[petsc-users] Cannot iterate well when using Newton iteration of SNES
David Jiawei LUO LIANG
12431140 at mail.sustech.edu.cn
Thu Nov 21 06:11:32 CST 2024
I am using the Newton iteration to solve a nonlinear 1D heat equation problem by using FEM.
I attached my source code named "SNES_heat.cpp"
when I run the code
0 SNES Function norm 1.206289245288e+01
1 SNES Function norm 7.128802192789e+00
2 SNES Function norm 6.608812909525e+00
you can find that it only iterate 3 steps, and then do all the function evaluation and finally just stop the program.
I think it is not reasonble. I check my code, it is correct if I set it as a linear problem. it means my Jacobian and Residual function is correct.
But when I set it as a nonlinear, the residual seems reduces as not expected.
I doubt that whether my understanding of the newton iteration is different from SNES's newton iteration process.
南方科技大学/学生/研究生/2024
广东省深圳市南山区学苑大道1088号
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241121/e58d6eca/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241121/e58d6eca/attachment-0001.obj>
