[petsc-users] Requesting help with SNES non-linear example
Vaishak Prasad
vaishakprasad at gmail.com
Sat Oct 26 05:39:23 CDT 2024
Dear Jose,
Thankyou very much for your response.
On Sat, Oct 26, 2024 at 3:32 PM Jose E. Roman <jroman at dsic.upv.es> wrote:
> Your residue() function is computing something (f) that is not returned to
> the calling function. So evalFunction() returns a zero residual and the
> solver stops in one iteration.
Apologies, I am a little confused. The example bratu2d.py imports the
residue function from bratu2dnpy.py and it also does not return anything
(and it works). I was under the impression that
a pointer to `f` is passed to petsc, that overwrites it at each iteration.
Please correct me if I am wrong.
I also tried returning `f` in my residue function but it does not change
anything. Is this what you suggested?
> Mixing numpy arrays and petsc4py vectors is going to be tricky unless you
> know what you are doing. It is simpler to manipulate petsc4py vectors
> directly, see for instance bratu3d.py or other examples.
I have also tried this. I created a petsc vector for the input expected
solution and then converted it into a numpy array using the `getArray`
method. But noting changes.
I also printed some information about the convergence itself. I find
ConvergedReason is 2 (absolute tolerance)
getTolerances is [1e-8, 1e-50, 1e-8, 50] (default)
getErrorIfNotConverged is False
getIterationNumber is 0
In contrast, the convergence reason for the bratu2d example was 3 (relative
tolerance).
I also tried increasing the `max_it` but to no avail.
I appreciate your valuable suggestion and advice in this regard.
Thanks and Regards
Jose
> > El 26 oct 2024, a las 11:11, Vaishak Prasad <vaishakprasad at gmail.com>
> escribió:
> > Hi,
> > Thanks for pointing me to the updated example. The example itself works
> fine.
> > However, on adapting the example to a simple problem ( recovering a
> given 1D vector), I find that there is only one function call happening and
> the solution has not converged. I am attaching the modified example here.
> Is there something silly I am doing here?
> > Any help would be appreciated.
> > Thanks and Regards
> > On Sat, Oct 26, 2024 at 12:42 PM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > The examples in those old slides might be outdated. Try with the
> examples that come with the PETSc repo or tarball. In particular, that
> example can be found in src/binding/petsc4py/demo/legacy/bratu2d/bratu2d.py.
> > Jose
> > > El 25 oct 2024, a las 19:58, Vaishak Prasad <vaishakprasad at gmail.com>
> escribió:
> > > Dear All,
> > > Greetings from India.
> > > I am new to petsc4py. I was trying out the example on slides 18, and
> 19 at
> > > https://urldefense.us/v3/__https://www.bu.edu/pasi/files/2011/01/Lisandro-Dalcin-petsc4py.pdf__;!!G_uCfscf7eWS!bzL5mw0mqx-jt3BIhPqHNtxZUf469dbmQwxugUupECLT7CEMbk_vj-TZ_wEym_uN1O4CWKJKeODMn0a0tO72ky2PkUrV$
> > > However, I get a zero vector for the solution `x`.
> > > I am using petsc4py 3.21.3 on Linux.
> > > With regards
> > > Vaishak Prasad
> > > Post Doctoral Fellow
> > > Astrophysical Relativity Group
> > > International Center for Theoretical Sciences
> > > Tata Institute of Fundamental Research
> > > Survey No. 151, Shivakote, Hesaraghatta Hobli,
> > > Bengaluru, Karnataka, India,
> > > Earth, Solar system,
> > > Milky Way Galaxy, The Local Group
> > Vaishak Prasad
> > <mwe.py>
Vaishak Prasad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241026/d353e401/attachment-0001.html>
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241026/d353e401/attachment-0001.py>
