[petsc-users] Problem running geoclaw example with petsc 3.22
Praveen C cpraveen at gmail.com
Thu Oct 24 11:17:31 CDT 2024
Hello Barry
I use this script to install clawpack and required dependencies
https://urldefense.us/v3/__https://github.com/cpraveen/cfdlab/blob/master/bin/clawpack.sh__;!!G_uCfscf7eWS!fvuzf9vr_6FD4jbeIajCoXJnAXTzstvxWHD2FAL9lFHroogk1p_mvSk5I20ogPCA3z3OI8jNMbzr3OApoFWW8w$
See lines 125-132
You can use it like this
export CLAW=/path/to/where/you/want/clawpack
bash clawpack.sh v5.11.0
This will git pull clawpack and creates a conda env called “claw” and installs inside that.
I have not specified petsc version in this script, but latest miniforge should install petsc at 3.22
Thank you
praveen
> On 24 Oct 2024, at 9:37 PM, Barry Smith <bsmith at petsc.dev> wrote:
>     Good, some helpful information with the runs you made.
>    In the crash below it made more progress it was able to allocate multiple regions of shared memory and access them. I don't know why it would crash later.
>    Can you tell me all the steps with miniforge (which seems to be related to the failure) you use? I've never used miniforge.
>    If I can get to an environment that reproduces the problem I can debug it and fix it.
>    Barry
>> On Oct 24, 2024, at 11:49 AM, Praveen C <cpraveen at gmail.com> wrote:
>> I get this
>> $ mpiexec -n 3 ./ex89f  -n 20 -mpi_linear_solver_server -mpi_linear_solver_server -mpi_linear_solver_server_ksp_view -ksp_monitor -ksp_converged_reason -ksp_view  -mpi_linear_solver_server_minimum_count_per_rank 5
>> [0]PETSC ERROR: ------------------------------------------------------------------------
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see https://urldefense.us/v3/__https://petsc.org/release/faq/*valgrind__;Iw!!G_uCfscf7eWS!fvuzf9vr_6FD4jbeIajCoXJnAXTzstvxWHD2FAL9lFHroogk1p_mvSk5I20ogPCA3z3OI8jNMbzr3OAkxkT2HQ$  and https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fvuzf9vr_6FD4jbeIajCoXJnAXTzstvxWHD2FAL9lFHroogk1p_mvSk5I20ogPCA3z3OI8jNMbzr3ODvXnLz2A$
>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>> [0]PETSC ERROR: to get more information on the crash.
>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
>>   Proc: [[47380,1],0]
>>   Errorcode: 59
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> prterun has exited due to process rank 0 with PID 0 on node MacMiniHome calling
>> "abort". This may have caused other processes in the application to be
>> terminated by signals sent by prterun (as reported here).
>> and I have this after the code exits
>> $ ipcs -m
>> IPC status from <running system> as of Thu Oct 24 21:17:39 IST 2024
>> T     ID     KEY        MODE       OWNER    GROUP
>> Shared Memory:
>> m 1572864 0x0000000b --rw-rw-rw-  praveen    staff
>> m 524289 0x0000000c --rw-rw-rw-  praveen    staff
>> m 655362 0x0000000d --rw-rw-rw-  praveen    staff
>> m 262147 0x0000000e --rw-rw-rw-  praveen    staff
>> m 262148 0x0000000f --rw-rw-rw-  praveen    staff
>> m 393221 0x0000000a --rw-rw-rw-  praveen    staff
>> This is with petsc installed with miniforge, which I also use with clawpack. With spack installed petsc, I can run the ex89f example.
>> Thanks
>> praveen
>>> On 24 Oct 2024, at 7:55 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>>    Ok, super strange, I've run many times on my Mac
>>>    Can you please try to remove that allocated memory with ipcrm and then
>>>    cd $PETSC_DIR/src/ksp/ksp/tutorials
>>>    make ex89f
>>>   This does the same thing as the GeoClaw code but is much simpler.
>>>    Barry
>>>> On Oct 23, 2024, at 10:55 PM, Praveen C <cpraveen at gmail.com> wrote:
>>>> I get very similar error on my mac with
>>>> $ gfortran -v
>>>> Using built-in specs.
>>>> COLLECT_GCC=gfortran
>>>> COLLECT_LTO_WRAPPER=/opt/homebrew/Caskroom/miniforge/base/envs/claw/libexec/gcc/arm64-apple-darwin20.0.0/13.2.0/lto-wrapper
>>>> Target: arm64-apple-darwin20.0.0
>>>> Configured with: ../configure --prefix=/opt/homebrew/Caskroom/miniforge/base/envs/claw --build=x86_64-apple-darwin13.4.0 --host=arm64-apple-darwin20.0.0 --target=arm64-apple-darwin20.0.0 --with-libiconv-prefix=/opt/homebrew/Caskroom/miniforge/base/envs/claw --enable-languages=fortran --disable-multilib --enable-checking=release --disable-bootstrap --disable-libssp --with-gmp=/opt/homebrew/Caskroom/miniforge/base/envs/claw --with-mpfr=/opt/homebrew/Caskroom/miniforge/base/envs/claw --with-mpc=/opt/homebrew/Caskroom/miniforge/base/envs/claw --with-isl=/opt/homebrew/Caskroom/miniforge/base/envs/claw --enable-darwin-at-rpath
>>>> Thread model: posix
>>>> Supported LTO compression algorithms: zlib
>>>> gcc version 13.2.0 (GCC)
>>>> Before starting
>>>> $ ipcs -m
>>>> IPC status from <running system> as of Thu Oct 24 08:02:11 IST 2024
>>>> Shared Memory:
>>>> and when I run the code
>>>>  Using a PETSc solver
>>>>  Using Bouss equations from the start
>>>>  rnode allocated...
>>>>  node allocated...
>>>>  listOfGrids allocated...
>>>>  Storage allocated...
>>>>  bndList allocated...
>>>> Gridding level   1 at t =  0.000000E+00:     4 grids with       10000 cells
>>>>    Setting initial dt to    2.9999999999999999E-002
>>>>   max threads set to            1
>>>>  Done reading data, starting computation ...
>>>>  Total zeta at initial time:    39269.907650665169
>>>> GEOCLAW: Frame    0 output files done at time t =  0.000000D+00
>>>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>>> [0]PETSC ERROR: Unable to locate PCMPI allocated shared address 0x130698000
>>>> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
>>>> [0]PETSC ERROR:   Option left: name:-ksp_type value: preonly source: file
>>>> [0]PETSC ERROR:   Option left: name:-mpi_ksp_max_it value: 200 source: file
>>>> [0]PETSC ERROR:   Option left: name:-mpi_ksp_reuse_preconditioner (no value) source: file
>>>> [0]PETSC ERROR:   Option left: name:-mpi_ksp_rtol value: 1.e-9 source: file
>>>> [0]PETSC ERROR:   Option left: name:-mpi_ksp_type value: gmres source: file
>>>> [0]PETSC ERROR:   Option left: name:-mpi_linear_solver_server_view (no value) source: file
>>>> [0]PETSC ERROR:   Option left: name:-mpi_pc_gamg_sym_graph value: true source: file
>>>> [0]PETSC ERROR:   Option left: name:-mpi_pc_gamg_symmetrize_graph value: true source: file
>>>> [0]PETSC ERROR:   Option left: name:-mpi_pc_type value: gamg source: file
>>>> [0]PETSC ERROR:   Option left: name:-pc_mpi_minimum_count_per_rank value: 5000 source: file
>>>> [0]PETSC ERROR:   Option left: name:-pc_type value: mpi source: file
>>>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fvuzf9vr_6FD4jbeIajCoXJnAXTzstvxWHD2FAL9lFHroogk1p_mvSk5I20ogPCA3z3OI8jNMbzr3ODvXnLz2A$  for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.22.0, Sep 28, 2024
>>>> [0]PETSC ERROR: /Users/praveen/work/bouss/radial_flat/xgeoclaw with 6 MPI process(es) and PETSC_ARCH  on MacMiniHome.local by praveen Thu Oct 24 08:04:27 2024
>>>> [0]PETSC ERROR: Configure options: AR=arm64-apple-darwin20.0.0-ar CC=mpicc CXX=mpicxx FC=mpifort CFLAGS="-ftree-vectorize -fPIC -fstack-protector-strong -O2 -pipe -isystem /opt/homebrew/Caskroom/miniforge/base/envs/claw/include  " CPPFLAGS="-D_FORTIFY_SOURCE=2 -isystem /opt/homebrew/Caskroom/miniforge/base/envs/claw/include -mmacosx-version-min=11.0 -mmacosx-version-min=11.0" CXXFLAGS="-ftree-vectorize -fPIC -fstack-protector-strong -O2 -pipe -stdlib=libc++ -fvisibility-inlines-hidden -fmessage-length=0 -isystem /opt/homebrew/Caskroom/miniforge/base/envs/claw/include  " FFLAGS="-march=armv8.3-a -ftree-vectorize -fPIC -fno-stack-protector -O2 -pipe -isystem /opt/homebrew/Caskroom/miniforge/base/envs/claw/include  " LDFLAGS="-Wl,-headerpad_max_install_names -Wl,-dead_strip_dylibs -Wl,-rpath,/opt/homebrew/Caskroom/miniforge/base/envs/claw/lib -L/opt/homebrew/Caskroom/miniforge/base/envs/claw/lib" LIBS="-Wl,-rpath,/opt/homebrew/Caskroom/miniforge/base/envs/claw/lib -lmpi_mpifh -lgfortran" --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-clib-autodetect=0 --with-cxxlib-autodetect=0 --with-fortranlib-autodetect=0 --with-debugging=0 --with-blas-lib=libblas.dylib --with-lapack-lib=liblapack.dylib --with-yaml=1 --with-hdf5=1 --with-fftw=1 --with-hwloc=0 --with-hypre=1 --with-metis=1 --with-mpi=1 --with-mumps=1 --with-parmetis=1 --with-pthread=1 --with-ptscotch=1 --with-shared-libraries --with-ssl=0 --with-scalapack=1 --with-superlu=1 --with-superlu_dist=1 --with-superlu_dist-include=/opt/homebrew/Caskroom/miniforge/base/envs/claw/include/superlu-dist --with-superlu_dist-lib=-lsuperlu_dist --with-suitesparse=1 --with-suitesparse-dir=/opt/homebrew/Caskroom/miniforge/base/envs/claw --with-x=0 --with-scalar-type=real   --with-cuda=0 --with-batch --prefix=/opt/homebrew/Caskroom/miniforge/base/envs/claw
>>>> [0]PETSC ERROR: #1 PetscShmgetMapAddresses() at /Users/runner/miniforge3/conda-bld/petsc_1728030427805/work/src/sys/utils/server.c:114
>>>> [0]PETSC ERROR: #2 PCMPISetMat() at /Users/runner/miniforge3/conda-bld/petsc_1728030427805/work/src/ksp/pc/impls/mpi/pcmpi.c:269
>>>> [0]PETSC ERROR: #3 PCSetUp_MPI() at /Users/runner/miniforge3/conda-bld/petsc_1728030427805/work/src/ksp/pc/impls/mpi/pcmpi.c:853
>>>> [0]PETSC ERROR: #4 PCSetUp() at /Users/runner/miniforge3/conda-bld/petsc_1728030427805/work/src/ksp/pc/interface/precon.c:1071
>>>> [0]PETSC ERROR: #5 KSPSetUp() at /Users/runner/miniforge3/conda-bld/petsc_1728030427805/work/src/ksp/ksp/interface/itfunc.c:415
>>>> [0]PETSC ERROR: #6 KSPSolve_Private() at /Users/runner/miniforge3/conda-bld/petsc_1728030427805/work/src/ksp/ksp/interface/itfunc.c:826
>>>> [0]PETSC ERROR: #7 KSPSolve() at /Users/runner/miniforge3/conda-bld/petsc_1728030427805/work/src/ksp/ksp/interface/itfunc.c:1075
>>>> Code does not progress and I kill it
>>>> ^CTraceback (most recent call last):
>>>>   File "/Users/praveen/Applications/clawpack/clawutil/src/python/clawutil/runclaw.py", line 341, in <module>
>>>>     runclaw(*args)
>>>>   File "/Users/praveen/Applications/clawpack/clawutil/src/python/clawutil/runclaw.py", line 242, in runclaw
>>>>     proc = subprocess.check_call(cmd_split,
>>>>   File "/opt/homebrew/Caskroom/miniforge/base/envs/claw/lib/python3.12/subprocess.py", line 408, in check_call
>>>>     retcode = call(*popenargs, **kwargs)
>>>>   File "/opt/homebrew/Caskroom/miniforge/base/envs/claw/lib/python3.12/subprocess.py", line 391, in call
>>>>     return p.wait(timeout=timeout)
>>>>   File "/opt/homebrew/Caskroom/miniforge/base/envs/claw/lib/python3.12/subprocess.py", line 1264, in wait
>>>>     return self._wait(timeout=timeout)
>>>>   File "/opt/homebrew/Caskroom/miniforge/base/envs/claw/lib/python3.12/subprocess.py", line 2053, in _wait
>>>>     (pid, sts) = self._try_wait(0)
>>>>   File "/opt/homebrew/Caskroom/miniforge/base/envs/claw/lib/python3.12/subprocess.py", line 2011, in _try_wait
>>>>     (pid, sts) = os.waitpid(self.pid, wait_flags)
>>>> KeyboardInterrupt
>>>> make[1]: *** [output] Interrupt: 2
>>>> make: *** [.output] Interrupt: 2
>>>> Now it says
>>>> $ ipcs -m
>>>> IPC status from <running system> as of Thu Oct 24 08:05:06 IST 2024
>>>> Shared Memory:
>>>> m 720896 0x0000000a --rw-rw-rw-  praveen    staff
>>>> Thanks
>>>> praveen
>>>>> On 23 Oct 2024, at 8:26 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>>>>    Hmm,  so it is creating the first shared memory region with ID of 10 (A in hex) puts it in a linked list in PETSc but then when it tries to find it in the linked list it cannot find it.
>>>>>    I don't know how to reproduce this or debug it remotely.
>>>>>     Can you build on a completely different machine or with completely different compilers?
>>>>>    Barry
>>>>>> On Oct 23, 2024, at 10:31 AM, Praveen C <cpraveen at gmail.com> wrote:
>>>>>> I get same error and now it shows
>>>>>> $ ipcs -m
>>>>>> ------ Shared Memory Segments --------
>>>>>> key        shmid      owner      perms      bytes      nattch     status
>>>>>> 0x0000000a 32788      praveen    666        240        6
>>>>>> Note that the code seems to be still running after printing those error message, but it is not printing any progress which it should do.
>>>>>> Thanks
>>>>>> praveen
>>>>>>> On 23 Oct 2024, at 7:56 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>>    Try
>>>>>>> ipcrm -m 11
>>>>>>> ipcs -m
>>>>>>> Try running the program again
>>>>>>> If failed check
>>>>>>> ipcs -m
>>>>>>> again
>>>>>>>> On Oct 23, 2024, at 10:20 AM, Praveen C <cpraveen at gmail.com> wrote:
>>>>>>>> Hello Barry
>>>>>>>> I see this
>>>>>>>> $ ipcs -m
>>>>>>>> 0x0000000a 11         praveen    666        240        6
>>>>>>>> and I am observing same error as below.
>>>>>>>> Thanks
>>>>>>>> praveen
>>>>>>>>> On 23 Oct 2024, at 7:08 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>>>>   Please take a look at the notes in https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscShmgetAllocateArray/__;!!G_uCfscf7eWS!fvuzf9vr_6FD4jbeIajCoXJnAXTzstvxWHD2FAL9lFHroogk1p_mvSk5I20ogPCA3z3OI8jNMbzr3OD4MyLSQw$   For some reason your program is not able to access/use the Unix shared memory; check if you are already using the shared memory (so it is not available for a new run) or the limits are too low to access enough memory.
>>>>>>>>>    Barry
>>>>>>>>>> On Oct 23, 2024, at 8:23 AM, Praveen C <cpraveen at gmail.com> wrote:
>>>>>>>>>> Dear all
>>>>>>>>>> I am not able to run the boussinesq example from geoclaw using petsc at 3.22.0
>>>>>>>>>> https://urldefense.us/v3/__https://github.com/clawpack/geoclaw/tree/3303883f46572c58130d161986b8a87a57ca7816/examples/bouss__;!!G_uCfscf7eWS!e3VQ4NHKmXGstRsQW5vtI7fmKfUT9zmJkMJcPbcvPyIjicyfJpNoMgx3wZ-qyGcKNSjIkNZkzilec8MnHN6PMw$
>>>>>>>>>> It runs with petsc at 3.21.6
>>>>>>>>>> The error I get is given below. After printing this, the code does not progress.
>>>>>>>>>> I use the following petsc options
>>>>>>>>>> # set min numbers of matrix rows per MPI rank  (default is 10000)
>>>>>>>>>> -mpi_linear_solve_minimum_count_per_rank 5000
>>>>>>>>>> # Krylov linear solver:
>>>>>>>>>> -ksp_type gmres
>>>>>>>>>> -ksp_max_it 200
>>>>>>>>>> -ksp_reuse_preconditioner
>>>>>>>>>> -ksp_rtol 1.e-9
>>>>>>>>>> # preconditioner:
>>>>>>>>>> -pc_type gamg
>>>>>>>>>> I installed petsc and other dependencies for clawpack using miniforge.
>>>>>>>>>> Thanks
>>>>>>>>>> pc
>>>>>>>>>> ==> Use Bouss. in water deeper than    1.0000000000000000       Using a PETSc solver
>>>>>>>>>> rnode allocated...
>>>>>>>>>> node allocated...
>>>>>>>>>> max threads set to            6
>>>>>>>>>>   Done reading data, starting computation ...       Total zeta at initial time:    39269.907650665169      GEOCLAW: Frame    0 output files done at time t =  0.000000D+00
>>>>>>>>>> [0]PETSC ERROR: Unable to locate PCMPI allocated shared address 0x55e6d750ae20
>>>>>>>>>> [0]PETSC ERROR:   Option left: name:-ksp_max_it value: 200 source: file
>>>>>>>>>> [0]PETSC ERROR:   Option left: name:-ksp_reuse_preconditioner (no value) source: file
>>>>>>>>>> [0]PETSC ERROR:   Option left: name:-ksp_rtol value: 1.e-9 source: file
>>>>>>>>>> [0]PETSC ERROR:   Option left: name:-ksp_type value: gmres source: file
>>>>>>>>>> [0]PETSC ERROR:   Option left: name:-mpi_linear_solve_minimum_count_per_rank value: 5000 source: file
>>>>>>>>>> [0]PETSC ERROR:   Option left: name:-pc_type value: gamg source: file
>>>>>>>>>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!e3VQ4NHKmXGstRsQW5vtI7fmKfUT9zmJkMJcPbcvPyIjicyfJpNoMgx3wZ-qyGcKNSjIkNZkzilec8MvNjNo7A$  for trouble shooting.
>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.22.0, Sep 28, 2024  [0]PETSC ERROR: /home/praveen/bouss/radial_flat/xgeoclaw with 6 MPI process(es) and PETSC_ARCH  on euler by praveen Thu Oct 17 21:49:54 2024
>>>>>>>>>> [0]PETSC ERROR: Configure options: AR=${PREFIX}/bin/x86_64-conda-linux-gnu-ar CC=mpicc CXX=mpicxx FC=mpifort CFLAGS="-march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /opt/miniforge/envs/claw/include  " CPPFLAGS="-DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /opt/miniforge/envs/claw/include" CXXFLAGS="-fvisibility-inlines-hidden -fmessage-length=0 -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /opt/miniforge/envs/claw/include  " FFLAGS="-march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /opt/miniforge/envs/claw/include   -Wl,--no-as-needed" LDFLAGS="-pthread -fopenmp -Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,--disable-new-dtags -Wl,--gc-sections -Wl,--allow-shlib-undefined -Wl,-rpath,/opt/miniforge/envs/claw/lib -Wl,-rpath-link,/opt/miniforge/envs/claw/lib -L/opt/miniforge/envs/claw/lib -Wl,-rpath-link,/opt/miniforge/envs/claw/lib" LIBS="-Wl,-rpath,/opt/miniforge/envs/claw/lib -lmpi_mpifh -lgfortran" --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-clib-autodetect=0 --with-cxxlib-autodetect=0 --with-fortranlib-autodetect=0 --with-debugging=0 --with-blas-lib=libblas.so --with-lapack-lib=liblapack.so --with-yaml=1 --with-hdf5=1 --with-fftw=1 --with-hwloc=0 --with-hypre=1 --with-metis=1 --with-mpi=1 --with-mumps=1 --with-parmetis=1 --with-pthread=1 --with-ptscotch=1 --with-shared-libraries --with-ssl=0 --with-scalapack=1 --with-superlu=1 --with-superlu_dist=1 --with-superlu_dist-include=/opt/miniforge/envs/claw/include/superlu-dist --with-superlu_dist-lib=-lsuperlu_dist --with-suitesparse=1 --with-suitesparse-dir=/opt/miniforge/envs/claw --with-x=0 --with-scalar-type=real   --with-cuda=0 --prefix=/opt/miniforge/envs/claw
>>>>>>>>>> [0]PETSC ERROR: #1 PetscShmgetMapAddresses() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/sys/utils/server.c:114
>>>>>>>>>> [0]PETSC ERROR: #2 PCMPISetMat() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/pc/impls/mpi/pcmpi.c:269
>>>>>>>>>> [0]PETSC ERROR: #3 PCSetUp_MPI() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/pc/impls/mpi/pcmpi.c:853
>>>>>>>>>> [0]PETSC ERROR: #4 PCSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/pc/interface/precon.c:1071
>>>>>>>>>> [0]PETSC ERROR: #5 KSPSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/ksp/interface/itfunc.c:415
>>>>>>>>>> [0]PETSC ERROR: #6 KSPSolve_Private() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/ksp/interface/itfunc.c:826
>>>>>>>>>> [0]PETSC ERROR: #7 KSPSolve() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/ksp/interface/itfunc.c:1075
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241024/94213371/attachment-0001.html>
