[petsc-users] Hypre AMS usage
Karthikeyan Chockalingam - STFC UKRI karthikeyan.chockalingam at stfc.ac.uk
Tue Sep 10 12:16:53 CDT 2024
Hi Matt,
I am not sure, if I understand how to read the source code, let’s take the below line
PetscCall(PetscOptionsReal("-pc_hypre_ams_relax_weight", "Relaxation weight for AMS smoother", "None", jac->as_relax_weight, &jac->as_relax_weight, &flag3))
(Q1) Am I doing it right by setting as in the line below? How does the line below match up to the above? Since the above line has more arguments
petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_ams_relax_weight", "1.0")
(Q2) How do I go about setting the four parameters below using PetscOptionsSetValue?
PetscCall(PetscOptionsIntArray("-pc_hypre_ams_amg_alpha_options", "AMG options for vector Poisson", "None", jac->as_amg_alpha_opts, &n, &flag2));
  if (flag || flag2) {
    PetscCallExternal(HYPRE_AMSSetAlphaAMGOptions, jac->hsolver, jac->as_amg_alpha_opts[0], /* AMG coarsen type */
                      jac->as_amg_alpha_opts[1],                                            /* AMG agg_levels */
                      jac->as_amg_alpha_opts[2],                                            /* AMG relax_type */
                      jac->as_amg_alpha_theta, jac->as_amg_alpha_opts[3],                   /* AMG interp_type */
                      jac->as_amg_alpha_opts[4]);                                           /* AMG Pmax */
Kind regards,
Karthik.
Date: Monday, 9 September 2024 at 22:00
To: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Hypre AMS usage
On Mon, Sep 9, 2024 at 4:32 PM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
Great. Thank you for letting me know.
I got the reference to KSP as well from libmesh and I am not creating a new KSP.
This time around, I didn’t have to set the PC type and it seems to work.
Excellent.
     Matt
  petscErr = PetscOptionsSetValue(NULL,"-ksp_type", "gmres");
  petscErr = PetscOptionsSetValue(NULL,"-pc_type", "hypre");
  petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_type", "ams");
  petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_ams_relax_type", "2");
  petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_ams_relax_times", "1");
  petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_ams_relax_weight", "1.0");
  petscErr = PetscOptionsSetValue(NULL, "-pc_hypre_ams_omega", "1.0");
  petscErr = PetscOptionsSetValue(NULL, "-ksp_view", NULL);
  petscErr = PetscOptionsSetValue(NULL, "-ksp_monitor_true_residual", NULL);
  petscErr = PetscOptionsSetValue(NULL, "-ksp_converged_reason", NULL);
  petscErr = PetscOptionsSetValue(NULL, "-options_left", NULL);
  petscErr = KSPSetFromOptions(ksp);
  // Set discrete gradient
  petscErr = PCHYPRESetDiscreteGradient(pc, par_G);
  // Set vertex coordinates
  petscErr = PCHYPRESetEdgeConstantVectors(pc, par_xvec, par_yvec, par_zvec);
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Date: Monday, 9 September 2024 at 21:11
To: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>>
Cc: Stefano Zampini <stefano.zampini at gmail.com<mailto:stefano.zampini at gmail.com>>, petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
On Mon, Sep 9, 2024 at 4:03 PM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
I never explicitly called KSPGetPC(). I am embedding AMS in a libmesh (fem) example.  So, I only got the reference to pc from libmesh and set  petscErr = PCHYPRESetDiscreteGradient(pc, par_G);
However, you are creating a _new_ KSP, so your PC will not match it. This is not doing what you want.
     Matt
Date: Monday, 9 September 2024 at 20:57
On Mon, Sep 9, 2024 at 3:38 PM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
I didn’t know how to check the pc type but adding
petscErr = PCSetType(pc, "hypre");
before the two functions made it to work.
But how does it work from the command line?
For summary:
  KSPCreate(mesh.comm().get(), &ksp);
  petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_ams_relax_weigh", "1.0");
Where is the KSPGetPC() call?
     Matt
  // Set pc type
Date: Monday, 9 September 2024 at 19:46
On Mon, Sep 9, 2024 at 2:18 PM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
Calling the two functions after KSPSetFromOptions() did not work either.
Can you check that the PC has the correct type when you call it?
     Matt
Everything works from the command line.
I haven’t set KSPSetOperators, not sure if that is an issue.
Date: Monday, 9 September 2024 at 19:09
On Mon, Sep 9, 2024 at 1:21 PM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
Hi Stefano,
Thank you. That was helpful. I tried the following:
It errored though I have set PCHYPRESetEdgeConstantVectors.
My guess is that the "pc" was not yet Hypre, since that type was not set until KSPSetFromOptions() was called. So you need
to call those two functions after that call.
    Matt
But my program works, without PetscOptionsSetValue and by passing everything on the command line.
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: HYPRE AMS preconditioner needs either the coordinate vectors via PCSetCoordinates() or the edge constant vectors via PCHYPRESetEdgeConstantVectors() or the interpolation matrix via PCHYPRESetInterpolations()
[0]PETS C ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
[0]PETSC ERROR:   Option left: name:-ksp_converged_reason (no value) source: code
[0]PETSC ERROR:   Option left: name:-options_left (no value) source: code
[0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dFRi6cIw$  for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.20.3, unknown
[0]PETSC ERROR: ./example-dbg on a arch-moose named HC20210312 by karthikeyan.chockalingam Mon Sep  9 18:10:13 2024
[0]PETSC ERROR: Configure options --with-64-bit-indices --with-cxx-dialect=C++17 --with-debugging=no --with-fortran-bindings=0 --with-mpi=1 --with-openmp=1 --with-shared-libraries=1 --with-sowing=0 --download-fblaslapack=1 --download-hypre=1 --download-metis=1 --download-mumps=1 --download-ptscotch=1 --download-parmetis=1 --download-scalapack=1 --download-slepc=1 --download-strumpack=1 --download-superlu_dist=1 --download-bison=1 --download-hdf5=1 --with-hdf5-fortran-bindings=0 --download-hdf5-configure-arguments="--with-zlib" --with-make-np=4
[0]PETSC ERROR: #1 PCSetUp_HYPRE() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/pc/impls/hypre/hypre.c:295
[0]PETSC ERROR: #2 PCSetUp() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/pc/interface/precon.c:1080
[0]PETSC ERROR: #3 KSPSetUp() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:415
[0]PETSC ERROR: #4 KSPSolve_Private() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:833
[0]PETSC ERROR: #5 KSPSolve() at /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:1080
libMesh terminating:
From: Stefano Zampini <stefano.zampini at gmail.com<mailto:stefano.zampini at gmail.com>>
Date: Monday, 9 September 2024 at 17:02
To: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Cc: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>>, petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
I would say the best way is to look at the source code
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L2061__;Iw!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dA_V2Zrh$
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L1239__;Iw!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dCD6gvmG$
Il giorno lun 9 set 2024 alle ore 18:50 Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> ha scritto:
On Mon, Sep 9, 2024 at 10:17 AM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
Hi Matt,
You mentioned it doesn’t hurt to set the smoothing flags
https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dA76B8UI$ <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL55yOMB-v$>
Do you know where I can look for the equivalent PETSc commands? Thank you.
Yes, this is described here: https://urldefense.us/v3/__https://petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dC7ch0OK$ <https://urldefense.us/v3/__https:/petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9e0RfePC$>
The best way is to run with -help or look at the source.
     Matt
Kind regards,
Karthik.
Date: Friday, 6 September 2024 at 17:57
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
On Fri, Sep 6, 2024 at 11:37 AM Karthikeyan Chockalingam - STFC UKRI via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I am trying to use the Hypre AMS preconditioner for the first time.
I am following the example problem from Hypre
https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dN3BQIpW$ <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL5ySgA0XM$>
I have so far successfully set the discrete gradient operator and vertex co-ordinates,
Do I need to set the following smoothing options?
It cannot hurt. I would set them to begin with.
Also, do I need to convert from MATMPIAIJ to CSR?
https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dGRl6keR$ <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL53Trv1si$>
No.
What are the other PETSc calls to invoke AMS? Is there an example problem I can look at?
I do not know. I don't think we have an example.
    Matt
Thank you.
Karthik.
Karthik Chockalingam, Ph.D.
Senior Research Software Engineer
High Performance Systems Engineering Group
Hartree Centre | Science and Technology Facilities Council
 [signature_3970890138]
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dEmst4km$ <https://urldefense.us/v3/__http:/www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9ZyhqOzc$>
-- Norbert Wiener
Stefano
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dEmst4km$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YLWMpSx0H9uhaBMkNdt_SaKxHEab3a-U9xdt6315FLGVN37kf7VGm3fThdy1j1KCH5SPP8ynAhL3YjRHwz2e9puxcSU7dGzxni0B$ >
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240910/8c73d9b5/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240910/8c73d9b5/attachment-0001.png>
