[petsc-users] Bug or mis-use for 64 indices PETSc mpi linear solver server with more than 8 cores
    Lin_Yuxiang
    linyx199071 at gmail.com
    Wed Sep  4 14:52:59 CDT 2024
To whom it may concern:
I recently tried to use the 64 indices PETSc to replace the legacy code's
solver using MPI linear solver server. However, it gives me error when I
use more than 8 cores, saying
Get NNZ
MatsetPreallocation
MatsetValue
MatSetValue Time per kernel: 43.1147 s
Matassembly
VecsetValue
pestc_solve
Read -1, expected 1951397280, errno = 14
When I tried the -start_in_debugger, the error seems from MPI_Scatter:
Rank0:
#3  0x00001555512e4de5 in mca_pml_ob1_recv () from
/usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_pml_ob1.so
#4  0x0000155553e01e60 in PMPI_Scatterv () from
/lib/x86_64-linux-gnu/libmpi.so.40
#5  0x0000155554b13eab in PCMPISetMat (pc=pc at entry=0x0) at
/auto/research/rdfs/home/lyuxiang/petsc-3.20.4/src/ksp/pc/impls/mpi/pcmpi.c:230
#6  0x0000155554b17403 in PCMPIServerBegin () at
/auto/research/rdfs/home/lyuxiang/petsc-3.20.4/src/ksp/pc/impls/mpi/pcmpi.c:464
#7  0x00001555540b9aa4 in PetscInitialize_Common (prog=0x7fffffffe27b
"geosimtrs_mpiserver", file=file at entry=0x0,
    help=help at entry=0x55555555a1e0 <help> "Solves a linear system in
parallel with KSP.\nInput parameters include:\n  -view_exact_sol   : write
exact solution vector to stdout\n  -m <mesh_x>       : number of mesh
points in x-direction\n  -n <mesh"..., ftn=ftn at entry=PETSC_FALSE,
readarguments=readarguments at entry=PETSC_FALSE, len=len at entry=0)
    at
/auto/research/rdfs/home/lyuxiang/petsc-3.20.4/src/sys/objects/pinit.c:1109
#8  0x00001555540bba82 in PetscInitialize (argc=argc at entry=0x7fffffffda8c,
args=args at entry=0x7fffffffda80, file=file at entry=0x0,
points in x-direction\n  -n <mesh"...) at
/auto/research/rdfs/home/lyuxiang/petsc-3.20.4/src/sys/objects/pinit.c:1274
#9  0x0000555555557673 in main (argc=<optimized out>, args=<optimized out>)
at geosimtrs_mpiserver.c:29
 Rank1-10
0x0000155553e1f030 in ompi_coll_base_allgather_intra_bruck () from
#4  0x0000155550f62aaa in ompi_coll_tuned_allgather_intra_dec_fixed () from
/usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_coll_tuned.so
#5  0x0000155553ddb431 in PMPI_Allgather () from
#6  0x00001555541a2289 in PetscLayoutSetUp (map=0x555555721ed0) at
/auto/research/rdfs/home/lyuxiang/petsc-3.20.4/src/vec/is/utils/pmap.c:248
#7  0x000015555442e06a in MatMPIAIJSetPreallocationCSR_MPIAIJ
(B=0x55555572d850, Ii=0x15545a778010, J=0x15545beacb60, v=0x1554cff55e60)
    at
/auto/research/rdfs/home/lyuxiang/petsc-3.20.4/src/mat/impls/aij/mpi/mpiaij.c:3885
#8  0x00001555544284e3 in MatMPIAIJSetPreallocationCSR (B=0x55555572d850,
i=0x15545a778010, j=0x15545beacb60, v=0x1554cff55e60) at
/auto/research/rdfs/home/lyuxiang/petsc-3.20.4/src/mat/impls/aij/mpi/mpiaij.c:3998
#9  0x0000155554b1412f in PCMPISetMat (pc=pc at entry=0x0) at
/auto/research/rdfs/home/lyuxiang/petsc-3.20.4/src/ksp/pc/impls/mpi/pcmpi.c:250
#10 0x0000155554b17403 in PCMPIServerBegin () at
#11 0x00001555540b9aa4 in PetscInitialize_Common (prog=0x7fffffffe27b
readarguments=readarguments at entry=PETSC_FALSE, len=len at entry=0) at
#12 0x00001555540bba82 in PetscInitialize (argc=argc at entry=0x7fffffffda8c,
#13 0x0000555555557673 in main (argc=<optimized out>, args=<optimized out>)
This did not happen in 32bit indiced PETSc, running with more than 8 cores
runs smoothly using MPI linear solver server, nor did it happen on 64 bit
indiced MPI version (not with mpi_linear_solver_server), only happens on 64
bit PETSc mpi linear solver server, I think it maybe a potential bug?
Any advice would be greatly appreciated, the matrix and ia, ja is too big
to upload, so if anything you need to debug pls let me know
   Machine type: HPC
   OS version and type: Linux houamd009 6.1.55-cggdb11-1 #1 SMP Fri Sep 29
   10:09:13 UTC 2023 x86_64 GNU/Linux
   PETSc version: #define PETSC_VERSION_RELEASE    1
   #define PETSC_VERSION_MAJOR      3
   #define PETSC_VERSION_MINOR      20
   #define PETSC_VERSION_SUBMINOR   4
   #define PETSC_RELEASE_DATE       "Sep 28, 2023"
   #define PETSC_VERSION_DATE       "Jan 29, 2024"
   MPI implementation: OpenMPI
   Compiler and version: GNU
Yuxiang Lin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240904/9ebeea66/attachment.html>
