[petsc-users] Multigrid Preconditioned CG on cell-centered Poisson with DMStag
Barry Smith bsmith at petsc.dev
Wed Oct 2 11:40:58 CDT 2024
   Use -mg_coarse_pc_type svd
   Verify that when you apply the restriction to a constant vector (all ones) it returns a constant vector, maybe scaled
   Verify that when you apply the interpolation to a constant vector it returns a constant vector
> On Oct 2, 2024, at 12:29 PM, Gautam Luhana <gkluhana at cs.ubc.ca> wrote:
> GMRES is similar i.e. converges but iteration counts go +1-2 with every doubling of the mesh.
> I am attaching the output from a cg and gmres run for a single stokes iteration with a velocity and pressure subdomain solves, subsequent iterations are similar. The pressure subdomain ksp is titled pre_mgcg.
> Adding more information in case it is relevant to isolating the issue:
> -> The coarse grid operators are formed by setting PCMGSetGalerkin to PC_MG_GALERKIN_BOTH.
> -> The interpolation / restriction operators are formed using the DMCreateInterpolation and DMCreateRestriction functions on coarsened DMs (DMStag implementation) and sent to PCMGSetInterpolation/PCMGSetRestriction.
> Thanks for the help!
> -Gautam
> On 2024-10-02 7:42 a.m., Barry Smith wrote:
>> [CAUTION: Non-UBC Email]
>> Using
>> PetscCall(MatNullSpaceCreate(PetscObjectComm((PetscObject)dmPressure), PETSC_TRUE, 0, nullptr, &matNullSpace));
>> should be fine (the other approach is equivalent).
>> Any change if you use -ksp_type gmres?
>> Please send all the output from a sample run with -ksp_monitor_true_residual -ksp_view
>>> On Oct 1, 2024, at 6:42 PM, Gautam Luhana <gkluhana at cs.ubc.ca> wrote:
>>> I did think that I accounted for that but now I see that I am getting the same number of iterations in the pressure space with and without the call to MatSetNullspace so maybe I am not doing that correctly and that's where the problem is.
>>> I tried it in the following way first:
>>>       PetscCall(MatSetNullSpace(*A, matNullSpace));
>>> and then also as:
>>>       PetscCall(DMGetGlobalVector(dmPressure, &constantPressure));
>>>       PetscCall(VecSet(constantPressure, 1.0));
>>>       PetscCall(VecNorm(constantPressure, NORM_2, &nrm));
>>>       PetscCall(VecScale(constantPressure, 1.0 / nrm));
>>>       PetscCall(DMCreateGlobalVector(dmPressure, &basis));
>>>       PetscCall(VecCopy(constantPressure, basis));
>>> PetscCall(MatNullSpaceCreate(PetscObjectComm((PetscObject)dmPressure), PETSC_FALSE, 1, &basis, &matNullSpace));
>>> Is this the right way? are there other options that need to be set?
>>> -Gautam
>>>>    Are you handling the null space? Like with MatSetNullSpace()?
>>>>    Can you try src/ksp/ksp/tutorials/ex32.c it solves the same problem but with a simpler DMDA. I don't see any reason why using DMStag with the cell-centered values should be different.
>>>>    Barry
>>>>> On Oct 1, 2024, at 3:37 PM, Gautam Luhana <gkluhana at cs.ubc.ca> wrote:
>>>>> Hello,
>>>>> I am solving the stokes equations on the MAC grid using DMStag with an approximate Schur complement based preconditioner. The preconditioner needs a subdomain solve of the Poisson equation on both the velocity as well as the pressure space. I am using multigrid preconditioned CG for both the subdomain solves. While the subdomain solve on the velocity space converges in 4-5 iterations and is independent of mesh-size, the pressure solve is not mesh-size independent. Relevant information:
>>>>> Pressure space operator has Neumann boundary conditions.
>>>>> Coarse-grid operators are being generated using the Galerkin approach (A = P*Af*Pt) for both of the subdomains.
>>>>> For the pressure space, the jacobi and sor smoothers were tried with several omega and damping parameter choices.
>>>>> Symmetric smoothing (same number of pre- and post-smoothing iterations)
>>>>> Has anyone tried solving the poisson operator on the cell-centered pressure space with DMStag? Or know what might be going wrong with the mg-cg convergence?
>>>>> Thanks!
>>>>> -Gautam
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241002/0d4e36c3/attachment-0002.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241002/0d4e36c3/attachment-0003.txt>
