[petsc-users] Cannot iterate well when using Newton iteration of SNES
David Jiawei LUO LIANG
12431140 at mail.sustech.edu.cn
Thu Nov 21 09:45:04 CST 2024
Coincidentally, Matt. I am gonna write the 2d heat dynamic problem.
Now I still not that much understand how DM mesh works.
It is a good chance to learn DM by studying your example.
Hope you the best!
南方科技大学/学生/研究生/2024
广东省深圳市南山区学苑大道1088号
------------------ Original ------------------
Date: Thu, Nov 21, 2024 11:37 PM
To: "Jed Brown"<jed at jedbrown.org>;
Cc: "David Jiawei LUO LIANG"<12431140 at mail.sustech.edu.cn>; "petsc-users"<petsc-users at mcs.anl.gov>;
Subject: Re: [petsc-users] Cannot iterate well when using Newton iteration of SNES
One more suggestion email. I solve the linear version myself in ts/tutorials/ex45.c
Matt
On Thu, Nov 21, 2024 at 10:35 AM Jed Brown <jed at jedbrown.org> wrote:
You should add VecZeroEntries(f) near the top of your FormFunction (it's currently accumulating into whatever was there last) and MatZeroEntries(B) to FormJacobian.
I reduced to nElem = 5 for ease of viewing. With these changes, I see quadratic convergence but the problem is still nonlinear. To explore further, consider using these diagnostics
./SNES_heat -{snes,ksp}_monitor -{snes,ksp}_converged_reason -snes_linesearch_monitor -ksp_view_mat
with and without -snes_fd.
For readability, I would suggest consistency in "u" vs "x".
"David Jiawei LUO LIANG" <12431140 at mail.sustech.edu.cn> writes:
> I am using the Newton iteration to solve a nonlinear 1D heat equation problem by using FEM.
> I attached my source code named "SNES_heat.cpp"
> when I run the code
> 0 SNES Function norm 1.206289245288e+01
> 1 SNES Function norm 7.128802192789e+00
> 2 SNES Function norm 6.608812909525e+00
> you can find that it only iterate 3 steps, and then do all the function evaluation and finally just stop the program.
> I think it is not reasonble. I check my code, it is correct if I set it as a linear problem. it means my Jacobian and Residual function is correct.
> But when I set it as a nonlinear, the residual seems reduces as not expected.
> I doubt that whether my understanding of the newton iteration is different from SNES's newton iteration process.
> 南方科技大学/学生/研究生/2024
> 广东省深圳市南山区学苑大道1088号
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dSL2GSpljTIMB0tcY__f9j77VbVzQe3qtLiTf_zyXLkjYGis3L_HhIi6Zd3Xebfl90gusl7j3fAmWfqFsna4Ipv55wHVlbA1$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241121/3d962b94/attachment.html>
