[petsc-users] KSPSolve + MUMPS memory growth issues
Matthew Knepley
knepley at gmail.com
Thu Sep 5 13:47:51 CDT 2024
On Thu, Sep 5, 2024 at 2:46 PM Corbijn van Willenswaard, Lars (UT) <
l.j.corbijnvanwillenswaard at utwente.nl> wrote:
> Thank you, that makes testing so much easier. So far, I’ve been able to
> shrink the matrix (now only 64x64) and see that it still has growing memory
> usage over time. Unfortunately, I’ve no access to a linux machine right
> now, so running through valgrind like Barry suggested has to wait.
Just to check. Your matrix, with that simple code, producing growing
memory? If you send the matrix, I will find the problem.
Matt
> Lars
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Thursday, 5 September 2024 at 19:56
> *To: *"Corbijn van Willenswaard, Lars (UT)" <
> *Cc: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] KSPSolve + MUMPS memory growth issues
> On Thu, Sep 5, 2024 at 1:40 PM Corbijn van Willenswaard, Lars (UT) via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
> Dear PETSc,
> For the last months I’ve struggled with a solver that I wrote for a FEM
> eigenvalue problem running out of memory. I’ve traced it to KSPSolve +
> MUMPS being the issue, but I'm getting stuck on digging deeper.
> The reason I suspect the KSPSolve/MUMPS is that when commenting out the
> KSPSolve the memory stays constant while running the rest of the algorithm.
> Of course, the algorithm also converges to a different result in this
> setup. When changing the KSP statement to
> for(int i = 0; i < 100000000; i++) KSPSolve(A_, vec1_, vec2_);
> the memory grows faster than when running the algorithm. Logging shows
> that the program never the terminating i=100M. Measuring the memory growth
> using ps (started debugging before I knew of PETSc's features) I see a
> growth in the RSS on a single compute node of up to 300MB/min for this
> artificial case. Real cases grow more like 60MB/min/node, which causes a
> kill due to memory exhaustion after about 2-3 days.
> Locally (Mac) I've been able to reproduce this both with 6 MPI processes
> and with a single one. Instrumenting the code to show differences in
> PetscMemoryGetCurrentUsage (full code below), shows that the memory
> increases every step at the start, but also does at later iterations (small
> excerpt from the output):
> rank step memory (increase since prev step)
> 0 6544 current 39469056( 8192)
> 0 7086 current 39477248( 8192)
> 0 7735 current 39497728( 20480)
> 0 9029 current 39501824( 4096)
> A similar output is visible in a run with 6 ranks, where there does not
> seem to be a pattern as to which of the ranks increases at which step.
> (Note I've checked PetscMallocGetCurrentUsage, but that is constant)
> Switching the solver to petsc's own solver on a single rank does not show
> a memory increase after the first solve. Changing the solve to overwrite
> the vector will result in a few increases after the first solve, but these
> do not seem to repeat. So, changes like VecCopy(vec2, vec1_); KSPSolve(A_,
> vec1_, vec1_);.
> Does anyone have an idea on how to further dig into this problem?
> I think the best way is to construct the simplest code that reproduces
> your problem. For example, we could save your matrix in a binary file
> -ksp_view_mat binary:mat.bin
> and then use a very simple code:
> #include <petsc.h>
> int main(int argc, char **argv)
> PetscViewer viewer;
> Mat A;
> Vec b, x;
> PetscCall(PetscInitialize(&argc, &argv, NULL, NULL));
> PetscCall(PetscViewerBinaryOpen(PETSC_COMM_WORLD, "mat.bin",
> PETSC_MODE_READ, &viewer));
> PetscCall(MatLoad(A, viewer));
> PetscCall(PetscViewerDestroy(&viewer));
> PetscCall(MatCreateVecs(A, &x, &b));
> PetscCall(VecSet(b, 1.));
> PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp));
> PetscCall(KSPSetOperators(ksp, A, A));
> PetscCall(KSPSetFromOptions(ksp));
> for (PetscInt i = 0; i < 100000; ++i) PetscCall(KSPSolve(ksp, b, x));
> PetscCall(KSPDestroy(&ksp));
> PetscCall(MatDestroy(&A));
> PetscCall(VecDestroy(&b));
> PetscCall(VecDestroy(&x));
> PetscCall(PetscFinalize());
> return(0);
> and see if you get memory increase.
> Thanks,
> Matt
> Kind regards,
> Lars Corbijn
> Instrumentation:
> PetscLogDouble lastCurrent, current;
> int rank;
> MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
> for(int i = 0; i < 100000000; ++i) {
> PetscMemoryGetCurrentUsage(&lastCurrent);
> PetscMemoryGetCurrentUsage(¤t);
> if(current != lastCurrent) {
> std::cout << std::setw(2) << rank << " " << std::setw(6) << i
> << " current " << std::setw(8) << (int) current <<
> std::right
> << "(" << std::setw(6) << (int)(current - lastCurrent)
> << std::endl;
> lastCurrent = current;
> Matrix details
> The matrix A in question is created from a complex valued matrix C_ (type
> mataij) using the following code (modulo renames). Theoretically it should
> be a Laplacian with phase-shift periodic boundary conditions
> MatHermitianTranspose(C_, MAT_INITIAL_MATRIX, &Y_);
> MatProductCreate(C_, Y_, NULL, & A_);
> MatProductSetType(A_, MATPRODUCT_AB);
> MatProductSetFromOptions(A_);
> MatProductSymbolic(A_);
> MatProductNumeric(A_);
> Petsc arguments: -log_view_memory -log_view :petsc.log -ksp_type preonly
> -pc_type lu -pc_factor_mat_solver_type mumps -bv_matmult vecs -memory_view
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a3fMSsz8iwy1xT-RP5SLCxWCyf4c8fdJbl-sBGzc7G9RNSjBFaOZMQIIs26Kkmx86CA_koT3TvTMMeiNQTeQ$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a3fMSsz8iwy1xT-RP5SLCxWCyf4c8fdJbl-sBGzc7G9RNSjBFaOZMQIIs26Kkmx86CA_koT3TvTMMRdxjnQm$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a3fMSsz8iwy1xT-RP5SLCxWCyf4c8fdJbl-sBGzc7G9RNSjBFaOZMQIIs26Kkmx86CA_koT3TvTMMeiNQTeQ$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a3fMSsz8iwy1xT-RP5SLCxWCyf4c8fdJbl-sBGzc7G9RNSjBFaOZMQIIs26Kkmx86CA_koT3TvTMMRdxjnQm$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240905/ac647de4/attachment-0001.html>
