[petsc-users] Hypre AMS usage
Karthikeyan Chockalingam - STFC UKRI karthikeyan.chockalingam at stfc.ac.uk
Fri Sep 6 10:37:28 CDT 2024
Hello,
I am trying to use the Hypre AMS preconditioner for the first time.
I am following the example problem from Hypre
https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L954__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL5ySgA0XM$
I have so far successfully set the discrete gradient operator and vertex co-ordinates,
// Set discrete gradient
  petscErr = PCHYPRESetDiscreteGradient(pc, par_G);
  // Set vertex coordinates
  petscErr = PCHYPRESetEdgeConstantVectors(pc, par_xvec, par_yvec, par_zvec);
Do I need to set the following smoothing options?
https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L965__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL55yOMB-v$
Also, do I need to convert from MATMPIAIJ to CSR?
https://urldefense.us/v3/__https://github.com/hypre-space/hypre/blob/3caa81955eb8d1b4e35d9b450e27cf6d07b50f6e/src/examples/ex15.c*L984__;Iw!!G_uCfscf7eWS!biuCOXkV-qD-e8iTXiwaD9XJ0EWuqr2PidZJdPqbnFzCshQFo-mclGSvGBOPuGSTkjPvMKnIfJzWos7QShcSitpwyrhL53Trv1si$
What are the other PETSc calls to invoke AMS? Is there an example problem I can look at?
Thank you.
Karthik.
Karthik Chockalingam, Ph.D.
Senior Research Software Engineer
High Performance Systems Engineering Group
Hartree Centre | Science and Technology Facilities Council
karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>
 [signature_3970890138]
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240906/b35c42d6/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240906/b35c42d6/attachment-0001.png>
