[petsc-users] Hypre AMS usage
Mon Sep 9 14:56:56 CDT 2024
On Mon, Sep 9, 2024 at 3:38 PM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> I didn’t know how to check the pc type but adding
> petscErr = PCSetType(pc, "hypre");
> before the two functions made it to work.
> But how does it work from the command line?
> For summary:
>   KSPCreate(mesh.comm().get(), &ksp);
>   petscErr = PetscOptionsSetValue(NULL,"-ksp_type", "gmres");
>   petscErr = PetscOptionsSetValue(NULL,"-pc_type", "hypre");
>   petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_type", "ams");
>   petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_ams_relax_type", "2");
>   petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_ams_relax_times", "1");
>   petscErr = PetscOptionsSetValue(NULL,"-pc_hypre_ams_relax_weigh", "1.0");
>   petscErr = PetscOptionsSetValue(NULL, "-pc_hypre_ams_omega", "1.0");
>   petscErr = PetscOptionsSetValue(NULL, "-ksp_view", NULL);
>   petscErr = PetscOptionsSetValue(NULL, "-ksp_monitor_true_residual",
> NULL);
>   petscErr = PetscOptionsSetValue(NULL, "-ksp_converged_reason", NULL);
>   petscErr = PetscOptionsSetValue(NULL, "-options_left", NULL);
>   petscErr = KSPSetFromOptions(ksp);
Where is the KSPGetPC() call?
     Matt
>   // Set pc type
>   // Set discrete gradient
>   petscErr = PCHYPRESetDiscreteGradient(pc, par_G);
>   // Set vertex coordinates
>   petscErr = PCHYPRESetEdgeConstantVectors(pc, par_xvec, par_yvec,
> par_zvec);
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Monday, 9 September 2024 at 19:46
> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> *Cc: *Stefano Zampini <stefano.zampini at gmail.com>, petsc-users at mcs.anl.gov
> <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Hypre AMS usage
> On Mon, Sep 9, 2024 at 2:18 PM Karthikeyan Chockalingam - STFC UKRI <
> Calling the two functions after KSPSetFromOptions() did not work either.
> Can you check that the PC has the correct type when you call it?
>   Thanks,
>      Matt
> Everything works from the command line.
> I haven’t set KSPSetOperators, not sure if that is an issue.
> *Date: *Monday, 9 September 2024 at 19:09
> On Mon, Sep 9, 2024 at 1:21 PM Karthikeyan Chockalingam - STFC UKRI <
> Hi Stefano,
> Thank you. That was helpful. I tried the following:
> par_zvec);
> NULL);
> It errored though I have set PCHYPRESetEdgeConstantVectors.
> My guess is that the "pc" was not yet Hypre, since that type was not set
> until KSPSetFromOptions() was called. So you need
> to call those two functions after that call.
>   Thanks,
>     Matt
> But my program works, without PetscOptionsSetValue and by passing
> everything on the command line.
> *[0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: HYPRE AMS preconditioner needs either the coordinate
> vectors via PCSetCoordinates() or the edge constant vectors via
> PCHYPRESetEdgeConstantVectors() or the interpolation matrix via
> PCHYPRESetInterpolations()
> [0]PETS C ERROR: WARNING! There are unused option(s) set! Could be the
> program crashed before usage or a spelling mistake, etc!
> [0]PETSC ERROR:   Option left: name:-ksp_converged_reason (no value)
> source: code
> [0]PETSC ERROR:   Option left: name:-options_left (no value) source: code
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtcUECUOq$  for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.20.3, unknown
> [0]PETSC ERROR: ./example-dbg on a arch-moose named HC20210312 by
> karthikeyan.chockalingam Mon Sep  9 18:10:13 2024
> [0]PETSC ERROR: Configure options --with-64-bit-indices
> --with-cxx-dialect=C++17 --with-debugging=no --with-fortran-bindings=0
> --with-mpi=1 --with-openmp=1 --with-shared-libraries=1 --with-sowing=0
> --download-fblaslapack=1 --download-hypre=1 --download-metis=1
> --download-mumps=1 --download-ptscotch=1 --download-parmetis=1
> --download-scalapack=1 --download-slepc=1 --download-strumpack=1
> --download-superlu_dist=1 --download-bison=1 --download-hdf5=1
> --with-hdf5-fortran-bindings=0
> --download-hdf5-configure-arguments="--with-zlib" --with-make-np=4
> [0]PETSC ERROR: #1 PCSetUp_HYPRE() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/pc/impls/hypre/hypre.c:295
> [0]PETSC ERROR: #2 PCSetUp() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/pc/interface/precon.c:1080
> [0]PETSC ERROR: #3 KSPSetUp() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:415
> [0]PETSC ERROR: #4 KSPSolve_Private() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:833
> [0]PETSC ERROR: #5 KSPSolve() at
> /Users/karthikeyan.chockalingam/moose/petsc/src/ksp/ksp/interface/itfunc.c:1080
> libMesh terminating:
> HYPRE AMS preconditioner needs either the coordinate vectors via
> *From: *Stefano Zampini <stefano.zampini at gmail.com>
> *Date: *Monday, 9 September 2024 at 17:02
> *To: *Matthew Knepley <knepley at gmail.com>
> *Cc: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> karthikeyan.chockalingam at stfc.ac.uk>, petsc-users at mcs.anl.gov <
> I would say the best way is to look at the source code
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L2061__;Iw!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtcheDSS5$
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L1239__;Iw!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtbmu07n0$
> Il giorno lun 9 set 2024 alle ore 18:50 Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Mon, Sep 9, 2024 at 10:17 AM Karthikeyan Chockalingam - STFC UKRI <
> Hi Matt,
> You mentioned it doesn’t hurt to set the smoothing flags
> https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtQ3XnN-5$
> <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL55yOMB-v$>
> Do you know where I can look for the equivalent PETSc commands? Thank you.
> Yes, this is described here:
> https://urldefense.us/v3/__https://petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtTAEu7DZ$
> <https://urldefense.us/v3/__https:/petsc.org/main/manualpages/PC/PCHYPRE/__;!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9e0RfePC$>
> The best way is to run with -help or look at the source.
>   Thanks,
>      Matt
> Kind regards,
> Karthik.
> *Date: *Friday, 6 September 2024 at 17:57
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> On Fri, Sep 6, 2024 at 11:37 AM Karthikeyan Chockalingam - STFC UKRI via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I am trying to use the Hypre AMS preconditioner for the first time.
> I am following the example problem from Hypre
> https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtXIoB5oo$
> <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL5ySgA0XM$>
> I have so far successfully set the discrete gradient operator and vertex
> co-ordinates,
> par_zvec);
> Do I need to set the following smoothing options?
> It cannot hurt. I would set them to begin with.
> Also, do I need to convert from MATMPIAIJ to CSR?
> https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtTwjkoKg$
> <https://urldefense.us/v3/__https:/github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL53Trv1si$>
> No.
> What are the other PETSc calls to invoke AMS? Is there an example problem
> I can look at?
> I do not know. I don't think we have an example.
>   Thanks,
>     Matt
> Thank you.
> Karthik.
> *Karthik Chockalingam, Ph.D.*
> Senior Research Software Engineer
> High Performance Systems Engineering Group
> Hartree Centre | Science and Technology Facilities Council
>  [image: signature_3970890138]
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtXHp7Z0r$
> <https://urldefense.us/v3/__http:/www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dM_jKT_vX0NCVNcY9XOTTUaTSW-TF2CgOkB2UDeZ2ztYXapdmLlSBT4XhV7PknN3ewygGWDbKFEP9ZyhqOzc$>
> experiments lead.
> -- Norbert Wiener
> Stefano
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtT9noRGp$ >
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtXHp7Z0r$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bPCXhLGg7jBKQ8N7LCSSnf6NovqslSKRmN9Okpj0J-2kMV1H_p1J2k5WL29WsxTzFFOjJqVptu6mtT9noRGp$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240909/6e0500f3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240909/6e0500f3/attachment-0001.png>
