[petsc-users] issue of MatCreateDense in the CUDA codes
Jose E. Roman
jroman at dsic.upv.es
Wed Oct 2 04:18:21 CDT 2024
For the CUDA case you should use MatCreateDenseCUDA() instead of MatCreateDense(). With this you pass a pointer with the data on the GPU memory. But I guess "new cuDoubleComplex[dim*dim]" is allocating on the CPU, you should use cudaMalloc() instead.
Jose
> El 2 oct 2024, a las 10:56, 刘浪天 via petsc-users <petsc-users at mcs.anl.gov> escribió:
> Hi all,
> I am using the PETSc and SLEPc to solve the Faddeev equation of baryons. I encounter a problem of function MatCreateDense when changing from CPU to CPU-GPU computations.
> At first, I write the codes in purely CPU computation in the following way and it works.
> Eigen::MatrixXcd H_KER;
> Eigen::MatrixXcd G0;
> printf("\nCompute the propagator matrix.\n");
> prop_matrix_nucleon_sc_av(Mn, pp_nodes, cos1_nodes);
> printf("\nCompute the propagator matrix done.\n");
> printf("\nCompute the kernel matrix.\n");
> bse_kernel_nucleon_sc_av(Mn, pp_nodes, pp_weights, cos1_nodes, cos1_weights);
> printf("\nCompute the kernel matrix done.\n");
> printf("\nCompute the full kernel matrix by multiplying kernel and propagator matrix.\n");
> MatrixXcd kernel_temp = H_KER * G0;
> printf("\nCompute the full kernel matrix done.\n");
> // Solve the eigen system with SLEPc
> printf("\nSolve the eigen system in the rest frame.\n");
> // Get the size of the Eigen matrix
> int nRows = (int) kernel_temp.rows();
> int nCols = (int) kernel_temp.cols();
> // Create PETSc matrix and share the data of kernel_temp
> Mat kernel;
> PetscCall(MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, nRows, nCols, kernel_temp.data(), &kernel));
> PetscCall(MatAssemblyBegin(kernel, MAT_FINAL_ASSEMBLY));
> PetscCall(MatAssemblyEnd(kernel, MAT_FINAL_ASSEMBLY));
> Now I change to compute the propagator and kernel matrices in GPU and then compute the largest eigenvalues in CPU using SLEPc in the ways below.
> cuDoubleComplex *h_propmat;
> cuDoubleComplex *h_kernelmat;
> int dim = EIGHT * NP * NZ;
> prop_matrix_nucleon_sc_av_cuda(Mn, pp_nodes.data(), cos1_nodes.data());
> kernel_matrix_nucleon_sc_av_cuda(Mn, pp_nodes.data(), pp_weights.data(), cos1_nodes.data(), cos1_weights.data());
> // Map the raw arrays to Eigen matrices (column-major order)
> auto *h_kernel_temp = new cuDoubleComplex [dim*dim];
> matmul_cublas_cuDoubleComplex(h_kernelmat,h_propmat,h_kernel_temp,dim,dim,dim);
> int nRows = dim;
> int nCols = dim;
> Mat kernel;
> auto* h_kernel = (std::complex<double>*)(h_kernel_temp);
> PetscCall(MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, nRows, nCols, h_kernel_temp, &kernel));
> But in this case, the compiler told me that the MatCreateDense function uses the data pointer as type of "thrust::complex<double>" instead of "std::complex<double>".
> I am sure I only configured and install PETSc in purely CPU without GPU and this codes are written in the host function.
> Why the function changes its behavior? Did you also meet this problem when writing the cuda codes and how to solve this problem.
> I tried to copy the data to a new thrust::complex<double> matrix but this is very time consuming since my matrix is very big. Is there a way to create the Mat from the original data without changing the data type to thrust::complex<double> in the cuda applications? Any response will be appreciated. Thank you!
> Best wishes,
> Langtian Liu
> Institute for Theorectical Physics, Justus-Liebig-University Giessen
> Heinrich-Buff-Ring 16, 35392 Giessen Germany
