[petsc-users] Problem running geoclaw example with petsc 3.22
    Praveen C
    cpraveen at gmail.com
    Wed Oct 23 09:20:13 CDT 2024
Hello Barry
I see this
$ ipcs -m
------ Shared Memory Segments --------
key        shmid      owner      perms      bytes      nattch     status
0x0000000a 11         praveen    666        240        6
and I am observing same error as below.
Thanks
praveen
> On 23 Oct 2024, at 7:08 PM, Barry Smith <bsmith at petsc.dev> wrote:
>   Please take a look at the notes in https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscShmgetAllocateArray/__;!!G_uCfscf7eWS!aV1t0ykXK5XZXD7-BJX9A_zGNHNR8THmsF66BnZkVDiDJF0FKfSG354RNSvXarj4iea2kTc7lgzUzX55rI7bsw$   For some reason your program is not able to access/use the Unix shared memory; check if you are already using the shared memory (so it is not available for a new run) or the limits are too low to access enough memory.
>    Barry
>> On Oct 23, 2024, at 8:23 AM, Praveen C <cpraveen at gmail.com> wrote:
>> Dear all
>> I am not able to run the boussinesq example from geoclaw using petsc at 3.22.0
>> https://urldefense.us/v3/__https://github.com/clawpack/geoclaw/tree/3303883f46572c58130d161986b8a87a57ca7816/examples/bouss__;!!G_uCfscf7eWS!e3VQ4NHKmXGstRsQW5vtI7fmKfUT9zmJkMJcPbcvPyIjicyfJpNoMgx3wZ-qyGcKNSjIkNZkzilec8MnHN6PMw$
>> It runs with petsc at 3.21.6
>> The error I get is given below. After printing this, the code does not progress.
>> I use the following petsc options
>> # set min numbers of matrix rows per MPI rank  (default is 10000)
>> -mpi_linear_solve_minimum_count_per_rank 5000
>> # Krylov linear solver:
>> -mpi_linear_solver_server
>> -mpi_linear_solver_server_view
>> -ksp_type gmres
>> -ksp_max_it 200
>> -ksp_reuse_preconditioner
>> -ksp_rtol 1.e-9
>> # preconditioner:
>> -pc_type gamg
>> I installed petsc and other dependencies for clawpack using miniforge.
>> Thanks
>> pc
>> ==> Use Bouss. in water deeper than    1.0000000000000000       Using a PETSc solver
>> Using Bouss equations from the start
>> rnode allocated...
>> node allocated...
>> listOfGrids allocated...
>> Storage allocated...
>> bndList allocated...
>> Gridding level   1 at t =  0.000000E+00:     4 grids with       10000 cells
>>  Setting initial dt to    2.9999999999999999E-002
>> max threads set to            6
>>   Done reading data, starting computation ...       Total zeta at initial time:    39269.907650665169      GEOCLAW: Frame    0 output files done at time t =  0.000000D+00
>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>> [0]PETSC ERROR: Petsc has generated inconsistent data
>> [0]PETSC ERROR: Unable to locate PCMPI allocated shared address 0x55e6d750ae20
>> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
>> [0]PETSC ERROR:   Option left: name:-ksp_max_it value: 200 source: file
>> [0]PETSC ERROR:   Option left: name:-ksp_reuse_preconditioner (no value) source: file
>> [0]PETSC ERROR:   Option left: name:-ksp_rtol value: 1.e-9 source: file
>> [0]PETSC ERROR:   Option left: name:-ksp_type value: gmres source: file
>> [0]PETSC ERROR:   Option left: name:-mpi_linear_solve_minimum_count_per_rank value: 5000 source: file
>> [0]PETSC ERROR:   Option left: name:-mpi_linear_solver_server_view (no value) source: file
>> [0]PETSC ERROR:   Option left: name:-pc_type value: gamg source: file
>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!e3VQ4NHKmXGstRsQW5vtI7fmKfUT9zmJkMJcPbcvPyIjicyfJpNoMgx3wZ-qyGcKNSjIkNZkzilec8MvNjNo7A$  for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.22.0, Sep 28, 2024  [0]PETSC ERROR: /home/praveen/bouss/radial_flat/xgeoclaw with 6 MPI process(es) and PETSC_ARCH  on euler by praveen Thu Oct 17 21:49:54 2024
>> [0]PETSC ERROR: Configure options: AR=${PREFIX}/bin/x86_64-conda-linux-gnu-ar CC=mpicc CXX=mpicxx FC=mpifort CFLAGS="-march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /opt/miniforge/envs/claw/include  " CPPFLAGS="-DNDEBUG -D_FORTIFY_SOURCE=2 -O2 -isystem /opt/miniforge/envs/claw/include" CXXFLAGS="-fvisibility-inlines-hidden -fmessage-length=0 -march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /opt/miniforge/envs/claw/include  " FFLAGS="-march=nocona -mtune=haswell -ftree-vectorize -fPIC -fstack-protector-strong -fno-plt -O2 -ffunction-sections -pipe -isystem /opt/miniforge/envs/claw/include   -Wl,--no-as-needed" LDFLAGS="-pthread -fopenmp -Wl,-O2 -Wl,--sort-common -Wl,--as-needed -Wl,-z,relro -Wl,-z,now -Wl,--disable-new-dtags -Wl,--gc-sections -Wl,--allow-shlib-undefined -Wl,-rpath,/opt/miniforge/envs/claw/lib -Wl,-rpath-link,/opt/miniforge/envs/claw/lib -L/opt/miniforge/envs/claw/lib -Wl,-rpath-link,/opt/miniforge/envs/claw/lib" LIBS="-Wl,-rpath,/opt/miniforge/envs/claw/lib -lmpi_mpifh -lgfortran" --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-clib-autodetect=0 --with-cxxlib-autodetect=0 --with-fortranlib-autodetect=0 --with-debugging=0 --with-blas-lib=libblas.so --with-lapack-lib=liblapack.so --with-yaml=1 --with-hdf5=1 --with-fftw=1 --with-hwloc=0 --with-hypre=1 --with-metis=1 --with-mpi=1 --with-mumps=1 --with-parmetis=1 --with-pthread=1 --with-ptscotch=1 --with-shared-libraries --with-ssl=0 --with-scalapack=1 --with-superlu=1 --with-superlu_dist=1 --with-superlu_dist-include=/opt/miniforge/envs/claw/include/superlu-dist --with-superlu_dist-lib=-lsuperlu_dist --with-suitesparse=1 --with-suitesparse-dir=/opt/miniforge/envs/claw --with-x=0 --with-scalar-type=real   --with-cuda=0 --prefix=/opt/miniforge/envs/claw
>> [0]PETSC ERROR: #1 PetscShmgetMapAddresses() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/sys/utils/server.c:114
>> [0]PETSC ERROR: #2 PCMPISetMat() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/pc/impls/mpi/pcmpi.c:269
>> [0]PETSC ERROR: #3 PCSetUp_MPI() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/pc/impls/mpi/pcmpi.c:853
>> [0]PETSC ERROR: #4 PCSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/pc/interface/precon.c:1071
>> [0]PETSC ERROR: #5 KSPSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/ksp/interface/itfunc.c:415
>> [0]PETSC ERROR: #6 KSPSolve_Private() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/ksp/interface/itfunc.c:826
>> [0]PETSC ERROR: #7 KSPSolve() at /home/conda/feedstock_root/build_artifacts/petsc_1728030599661/work/src/ksp/ksp/interface/itfunc.c:1075
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241023/63d18152/attachment.html>
