[petsc-users] Compiling PETSc in for Grace-Hopper nodes
Vanella, Marcos (Fed) marcos.vanella at nist.gov
Fri Nov 8 14:34:37 CST 2024
Hi Satish and Junchao, this is what I'm getting at the end of the configure.log. I guess there is an incompatibility among nvcc and the gcc version I'm using.
TESTING: checkCUDACompiler from config.setCompilers(/home1/09805/mnv/Software/petsc/config/BuildSystem/config/setCompilers.py:1541)
  Locate a functional CUDA compiler
    Checking for program /opt/apps/xalt/xalt/bin/nvcc...not found
    Checking for program /opt/apps/gcc14/cuda12/openmpi/5.0.5/libexec/osu-micro-benchmarks/mpi/one-sided/nvcc...not found
    Checking for program /opt/apps/gcc14/cuda12/openmpi/5.0.5/libexec/osu-micro-benchmarks/mpi/collective/nvcc...not found
    Checking for program /opt/apps/gcc14/cuda12/openmpi/5.0.5/libexec/osu-micro-benchmarks/mpi/pt2pt/nvcc...not found
    Checking for program /opt/apps/gcc14/cuda12/openmpi/5.0.5/libexec/osu-micro-benchmarks/mpi/startup/nvcc...not found
    Checking for program /opt/apps/gcc14/cuda12/openmpi/5.0.5/bin/nvcc...not found
    Checking for program /home1/apps/nvidia/Linux_aarch64/24.7/cuda/12.5/bin/nvcc...found
              Defined make macro "CUDAC" to "nvcc"
Executing: nvcc -c -o /tmp/petsc-qlfa8fb8/config.setCompilers/conftest.o -I/tmp/petsc-qlfa8fb8/config.setCompilers   /tmp/petsc-qlfa8fb8/config.setCompilers/conftest.cu
stdout:
In file included from /home1/apps/nvidia/Linux_aarch64/24.7/cuda/12.5/bin/../targets/sbsa-linux/include/cuda_runtime.h:82,
                 from <command-line>:
/home1/apps/nvidia/Linux_aarch64/24.7/cuda/12.5/bin/../targets/sbsa-linux/include/crt/host_config.h:143:2: error: #error -- unsupported GNU version! gcc versions later than 13 are not supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk.
  143 | #error -- unsupported GNU version! gcc versions later than 13 are not supported! The nvcc flag '-allow-unsupported-compiler' can be used to override this version check; however, using an unsupported host compiler may cause compilation failure or incorrect run time execution. Use at your own risk.
Possible ERROR while running compiler: exit code 1
stderr:
Source:
#include "confdefs.h"
#include "conffix.h"
int main(void) {
  return 0;
          Error testing CUDA compiler: Cannot compile CUDA with nvcc.
            Deleting "CUDAC"
           UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
  CUDA compiler you provided with -with-cudac=nvcc cannot be found or does not work.
  File "/home1/09805/mnv/Software/petsc/config/configure.py", line 461, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/home1/09805/mnv/Software/petsc/config/BuildSystem/config/framework.py", line 1460, in configure
    self.processChildren()
  File "/home1/09805/mnv/Software/petsc/config/BuildSystem/config/framework.py", line 1448, in processChildren
    self.serialEvaluation(self.childGraph)
  File "/home1/09805/mnv/Software/petsc/config/BuildSystem/config/framework.py", line 1423, in serialEvaluation
    child.configure()
  File "/home1/09805/mnv/Software/petsc/config/BuildSystem/config/setCompilers.py", line 2846, in configure
    self.executeTest(getattr(self,LANG.join(('check','Compiler'))))
  File "/home1/09805/mnv/Software/petsc/config/BuildSystem/config/base.py", line 138, in executeTest
    ret = test(*args,**kargs)
  File "/home1/09805/mnv/Software/petsc/config/BuildSystem/config/setCompilers.py", line 1544, in checkCUDACompiler
    for compiler in self.generateCUDACompilerGuesses():
  File "/home1/09805/mnv/Software/petsc/config/BuildSystem/config/setCompilers.py", line 1527, in generateCUDACompilerGuesses
    raise RuntimeError('CUDA compiler you provided with -with-cudac='+self.argDB['with-cudac']+' cannot be found or does not work.'+'\n'+self.mesg)
Finishing configure run at Fri, 08 Nov 2024 14:28:04 -0600
Sent: Friday, November 8, 2024 3:25 PM
To: Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Compiling PETSc in for Grace-Hopper nodes
Hi, Marcos
  Could you attach the configure.log?
--Junchao Zhang
On Fri, Nov 8, 2024 at 2:19 PM Vanella, Marcos (Fed) via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi all, does anyone have experience compiling PETSc with gnu openmpi and cross compiling with cuda nvcc on these systems?
we have access to Vista, a machine in TACC and was trying to build PETSc with these libraries. I would need gnu openmpi to compile my code (fortran std 2018), and would like to keep the same cpu compiler/openmpi for PETSc.I have the following modules loaded:
Currently Loaded Modules:
  1) ucc/1.3.0   2) ucx/1.17.0   3) cmake/3.29.5   4) xalt/3.1   5) TACC   6) gcc/14.2.0   7) cuda/12.5 (g)   8) openmpi/5.0.5
  Where:
   g:  built for GPU
Here mpicc points to the gcc compiler, etc. When configuring PETSc in the following form I get nvcc not working:
$ ./configure COPTFLAGS="-O2 -g" CXXOPTFLAGS="-O2 -g" FOPTFLAGS="-O2 -g" FCOPTFLAGS="-O2 -g" CUDAOPTFLAGS="-O2 -g" --with-debugging=1 --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort --with-cuda --with-cudac=nvcc --with-cuda-arch=90 --download-fblaslapack=1 --with-make-np=8
                         Configuring PETSc to compile on your system
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:1541)
I have nvcc in my path:
$ nvcc --version
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Thu_Jun__6_02:26:10_PDT_2024
Cuda compilation tools, release 12.5, V12.5.82
Build cuda_12.5.r12.5/compiler.34385749_0
I remember being able to do this cross compilation in polaris. Any help is most appreciated,
Marcos
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241108/58150ce8/attachment-0001.html>
