[petsc-users] Check the precision for real numbers
Barry Smith bsmith at petsc.dev
Tue Oct 29 07:47:13 CDT 2024
   Do you mean inside Fortran source code, you want to determine if single or double is being used?
   1) The PETSc preprocess C macros are also included in Petsc's Fortran include files, so either
        PETSC_USE_REAL_SINGLE or PETSC_USE_REAL_DOUBLE is always defined, you can then use
        preprocessor macros to check: for example
        #if defined(PETSC_USE_REAL_SINGLE)
             xxxx
        #else
             xxxx
        #endif
    2) you can apply the Fortran kind() function to PetscReal to determine what type it is.
    I hope this helps,
    Barry
> On Oct 28, 2024, at 10:44 PM, Runjian Wu <wurunjian at gmail.com> wrote:
> Hi all,
> I have a question about how to return the precision for real number in Fortran code?
> Thanks,
> Runjian
