[petsc-users] issue of MatCreateDense in the CUDA codes
Junchao Zhang junchao.zhang at gmail.com
Thu Oct 3 09:38:30 CDT 2024
The MR is merged to petsc/release.
BTW, in MatCreateDense, the data pointer has to be a host pointer.  It is
better to always use PetscScalar*  (instead of std::complex<double>*) to do
the cast.
--Junchao Zhang
On Thu, Oct 3, 2024 at 3:03 AM 刘浪天 <langtian.liu at icloud.com> wrote:
> Okay. I see :D
> -------------------- Langtian Liu Institute for Theorectical Physics,
> Justus-Liebig-University Giessen Heinrich-Buff-Ring 16, 35392 Giessen
> Germany email: langtian.liu at icloud.com Tel: (+49)641 99 33342
> On Oct 3, 2024, at 9:58 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> You have to wait until the merge request has the label "Merged" instead of
> "Open".
> El 3 oct 2024, a las 9:55, 刘浪天 via petsc-users <petsc-users at mcs.anl.gov>
> escribió:
> Hello Junchao,
> Okay. Thank you for helping find this bug. I pull the newest version of
> petsc today. It seems this error has not been fixed in the present release
> version. Maybe I should wait for some days.
> Best wishes,
> Langtian
> On Oct 3, 2024, at 12:12 AM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> Hi, Langtian,
> Thanks for the configure.log and I now see what's wrong. Since you
> compiled your code with nvcc, we mistakenly thought petsc was configured
> with cuda.
> It is fixed in https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7909__;!!G_uCfscf7eWS!ckm_ynevPO4eoYiGVdofOAnizLKzlNsHf92YV6b-QZr4V0eo-HEk7MWC5flyF7VZFiqAwC3eoy-BPWGyUs0bDjx4iNhW$ ,
> which will be in petsc/release and main.
> Thanks.
> --Junchao Zhang
> On Wed, Oct 2, 2024 at 3:11 PM 刘浪天 <langtian.liu at icloud.com> wrote:
> Hi Junchao,
> I check it, I haven't use cuda when install pure cpu version of petsc.
> The configure.log has been attached. Thank you for your reply.
> Best wishes,
> On Oct 2, 2024, at 5:05 PM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> On Wed, Oct 2, 2024 at 3:57 AM 刘浪天 via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi all,
> I am using the PETSc and SLEPc to solve the Faddeev equation of baryons. I
> encounter a problem of function MatCreateDense when changing from CPU to
> CPU-GPU computations.
> At first, I write the codes in purely CPU computation in the following way
> and it works.
> Eigen::MatrixXcd H_KER;
> Eigen::MatrixXcd G0;
> printf("\nCompute the propagator matrix.\n");
> prop_matrix_nucleon_sc_av(Mn, pp_nodes, cos1_nodes);
> printf("\nCompute the propagator matrix done.\n");
> printf("\nCompute the kernel matrix.\n");
> bse_kernel_nucleon_sc_av(Mn, pp_nodes, pp_weights, cos1_nodes,
> cos1_weights);
> printf("\nCompute the kernel matrix done.\n");
> printf("\nCompute the full kernel matrix by multiplying kernel and
> MatrixXcd kernel_temp = H_KER * G0;
> printf("\nCompute the full kernel matrix done.\n");
> // Solve the eigen system with SLEPc
> printf("\nSolve the eigen system in the rest frame.\n");
> // Get the size of the Eigen matrix
> int nRows = (int) kernel_temp.rows();
> int nCols = (int) kernel_temp.cols();
> // Create PETSc matrix and share the data of kernel_temp
> Mat kernel;
> PetscCall(MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
> nRows, nCols, kernel_temp.data(), &kernel));
> PetscCall(MatAssemblyBegin(kernel, MAT_FINAL_ASSEMBLY));
> PetscCall(MatAssemblyEnd(kernel, MAT_FINAL_ASSEMBLY));
> Now I change to compute the propagator and kernel matrices in GPU and then
> compute the largest eigenvalues in CPU using SLEPc in the ways below.
> cuDoubleComplex *h_propmat;
> cuDoubleComplex *h_kernelmat;
> int dim = EIGHT * NP * NZ;
> prop_matrix_nucleon_sc_av_cuda(Mn, pp_nodes.data(), cos1_nodes.data());
> kernel_matrix_nucleon_sc_av_cuda(Mn, pp_nodes.data(), pp_weights.data(),
> cos1_nodes.data(), cos1_weights.data());
> // Map the raw arrays to Eigen matrices (column-major order)
> auto *h_kernel_temp = new cuDoubleComplex [dim*dim];
> matmul_cublas_cuDoubleComplex(h_kernelmat,h_propmat,h_kernel_temp,dim,dim,dim);
> int nRows = dim;
> int nCols = dim;
> Mat kernel;
> auto* h_kernel = (std::complex<double>*)(h_kernel_temp);
> nRows, nCols, h_kernel_temp, &kernel));
> But in this case, the compiler told me that the MatCreateDense function
> uses the data pointer as type of "thrust::complex<double>" instead of
> "std::complex<double>".
> I am sure I only configured and install PETSc in purely CPU without GPU
> and this codes are written in the host function.
> Please double check that your PETSc was purely CPU configured. You can
> find it at the end of your configure.log to see if petsc is configured with
> CUDA.
> Since thrust::complex<double> is a result of a petsc/cuda configuration, I
> have this doubt.
> Why the function changes its behavior? Did you also meet this problem when
> writing the cuda codes and how to solve this problem.
> I tried to copy the data to a new thrust::complex<double> matrix but this
> is very time consuming since my matrix is very big. Is there a way to
> create the Mat from the original data without changing the data type to
> thrust::complex<double> in the cuda applications? Any response will be
> appreciated. Thank you!
> Best wishes,
> Langtian Liu
> Institute for Theorectical Physics, Justus-Liebig-University Giessen
> Heinrich-Buff-Ring 16, 35392 Giessen Germany
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241003/05b194f7/attachment.html>
