[petsc-users] local/global DMPlex Vec output
Matteo Semplice
matteo.semplice at uninsubria.it
Mon Oct 21 17:24:25 CDT 2024
Dear Matt,
I guess you're right: thresholding by rank==0 and rank==1 in
paraview reveals that it is indeed the overlap cells that are appear
twice in the output.
The attached file is not exactly minimal but hopefully short enough. If
I run it in serial, all is ok, but with
mpirun -np 2 ./saveDemo
it creates a 10x10 grid, but I get "output.vtu" with a total of 120
cells. However the pointSF of the DMPlex seems correct.
Thanks
Matteo
Il 21/10/24 19:15, Matthew Knepley ha scritto:
> On Mon, Oct 21, 2024 at 12:22 PM Matteo Semplice via petsc-users
> <petsc-users at mcs.anl.gov> wrote:
> Dear petsc-users,
> I am having issues with output of parallel data attached to a
> DMPlex (or maybe more fundamental ones about DMPlex...).
> So I currently
> 1. create a DMPlex (DMPlexCreateGmshFromFile or DMPlexCreateBoxMesh)
> 2. partition it
> 3. and create a section for my data layout with
> DMPlexCreateSection(ctx.dmMesh, NULL, numComp, numDof, numBC,
> NULL, NULL, NULL, NULL, &sUavg)
> 4. DMSetLocalSection(ctx.dmMesh, sUavg)
> 5. create solLoc and solGlob vectors with DMCreateGlobalVector
> and DMCreateLocalVector
> 6. solve ....
> 7. VecView(ctx.solGlob, vtkViewer) on a .vtu file
> but when I load data in ParaView I get more cells than expected
> and it is as if the cells in the halo are put twice in output. (I
> could create a MWE if the above is not clear)
> I think we need an MWE here, because from the explanation above, it
> should work.
> However, I can try to guess the problem. When you partition the mesh,
> I am guessing that you have cells in the overlap. These cells
> must be in the point SF in order for the global section to give them a
> unique owner. Perhaps something has gone wrong here.
> Thanks,
> Matt
> I guess that the culprit is point (4), but if I replace it with
> DMSetGlobalSection then I cannot create the local vector at point (5).
> How should I handle this properly? In my code I need to create
> both local and global vectors, to perform at least GlobalToLocal
> and to save the global data.
> (On a side note, I tried also HDF5 but then it complains about the
> DM not having a DS...; really, any working solution that allows
> data to be explored with Paraview is fine)
> Thanks for any advice!
> Matteo Semplice
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!buvrehNNjQgd0-6_n_Z6VF4Vu2psZ4V9MxJaRNwIIb6jWpe0QCnQJthiMrRDFW2RNEmqkynIU62eShkLj670fPczTBr67mFEnvBJig$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!buvrehNNjQgd0-6_n_Z6VF4Vu2psZ4V9MxJaRNwIIb6jWpe0QCnQJthiMrRDFW2RNEmqkynIU62eShkLj670fPczTBr67mHQkiSkEQ$ >
Professore Associato in Analisi Numerica
Dipartimento di Scienza e Alta Tecnologia
Università degli Studi dell'Insubria
Via Valleggio, 11 - Como
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241022/9966f813/attachment-0001.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241022/9966f813/attachment-0001.bin>
