[petsc-users] local/global DMPlex Vec output
Matthew Knepley
knepley at gmail.com
Thu Oct 24 18:02:13 CDT 2024
On Thu, Oct 24, 2024 at 6:04 PM Matteo Semplice <
matteo.semplice at uninsubria.it> wrote:
> Hi. The HDF5 solution looks good to me, but I now get this error
> Okay, I can make a workaround for this. Here is what is happening.
When you output solutions, you really want the essential boundary
conditions included in the
output, and the only way I have to do that is for you to tell me about the
discretization, so I
require the DS.
What I can do is ignore this step if there is no DS. Let me do that and
mail you with the branch.
Thanks!
Matt
> $ ../src/saveDemo
> Creating mesh with (10,10) faces
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Need to call DMCreateDS() before calling DMGetDS()
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!dLtO-GGeUrd81R06hiAmfndS-cgZrVE4t8Hipjb8bHTF-vqn1VNb3pjTj5fljYzb6ejXt1QTiLZq1kEPxNH0$ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.21.5, unknown
> [0]PETSC ERROR: ../src/saveDemo on a named dentdherens by matteo Fri Oct
> 25 00:00:44 2024
> [0]PETSC ERROR: Configure options --COPTFLAGS="-O3 -march=native
> -mtune=native -mavx2" --CXXOPTFLAGS="-O3 -march=native -mtune=native
> -mavx2" --FOPTFLAGS="-O3 -march=native -mtune=native -mavx2" --PETSC_ARCH=op
> t --with-strict-petscerrorcode --download-hdf5
> --prefix=/home/matteo/software/petsc/3.21-opt/ --with-debugging=0
> --with-gmsh --with-metis --with-parmetis --with-triangle
> PETSC_DIR=/home/matteo/software/petsc --
> force
> [0]PETSC ERROR: #1 DMGetDS() at
> /home/matteo/software/petsc/src/dm/interface/dm.c:5525
> [0]PETSC ERROR: #2 DMPlexInsertBoundaryValues_Plex() at
> /home/matteo/software/petsc/src/dm/impls/plex/plexfem.c:1136
> [0]PETSC ERROR: #3 DMPlexInsertBoundaryValues() at
> /home/matteo/software/petsc/src/dm/impls/plex/plexfem.c:1274
> [0]PETSC ERROR: #4 VecView_Plex_HDF5_Internal() at
> /home/matteo/software/petsc/src/dm/impls/plex/plexhdf5.c:477
> [0]PETSC ERROR: #5 VecView_Plex() at
> /home/matteo/software/petsc/src/dm/impls/plex/plex.c:656
> [0]PETSC ERROR: #6 VecView() at
> /home/matteo/software/petsc/src/vec/vec/interface/vector.c:806
> [0]PETSC ERROR: #7 main() at saveDemo.cpp:123
> [0]PETSC ERROR: No PETSc Option Table entries
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
> with errorcode 73.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> I attach the modified sample code that produced the above error.
> Thanks
> Matteo
> Il 24/10/24 22:20, Matthew Knepley ha scritto:
> I just looked at the code. The VTK code is very old, and does not check
> for cell overlap.
> We have been recommending that people use either HDF5 or CGNS, both of
> which work in this case
> I believe. I can fix VTK if that is what you want, but it might take me a
> little while as it is very busy at
> work right now. However, if you output HDF5, then you can run
> ./lib/petsc/bin/petsc_gen_xdmf.py mesh.h5
> and it will generate an XDMF file so you can load it into ParaView. Or you
> can output CGNS which I think
> ParaView understands.
> Thanks,
> Matt
> On Thu, Oct 24, 2024 at 4:02 PM Semplice Matteo <
>> Hi,
>> I tried again today and have (re?)discovered this example
>> https://urldefense.us/v3/__https://petsc.org/release/src/dm/impls/plex/tutorials/ex14.c.html__;!!G_uCfscf7eWS!dLtO-GGeUrd81R06hiAmfndS-cgZrVE4t8Hipjb8bHTF-vqn1VNb3pjTj5fljYzb6ejXt1QTiLZq1oOKrq2I$ , but I
>> cannot understand if in my case I should call PetscSFCreateSectionSF
>> <https://urldefense.us/v3/__https://petsc.org/release/manualpages/PetscSF/PetscSFCreateSectionSF/__;!!G_uCfscf7eWS!dLtO-GGeUrd81R06hiAmfndS-cgZrVE4t8Hipjb8bHTF-vqn1VNb3pjTj5fljYzb6ejXt1QTiLZq1jGPN022$ > and,
>> if so, how should I then activate the returned SF.
>> Matteo
>> *Da:* Semplice Matteo
>> *Inviato:* martedì 22 ottobre 2024 00:24
>> *A:* Matthew Knepley <knepley at gmail.com>
>> *Cc:* PETSc <petsc-users at mcs.anl.gov>
>> *Oggetto:* Re: [petsc-users] local/global DMPlex Vec output
>> Dear Matt,
>> I guess you're right: thresholding by rank==0 and rank==1 in paraview
>> reveals that it is indeed the overlap cells that are appear twice in the
>> output.
>> The attached file is not exactly minimal but hopefully short enough. If I
>> run it in serial, all is ok, but with
>> mpirun -np 2 ./saveDemo
>> it creates a 10x10 grid, but I get "output.vtu" with a total of 120
>> cells. However the pointSF of the DMPlex seems correct.
>> Thanks
>> Matteo
>> Il 21/10/24 19:15, Matthew Knepley ha scritto:
>> On Mon, Oct 21, 2024 at 12:22 PM Matteo Semplice via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> Dear petsc-users,
>> I am having issues with output of parallel data attached to a DMPlex
>> (or maybe more fundamental ones about DMPlex...).
>> So I currently
>> 1. create a DMPlex (DMPlexCreateGmshFromFile or DMPlexCreateBoxMesh)
>> 2. partition it
>> 3. and create a section for my data layout with
>> DMPlexCreateSection(ctx.dmMesh, NULL, numComp, numDof, numBC, NULL, NULL,
>> NULL, NULL, &sUavg)
>> 4. DMSetLocalSection(ctx.dmMesh, sUavg)
>> 5. create solLoc and solGlob vectors with DMCreateGlobalVector and
>> DMCreateLocalVector
>> 6. solve ....
>> 7. VecView(ctx.solGlob, vtkViewer) on a .vtu file
>> but when I load data in ParaView I get more cells than expected and it is
>> as if the cells in the halo are put twice in output. (I could create a MWE
>> if the above is not clear)
>> I think we need an MWE here, because from the explanation above, it
>> should work.
>> However, I can try to guess the problem. When you partition the mesh, I
>> am guessing that you have cells in the overlap. These cells
>> must be in the point SF in order for the global section to give them a
>> unique owner. Perhaps something has gone wrong here.
>> Thanks,
>> Matt
>> I guess that the culprit is point (4), but if I replace it with
>> DMSetGlobalSection then I cannot create the local vector at point (5).
>> How should I handle this properly? In my code I need to create both local
>> and global vectors, to perform at least GlobalToLocal and to save the
>> global data.
>> (On a side note, I tried also HDF5 but then it complains about the DM not
>> having a DS...; really, any working solution that allows data to be
>> explored with Paraview is fine)
>> Thanks for any advice!
>> Matteo Semplice
>> experiments lead.
>> -- Norbert Wiener
>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dLtO-GGeUrd81R06hiAmfndS-cgZrVE4t8Hipjb8bHTF-vqn1VNb3pjTj5fljYzb6ejXt1QTiLZq1j7Zbw0Z$
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dLtO-GGeUrd81R06hiAmfndS-cgZrVE4t8Hipjb8bHTF-vqn1VNb3pjTj5fljYzb6ejXt1QTiLZq1o97P_XX$ >
>> Professore Associato in Analisi Numerica
>> Dipartimento di Scienza e Alta Tecnologia
>> Università degli Studi dell'Insubria
>> Via Valleggio, 11 - Como
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dLtO-GGeUrd81R06hiAmfndS-cgZrVE4t8Hipjb8bHTF-vqn1VNb3pjTj5fljYzb6ejXt1QTiLZq1j7Zbw0Z$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dLtO-GGeUrd81R06hiAmfndS-cgZrVE4t8Hipjb8bHTF-vqn1VNb3pjTj5fljYzb6ejXt1QTiLZq1o97P_XX$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241024/b5ba3044/attachment.html>
