[petsc-users] Doubt about mesh size distribution in DMDACreate3d using periodic boundary conditions
MIGUEL MOLINOS PEREZ
mmolinos at us.es
Wed Nov 20 11:56:27 CST 2024
I mean that if the dimensions of the cube are 1x1x1 (for example). And I want 10 elements per edge, the discretization size must be 0.1 constant over the whole cube edge.
This is not in the code, I just impose the number of elements per edge.
Thank you,
Miguel
On 20 Nov 2024, at 18:52, Barry Smith <bsmith at petsc.dev> wrote:
What do you mean by discretization size, and how do I see it in the code?
Barry
On Nov 20, 2024, at 12:48 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
Sorry, I meant that the discretisation size is not constant across the edges of the cube.
Miguel
On 20 Nov 2024, at 18:36, Barry Smith <bsmith at petsc.dev> wrote:
I am sorry, I don't understand the problem. When I run by default with -da_view I get
Processor [0] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 0 2
Processor [1] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 0 2
Processor [2] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 0 2
Processor [3] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 0 2
Processor [4] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 3
Processor [5] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
X range of indices: 2 3, Y range of indices: 0 2, Z range of indices: 2 3
Processor [6] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
X range of indices: 0 2, Y range of indices: 2 3, Z range of indices: 2 3
Processor [7] M 3 N 3 P 3 m 2 n 2 p 2 w 1 s 1
X range of indices: 2 3, Y range of indices: 2 3, Z range of indices: 2 3
which seems right because you are trying to have three cells in each direction. The distribution has to be uneven, hence 0 2 and 2 3
When I change the code to use ndiv_mesh_* = 4 and run with periodic or not I get
$ PETSC_OPTIONS="" mpiexec -n 8 ./atoms-3D -dm_view
DM Object: 8 MPI processes
type: da
Processor [0] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
Processor [1] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 0 2
Processor [2] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 0 2
Processor [3] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 0 2
Processor [4] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
X range of indices: 0 2, Y range of indices: 0 2, Z range of indices: 2 4
Processor [5] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
X range of indices: 2 4, Y range of indices: 0 2, Z range of indices: 2 4
Processor [6] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
X range of indices: 0 2, Y range of indices: 2 4, Z range of indices: 2 4
Processor [7] M 4 N 4 P 4 m 2 n 2 p 2 w 1 s 1
X range of indices: 2 4, Y range of indices: 2 4, Z range of indices: 2 4
so it is splitting as expected each rank gets a 2 by 2 by 2 set of indices.
Could you please let me know what the problem is that I should be seeing.
Barry
On Nov 20, 2024, at 7:06 AM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
Dear Barry,
Please, find attached to this email a minimal example of the problem. Run it using 8 MPI processes.
Miguel
On 20 Nov 2024, at 11:48, Miguel Molinos <mmolinos at us.es> wrote:
Hi Bary:
I will check the example you suggest. Anyhow, I’ll send a reproducible example ASAP.
Miguel
On 19 Nov 2024, at 18:55, Barry Smith <bsmith at petsc.dev> wrote:
I modify src/dm/tests/ex25.c and always see a nice even split when possible with both DM_BOUNDARY_NONE and DM_BOUNDARY_PERIODIC
Can you please send a reproducible example?
Thanks
Barry
On Nov 19, 2024, at 6:14 AM, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
Dear all:
It seems that if I mesh a cubic domain with “DMDACreate3d” using 8 bricks for discretization and with periodic boundaries, each of the bricks has a different size. In contrast, if I use DM_BOUNDARY_NONE, all 8 bricks have the same size.
I have used this together with the DMSWarm discretization. And as you can see the number of particles per rank is not evenly distributed:
210 420 366 732 420 840 732 1464
Am I missing something?
Miguel
<Screenshot 2024-11-19 at 10.56.36.png>
<atoms-3D.cpp><Mg-hcp-cube-x17-x10-x10.dump>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241120/0480ec7e/attachment-0001.html>
