": "additive",
"fieldsplit_0": solver_mumps_assembled,
"fieldsplit_1": solver_mumps_assembled,
And this is the output
The true residual is very low. (3.501082228626e-15)
Corintis SA
1015 Lausanne
Date: Monday, 16 September 2024 at 19:34
Try ksp_monitor_true_residual. Let's see if it is an issue of preconditioned vs unpreconditioned residual.
On Sep 16, 2024, at 1:05 PM, miguel.salazar <miguel.salazar at corintis.com<mailto:miguel.salazar at corintis.com>> wrote:
Hello,
I have this simple example on Firedrake to illustrate my point. I am solving for a two-component poisson equation (uncoupled). Only the first component has a non-zero residual.
import firedrake as fd
from firedrake import inner, grad, dx, sin, pi
N = 10
mesh = fd.UnitSquareMesh(N, N)
V = fd.FunctionSpace(mesh, "CG", 1)
W = V * V
u = fd.Function(W)
v = fd.TestFunction(W)
a = inner(grad(u[0]), grad(v[0])) * dx + inner(grad(u[1]), grad(v[1])) * dx
x = fd.SpatialCoordinate(mesh)
f = fd.Function(V)
f.interpolate(fd.Constant(1e4) * sin(x[0] * pi) * sin(2 * x[1] * pi))
L = f * v[0] * dx
F = a - L
bcs = [fd.DirichletBC(W.sub(0), fd.Constant(2.0), (1,))]
def snes_firedrake_residual(F, u, bcs):
for bcs_ in bcs:
bcs_.apply(u)
residual = fd.assemble(F, bcs=bcs, zero_bc_nodes=True)
with residual.dat.vec_ro as r:
print("Initial residual:", r.norm())
problem = fd.NonlinearVariationalProblem(F, u, bcs=bcs)
"ksp_rtol": 1e-1,
solver = fd.NonlinearVariationalSolver(problem, solver_parameters=solver_fieldsplit)
solver.solve()
The PETSc output is as follow
Miguel
Corintis SA
1015 Lausanne
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240917/936347f6/attachment-0001.html>
Name: 2024-08-1609_02_11-re_mailmigrationfromgoogletooffice365-sebastien.gobel at corintis.com-co_4456a1bf-dd3e-46b7-85f9-21f278e66a79.png
Type: image/png
Desc: 2024-08-1609_02_11-re_mailmigrationfromgoogletooffice365-sebastien.gobel at corintis.com-co_4456a1bf-dd3e-46b7-85f9-21f278e66a79.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240917/936347f6/attachment-0001.png>
