[petsc-users] How to create an array of vectors of type Vec (for use with slepc EPSGetInvariantSubspace)
dazza simplythebest
sayosale at hotmail.com
Mon Sep 2 01:56:10 CDT 2024
Dear All,
I am seeking to perform a large number of eigenvalue calculations (related to a fluid dynamics
problem) using the slepc framework. I have written the program that calls slepc and validated its solutions against
known results for special cases - the Jacobi-Davidson iteration seemed to perform best on this problem.
Since in the 'production-level' calculation I will step through a parameter space which should
mean only small changes to the eigenproblem between each calculation, it seems to make sense
to use the previous solution as the initial guess for the next calculation.
The sequence to execute this strategy would seem to be:
To write out the current soln subspace:
call EPSGetInvariantSubspace
[ call VecView -> binary file (if a file storage is required for possible restart)]
To then read in this data to use it as the initial subspace for the next run:
call EPSSetInitialSpace
My question is that EPSGetInvariantSubspace needs an 'array of nconv vectors', how does one create
such an array ? My understanding is that the Vec structure is just a one-dimensional array (with contents
possibly scattered in non-contiguous memory locations !?) , so do we just need to create a long Vec
that stores multiple vectors ? How can we do this (the examples I have seen thus far use a MatCreateVecs to specify the size
of the Vec)?
If loading such a subspace from a binary file (created maybe by VecView), presumably VecLoad is the
best way to load such an array of vectors from the binary file ?
Best wishes and many thanks,
Dan.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240902/b39ee957/attachment.html>
