[petsc-users] Rigid body nullspace for Stokes operator
Mark Adams mfadams at lbl.gov
Wed Oct 30 14:25:51 CDT 2024
On Wed, Oct 30, 2024 at 1:49 PM Amneet Bhalla <mail2amneet at gmail.com> wrote:
> I think the nullspace for the velocity operator is of the form
> vnull = U + ω × r
> in which U is a rigid body velocity and ω is the rigid body rotational
> velocity, and r is the radius vector from the center of mass. I believe I
> need to construct 6 nullspace vectors in 3D and 3 nullspace vectors in 2D.
> Sounds correct?
yes
> Also does the center of mass coordinates matter when defining r?
no, but this would be good for conditioning, which I've never seen being an
issue.
You can just coordinate as r. That is the origin is your "center of mass".
> On Wed, Oct 30, 2024 at 7:53 AM Amneet Bhalla <mail2amneet at gmail.com>
> wrote:
>> @Mark: Is there some document/paper that I can follow to check the
>> algebra of these zero eigenvectors/null space modes?
>> @Jed : We use a projection method preconditioner to solve the coupled
>> velocity pressure system as described here (
>> https://urldefense.us/v3/__https://www.sciencedirect.com/science/article/pii/S0021999123004205__;!!G_uCfscf7eWS!dQPSeiutdub0FrPQ-gswdIQg7lOPRtrx-WocvHMu2ULBMuYLTKOxD_tE709brtLs8GY5uJVTOApLX6lrX3ZWoA8$ ). It
>> is an approximation of the Schur complement. As a part of projection
>> preconditioner, we need to solve just the momentum equation separately
>> without considering the pressure part.
>> On Tue, Oct 29, 2024 at 8:03 PM Jed Brown <jed at jedbrown.org> wrote:
>>> And to be clear, we recommend using fieldsplit Schur to separate the
>>> pressure and velocity part (there are many examples). Applying AMG directly
>>> to the saddle point problem will not be a good solver because the
>>> heuristics assume positivity and do not preserve inf-sup stability (nor do
>>> standard smoothers).
>>> Mark Adams <mfadams at lbl.gov> writes:
>>> > This is linear elasticity and there are 6 "null" vectors (if you
>>> removed
>>> > Dirichlet boundary conditions these are eigenvectors with zero
>>> eigenvalue):
>>> > 3 translations, x, y, z, and three rotatiions xx, yy ,zz.
>>> > x = (1,0,0,1,0,0,1,0 ...)
>>> > and xx is something like (0, z_1, -y_1, 0, z_2, -y_2, ...) where z_1
>>> is the
>>> > z coordinate of the first vertex, etc.
>>> > Mark
>>> > On Tue, Oct 29, 2024 at 3:47 PM Amneet Bhalla <mail2amneet at gmail.com>
>>> wrote:
>>> >> Hi Mark,
>>> >> Thanks! I am not sure how to construct null space and zero energy
>>> modes
>>> >> manually for this operator. Is there some theory or documentation I
>>> can
>>> >> follow to figure out what the null space and zero energy modes look
>>> like
>>> >> for this operator? Once I know what these are in symbolic form, I
>>> think I
>>> >> should be able to construct them manually.
>>> >> Best,
>>> >> --Amneet
>>> >> On Tue, Oct 29, 2024 at 7:35 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> >>> Oh my mistake. You are using staggered grids. So you don't have a
>>> block
>>> >>> size that hypre would use for the "nodal" methods.
>>> >>> I'm not sure what you are doing exactly, but try hypre and you could
>>> >>> create the null space, zero energy modes, manually, attach to the
>>> matrix
>>> >>> and try GAMG.
>>> >>> You can run with '-info :pc' and grep on GAMG to see if GAMG is
>>> picking
>>> >>> the null space up (send this output if you can't figure it out).
>>> >>> Thanks,
>>> >>> Mark
>>> >>> On Tue, Oct 29, 2024 at 9:28 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> >>>> This coordinate interface is just a shortcut for vertex based
>>> >>>> discretizations with 3 dof per vertex, etc. (maybe works in 2D).
>>> >>>> You will need to construct the null space vectors manually and
>>> attach it
>>> >>>> to the matrix. Used by GAMG.
>>> >>>> Note, for hypre you want to use the "nodal" options and it does not
>>> use
>>> >>>> these null space vectors. That is probably the way you want to go.
>>> >>>> eg: -pc_hypre_boomeramg_nodal_coarsen
>>> >>>> I would run with hypre boomerang and -help and grep on nodal to see
>>> all
>>> >>>> the "nodal" options and use them.
>>> >>>> Thanks,
>>> >>>> Mark
>>> >>>> On Mon, Oct 28, 2024 at 8:06 PM Amneet Bhalla <
>>> >>>> wrote:
>>> >>>>> Hi Folks,
>>> >>>>> I am trying to solve the momentum equation in a projection
>>> >>>>> preconditioner using GAMG or Hypre solver. The equation looks like
>>> for
>>> >>>>> velocity variable *v* looks like:
>>> >>>>>  [image: Screenshot 2024-10-28 at 4.15.17 PM.png]
>>> >>>>> Here, μ is spatially varying dynamic viscosity and λ is spatially
>>> >>>>> varying bulk viscosity. I understand that I need to specify rigid
>>> body
>>> >>>>> nullspace modes to the multigrid solver in order to accelerate its
>>> >>>>> convergence. Looking into this routine
>>> MatNullSpaceCreateRigidBody() (
>>> https://urldefense.us/v3/__https://petsc.org/release/manualpages/Mat/MatNullSpaceCreateRigidBody/__;!!G_uCfscf7eWS!bVR6duCoDqPhZrWS-sm1c5qxsFPjZMhdT86AqLpPzWgVy5qoRhd4_Jue2LJOIS6LRrtV2cHGrqger1Yvb-Y5f-0$
>>> https://urldefense.us/v3/__https://petsc.org/release/manualpages/Mat/MatNullSpaceCreateRigidBody/__;!!G_uCfscf7eWS!eKqgIJjCdMzIU76f7X65AmGxrU_-lC7W02BMWafJ77DNf_IuQk6O1X3qU1x9Ez8NJ20vZEL-mF6T1yNmDnwv0eWa2w$
>>> >>>>> I see that I need to provide the coordinates of each node. I am
>>> using
>>> >>>>> staggered grid discretization. Do I need to provide coordinates of
>>> >>>>> staggered grid locations?
>>> >>>>> Thanks,
>>> >>>>> --Amneet
>>> >> --Amneet
>> --Amneet
> --Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241030/c2bdc853/attachment-0001.html>
