[petsc-users] Requesting help with SNES non-linear example
Vaishak Prasad
vaishakprasad at gmail.com
Sat Oct 26 04:11:41 CDT 2024
Thanks for pointing me to the updated example. The example itself works
fine.
However, on adapting the example to a simple problem ( recovering a given
1D vector), I find that there is only one function call happening and the
solution has not converged. I am attaching the modified example here. Is
there something silly I am doing here?
Any help would be appreciated.
Thanks and Regards
On Sat, Oct 26, 2024 at 12:42 PM Jose E. Roman <jroman at dsic.upv.es> wrote:
> The examples in those old slides might be outdated. Try with the examples
> that come with the PETSc repo or tarball. In particular, that example can
> be found in src/binding/petsc4py/demo/legacy/bratu2d/bratu2d.py.
> Jose
> > El 25 oct 2024, a las 19:58, Vaishak Prasad <vaishakprasad at gmail.com>
> escribió:
> > Dear All,
> > Greetings from India.
> > I am new to petsc4py. I was trying out the example on slides 18, and 19
> at
> > https://urldefense.us/v3/__https://www.bu.edu/pasi/files/2011/01/Lisandro-Dalcin-petsc4py.pdf__;!!G_uCfscf7eWS!crzDSnMPvGJ19hJ6wP30I5DQnV7XMkJmxebYeLV9MFjpkLL2d5VtXHhHE2si93mzUmxzKxeVo0dkoyx-Cd04hRPUqrAd$
> > However, I get a zero vector for the solution `x`.
> > I am using petsc4py 3.21.3 on Linux.
> > With regards
> > Vaishak Prasad
> > Post Doctoral Fellow
> > Astrophysical Relativity Group
> > International Center for Theoretical Sciences
> > Tata Institute of Fundamental Research
> > Survey No. 151, Shivakote, Hesaraghatta Hobli,
> > Bengaluru, Karnataka, India,
> > Earth, Solar system,
> > Milky Way Galaxy, The Local Group
Vaishak Prasad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241026/249f6c0e/attachment-0001.html>
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241026/249f6c0e/attachment-0001.py>
