[petsc-users] Doubt about mesh size distribution in DMDACreate3d using periodic boundary conditions
Barry Smith bsmith at petsc.dev
Wed Nov 20 15:56:56 CST 2024
> On Nov 20, 2024, at 2:38 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
> Yes, I use the vertex (nodes) of the elements.
   Then the length between each vertex will be different between periodic and non-periodic case. With 10 points and non-periodic, it will be 1/9, and with periodic it will be 1/10th. Is this what you are asking about?
> I am using the DMDA as an auxiliar mesh to do the domain partitioning in the DMSWARM.
> Thanks,
> Miguel
>> On 20 Nov 2024, at 19:54, Barry Smith <bsmith at petsc.dev> wrote:
>>    Are you considering your degrees of freedom as vertex or cell-centered?
>>    Say three "elements" per edge.
>>        If vertex centered then discretization size is 1/3 if periodic and 1/2 if not periodic
>>        If cell-centered then each cell has width 1/3 for both periodic and not periodic
>>     but in both cases you can think of the discretization size as constant along the whole cube edge.
>>     Is this related to DMSWARM in particular?
>>> On Nov 20, 2024, at 12:56 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
>>> I mean that if the dimensions of the cube are 1x1x1 (for example). And I want 10 elements per edge, the discretization size must be 0.1 constant over the whole cube edge.
>>> This is not in the code, I just impose the number of elements per edge.
>>> Thank you,
>>> Miguel
>>>> On 20 Nov 2024, at 18:52, Barry Smith <bsmith at petsc.dev> wrote:
>>>>   What do you mean by discretization size, and how do I see it in the code?
>>>>   Barry
>>>>> On Nov 20, 2024, at 12:48 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
>>>>> Sorry, I meant that the discretisation size is not constant across the edges of the cube.
>>>>> Miguel
>>>>>> On 20 Nov 2024, at 18:36, Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>    I am sorry, I don't understand the problem. When I run by default with -da_view I get
>>>>>> Processor [0] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2
>>>>>> Processor [1] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 0 2
>>>>>> Processor [2] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 0 2
>>>>>> Processor [3] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 0 2
>>>>>> Processor [4] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 3
>>>>>> Processor [5] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 2 3
>>>>>> Processor [6] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 2 3
>>>>>> Processor [7] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 2 3
>>>>>> which seems right because you are trying to have three cells in each direction. The distribution has to be uneven, hence 0 2 and 2 3
>>>>>> When I change the code to use ndiv_mesh_* = 4 and run with periodic or not I get
>>>>>> $ PETSC_OPTIONS="" mpiexec -n 8 ./atoms-3D -dm_view
>>>>>> DM Object: 8 MPI processes
>>>>>>   type: da
>>>>>> Processor [0] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
>>>>>> Processor [1] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 0 2
>>>>>> Processor [2] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 0 2
>>>>>> Processor [3] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 0 2
>>>>>> Processor [4] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 4
>>>>>> Processor [5] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 2 4
>>>>>> Processor [6] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 2 4
>>>>>> Processor [7] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
>>>>>> X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 2 4
>>>>>> so it is splitting as expected each rank gets a 2 by 2 by 2 set of indices.
>>>>>> Could you please let me know what the problem is that I should be seeing.
>>>>>>   Barry
>>>>>>> On Nov 20, 2024, at 7:06 AM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
>>>>>>> Dear Barry,
>>>>>>> Please, find attached to this email a minimal example of the problem. Run it using 8 MPI processes.
>>>>>>> Thanks,
>>>>>>> Miguel
>>>>>>>> On 20 Nov 2024, at 11:48, Miguel Molinos <mmolinos at us.es> wrote:
>>>>>>>> Hi Bary:
>>>>>>>> I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP.
>>>>>>>> Thanks,
>>>>>>>> Miguel
>>>>>>>>> On 19 Nov 2024, at 18:55, Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>>>>    I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC
>>>>>>>>>     Can you please send a reproducible example?
>>>>>>>>>     Thanks
>>>>>>>>>      Barry
>>>>>>>>>> On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
>>>>>>>>>> Dear all:
>>>>>>>>>> It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size.
>>>>>>>>>> I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed:
>>>>>>>>>> 210 420 366 732 420 840 732 1464
>>>>>>>>>> Am I missing something?
>>>>>>>>>> Thanks,
>>>>>>>>>> Miguel
>>>>>>>>>> <Screenshot 2024-11-19 at 10.56.36.png>
>>>>>>> <atoms-3D.cpp><Mg-hcp-cube-x17-x10-x10.dump>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241120/1ae00f51/attachment-0001.html>
