[petsc-users] Example of SNES using matrix free jacobian
Barry Smith
bsmith at petsc.dev
Tue Oct 29 14:01:59 CDT 2024
Don't call
KSPSetOperators(ksp, J, J);
instead call
SNESSetJacobian(snes,J,J, MatMFFDComputeJacobian)
but I am not sure that would explain the crash.
BTW: since you are applying no preconditioner if the matrix is ill-conditioned it may take many iterations or not converge. You can try something like -ksp_gmres_restart 100 or similar value to try to improve convergence (default is 30).
Barry
> On Oct 29, 2024, at 12:37 PM, Daniel Pino Munoz <daniel.pino_munoz at mines-paristech.fr> wrote:
> Dear all,
> I have a linear problem that I am currently solving with a KSP matrix-free.
> I would like to move on to a non linear problem, so figure I could start by solving the same linear problem using SNES. So I am setting the problem as follows:
> SNESCreate(PETSC_COMM_WORLD, &snes);
> MatCreateShell(PETSC_COMM_WORLD, n_dofs, n_dofs, PETSC_DETERMINE, PETSC_DETERMINE, &ctx, &J);
> MatCreateShell(PETSC_COMM_WORLD, n_dofs, n_dofs, PETSC_DETERMINE, PETSC_DETERMINE, &ctx, &B);
> MatShellSetOperation(J, MATOP_MULT, (void (*)(void))(Multiplication));
> MatCreateVecs(J, &x_sol, &b);
> VecDuplicate(x_sol, &r);
> SNESSetFromOptions(snes);
> SNESSetFunction(snes, r, &(computeResidual), &ctx);
> SNESSetUseMatrixFree(snes, PETSC_FALSE, PETSC_TRUE);
> SNESGetLineSearch(snes, &linesearch);
> SNESGetKSP(snes, &ksp);
> KSPSetInitialGuessNonzero(ksp, PETSC_TRUE);
> I tested it with a small problem (compiled in debug) and it works.
> When I compiled it in Release, it crashes with a segfault. I tried running the Debug version through valgrind, but even for a small problem, it is too slow. So I was wondering if you guys could see any rocky mistake on the lines I used above?
> Otherwise, is there any example that uses a SNES combined with a matrix free KSP operator?
> Thank you,
> Daniel
