[petsc-users] Problem running geoclaw example with petsc 3.22
Praveen C
cpraveen at gmail.com
Wed Oct 23 09:31:00 CDT 2024
I get same error and now it shows
$ ipcs -m
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x0000000a 32788 praveen 666 240 6
Note that the code seems to be still running after printing those error message, but it is not printing any progress which it should do.
Thanks
praveen
> On 23 Oct 2024, at 7:56 PM, Barry Smith <bsmith at petsc.dev> wrote:
> Try
> ipcrm -m 11
> ipcs -m
> Try running the program again
> If failed check
> ipcs -m
> again
>> On Oct 23, 2024, at 10:20 AM, Praveen C <cpraveen at gmail.com> wrote:
>> Hello Barry
>> I see this
>> $ ipcs -m
>> 0x0000000a 11 praveen 666 240 6
>> and I am observing same error as below.
>> Thanks
>> praveen
>>> On 23 Oct 2024, at 7:08 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>> Please take a look at the notes in https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscShmgetAllocateArray/__;!!G_uCfscf7eWS!fpsbNP5z6XCWQ6tD3oyfDrMPZn-6CqXz9A-Lqv4A0-ss21oyjEdcRNGSEw8Kl1XFP9QBS7Iz3yheqkQrhkRkEg$ For some reason your program is not able to access/use the Unix shared memory; check if you are already using the shared memory (so it is not available for a new run) or the limits are too low to access enough memory.
>>> Barry
>>>> On Oct 23, 2024, at 8:23 AM, Praveen C <cpraveen at gmail.com> wrote:
>>>> Dear all
>>>> I am not able to run the boussinesq example from geoclaw using petsc at 3.22.0
>>>> https://urldefense.us/v3/__https://github.com/clawpack/geoclaw/tree/3303883f46572c58130d161986b8a87a57ca7816/examples/bouss__;!!G_uCfscf7eWS!e3VQ4NHKmXGstRsQW5vtI7fmKfUT9zmJkMJcPbcvPyIjicyfJpNoMgx3wZ-qyGcKNSjIkNZkzilec8MnHN6PMw$
>>>> It runs with petsc at 3.21.6
>>>> The error I get is given below. After printing this, the code does not progress.
>>>> I use the following petsc options
>>>> # set min numbers of matrix rows per MPI rank (default is 10000)
>>>> -mpi_linear_solve_minimum_count_per_rank 5000
>>>> # Krylov linear solver:
>>>> -mpi_linear_solver_server
>>>> -mpi_linear_solver_server_view
>>>> -ksp_type gmres
>>>> -ksp_max_it 200
>>>> -ksp_reuse_preconditioner
>>>> -ksp_rtol 1.e-9
>>>> # preconditioner:
>>>> -pc_type gamg
>>>> I installed petsc and other dependencies for clawpack using miniforge.
>>>> Thanks
>>>> pc
>>>> ==> Use Bouss. in water deeper than 1.0000000000000000 Using a PETSc solver
>>>> Using Bouss equations from the start
>>>> rnode allocated...
>>>> node allocated...
>>>> listOfGrids allocated...
>>>> Storage allocated...
>>>> bndList allocated...
>>>> Gridding level 1 at t = 0.000000E+00: 4 grids with 10000 cells
>>>> Setting initial dt to 2.9999999999999999E-002
>>>> max threads set to 6
>>>> Done reading data, starting computation ... Total zeta at initial time: 39269.907650665169 GEOCLAW: Frame 0 output files done at time t = 0.000000D+00
>>>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>>> [0]PETSC ERROR: Unable to locate PCMPI allocated shared address 0x55e6d750ae20
>>>> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
>>>> [0]PETSC ERROR: Option left: name:-ksp_max_it value: 200 source: file
>>>> [0]PETSC ERROR: Option left: name:-ksp_reuse_preconditioner (no value) source: file
>>>> [0]PETSC ERROR: Option left: name:-ksp_rtol value: 1.e-9 source: file
>>>> [0]PETSC ERROR: Option left: name:-ksp_type value: gmres source: file
>>>> [0]PETSC ERROR: Option left: name:-mpi_linear_solve_minimum_count_per_rank value: 5000 source: file
>>>> [0]PETSC ERROR: Option left: name:-mpi_linear_solver_server_view (no value) source: file
>>>> [0]PETSC ERROR: Option left: name:-pc_type value: gamg source: file
>>>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!e3VQ4NHKmXGstRsQW5vtI7fmKfUT9zmJkMJcPbcvPyIjicyfJpNoMgx3wZ-qyGcKNSjIkNZkzilec8MvNjNo7A$ for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.22.0, Sep 28, 2024 [0]PETSC ERROR: /home/praveen/bouss/radial_flat/xgeoclaw with 6 MPI process(es) and PETSC_ARCH on euler by praveen Thu Oct 17 21:49:54 2024
>>>> [0]PETSC ERROR: Configure options: AR=${PREFIX}/bin/x86_64-conda-linux-gnu-ar CC=mpicc CXX=mpicxx FC=mpifort CFLAGS="-march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /opt/miniforge/envs/claw/include " CPPFLAGS="-DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /opt/miniforge/envs/claw/include" CXXFLAGS="-fvisibility-inlines-hidden -fmessage-length=0 -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /opt/miniforge/envs/claw/include " FFLAGS="-march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /opt/miniforge/envs/claw/include -Wl,--no-as-needed" LDFLAGS="-pthread -fopenmp -Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,--disable-new-dtags -Wl,--gc-sections -Wl,--allow-shlib-undefined -Wl,-rpath,/opt/miniforge/envs/claw/lib -Wl,-rpath-link,/opt/miniforge/envs/claw/lib -L/opt/miniforge/envs/claw/lib -Wl,-rpath-link,/opt/miniforge/envs/claw/lib" LIBS="-Wl,-rpath,/opt/miniforge/envs/claw/lib -lmpi_mpifh -lgfortran" --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-clib-autodetect=0 --with-cxxlib-autodetect=0 --with-fortranlib-autodetect=0 --with-debugging=0 --with-blas-lib=libblas.so --with-lapack-lib=liblapack.so --with-yaml=1 --with-hdf5=1 --with-fftw=1 --with-hwloc=0 --with-hypre=1 --with-metis=1 --with-mpi=1 --with-mumps=1 --with-parmetis=1 --with-pthread=1 --with-ptscotch=1 --with-shared-libraries --with-ssl=0 --with-scalapack=1 --with-superlu=1 --with-superlu_dist=1 --with-superlu_dist-include=/opt/miniforge/envs/claw/include/superlu-dist --with-superlu_dist-lib=-lsuperlu_dist --with-suitesparse=1 --with-suitesparse-dir=/opt/miniforge/envs/claw --with-x=0 --with-scalar-type=real --with-cuda=0 --prefix=/opt/miniforge/envs/claw
>>>> [0]PETSC ERROR: #1 PetscShmgetMapAddresses() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/sys/utils/server.c:114
>>>> [0]PETSC ERROR: #2 PCMPISetMat() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/pc/impls/mpi/pcmpi.c:269
>>>> [0]PETSC ERROR: #3 PCSetUp_MPI() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/pc/impls/mpi/pcmpi.c:853
>>>> [0]PETSC ERROR: #4 PCSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/pc/interface/precon.c:1071
>>>> [0]PETSC ERROR: #5 KSPSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/ksp/interface/itfunc.c:415
>>>> [0]PETSC ERROR: #6 KSPSolve_Private() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/ksp/interface/itfunc.c:826
>>>> [0]PETSC ERROR: #7 KSPSolve() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/ksp/interface/itfunc.c:1075
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241023/88c72f92/attachment-0001.html>
