[petsc-users] Matrix free SNES with user provided matrix vector product and preconditioner operation
Barry Smith bsmith at petsc.dev
Wed Nov 6 12:03:47 CST 2024
  You need to provide a callback function. Why? Otherwise your MatShell and PCshell have no way of knowing at what location the Jacobian is suppose to be evaluated at (in a matrix free way). That is the x for which J(x) is used.
  Normally one puts the x into the application context of mJac and accesses it every time the matmult is called. Similarly it needs to be accessed in application of your preconditioner.
> On Nov 6, 2024, at 12:01 PM, Weide, Edwin van der (UT-ET) <e.t.a.vanderweide at utwente.nl> wrote:
> Barry,
> If I do that, I get the following error
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see https://urldefense.us/v3/__https://petsc.org/release/faq/*valgrind__;Iw!!G_uCfscf7eWS!elK6sfqwXIIaLqDzUlKw8Wy--UjvmZXYI0gRqu_nvUNMbIx2rMEX4aHIYXWikS4p4zHPTXyicwT9SEY8-JQt10s$  and https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!elK6sfqwXIIaLqDzUlKw8Wy--UjvmZXYI0gRqu_nvUNMbIx2rMEX4aHIYXWikS4p4zHPTXyicwT9SEY8mXmEtXk$
> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [0]PETSC ERROR: The line numbers in the error traceback are not always exact.
> [0]PETSC ERROR: #1 SNES callback Jacobian
> [0]PETSC ERROR: #2 SNESComputeJacobian() at /home/vdweide/petsc/src/snes/interface/snes.c:2966
> [0]PETSC ERROR: #3 SNESSolve_NEWTONLS() at /home/vdweide/petsc/src/snes/impls/ls/ls.c:218
> [0]PETSC ERROR: #4 SNESSolve() at /home/vdweide/petsc/src/snes/interface/snes.c:4841
> [0]PETSC ERROR: #5 SolveCurrentStage() at SolverClass.cpp:502
> [0]PETSC ERROR: #6 main() at Condensation.cpp:20
> So SNES tries to call the call back function for the Jacobian, but that is not provided. Hence the failure.
> Regards,
> Edwin
> From: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Sent: Wednesday, November 6, 2024 5:52 PM
> To: Weide, Edwin van der (UT-ET) <e.t.a.vanderweide at utwente.nl <mailto:e.t.a.vanderweide at utwente.nl>>
> Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Subject: Re: [petsc-users] Matrix free SNES with user provided matrix vector product and preconditioner operation
>    Just pass mJac, mJac  instead of mJac, nullptr and it will be happy.  In your case, the second mJac  won't be used in your preconditioner it is just a place holder so other parts of SNES won't try to create a matrix.
>   Barry
>> On Nov 6, 2024, at 11:36 AM, Weide, Edwin van der (UT-ET) via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>> Hi,
>> I am trying to solve a nonlinear problem with matrix-free SNES where I would like to provide both the matrix vector product and the preconditioner myself. For that purpose, I use the following construction.
>>   // Set up the matrix free evaluation of the Jacobian times a vector
>>   // by setting the appropriate function in snes.
>>   PetscCall(MatCreateShell(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE,
>>                            nEqns, nEqns, this, &mJac));
>>   PetscCall(MatShellSetOperation(mJac, MATOP_MULT,
>>                                  (void (*)(void))JacobianTimesVector));
>>   PetscCall(SNESSetJacobian(mSnes, mJac, nullptr, nullptr, nullptr));
>>   // Set the function to be used as preconditioner for the krylov solver.
>>   KSP ksp;
>>   PC  pc;
>>   PetscCall(SNESGetKSP(mSnes, &ksp));
>>   PetscCall(KSPGetPC(ksp, &pc));
>>   PetscCall(PCSetType(pc, PCSHELL));
>>   PetscCall(PCSetApplicationContext(pc, this));
>>   PetscCall(PCShellSetApply(pc, Preconditioner));
>> For small problems this construction works, and it does exactly what I expect it to do. However, when I increase the problem size, I get a memory allocation failure in SNESSolve, because it looks like SNES attempts to allocate memory for a full dense matrix for the preconditioner, which is not used. This is the call stack when the error occurs.
>> [0]PETSC ERROR: #1 PetscMallocAlign() at /home/vdweide/petsc/src/sys/memory/mal.c:53
>> [0]PETSC ERROR: #2 PetscTrMallocDefault() at /home/vdweide/petsc/src/sys/memory/mtr.c:175
>> [0]PETSC ERROR: #3 PetscMallocA() at /home/vdweide/petsc/src/sys/memory/mal.c:421
>> [0]PETSC ERROR: #4 MatSeqDenseSetPreallocation_SeqDense() at /home/vdweide/petsc/src/mat/impls/dense/seq/dense.c:3357
>> [0]PETSC ERROR: #5 MatSeqDenseSetPreallocation() at /home/vdweide/petsc/src/mat/impls/dense/seq/dense.c:3338
>> [0]PETSC ERROR: #6 MatDuplicateNoCreate_SeqDense() at /home/vdweide/petsc/src/mat/impls/dense/seq/dense.c:372
>> [0]PETSC ERROR: #7 MatDuplicate_SeqDense() at /home/vdweide/petsc/src/mat/impls/dense/seq/dense.c:399
>> [0]PETSC ERROR: #8 MatDuplicate() at /home/vdweide/petsc/src/mat/interface/matrix.c:4964
>> [0]PETSC ERROR: #9 DMCreateMatrix_Shell() at /home/vdweide/petsc/src/dm/impls/shell/dmshell.c:195
>> [0]PETSC ERROR: #10 DMCreateMatrix() at /home/vdweide/petsc/src/dm/interface/dm.c:1501
>> [0]PETSC ERROR: #11 SNESSetUpMatrices() at /home/vdweide/petsc/src/snes/interface/snes.c:794
>> [0]PETSC ERROR: #12 SNESSetUp_NEWTONLS() at /home/vdweide/petsc/src/snes/impls/ls/ls.c:290
>> [0]PETSC ERROR: #13 SNESSetUp() at /home/vdweide/petsc/src/snes/interface/snes.c:3395
>> [0]PETSC ERROR: #14 SNESSolve() at /home/vdweide/petsc/src/snes/interface/snes.c:4831
>> [0]PETSC ERROR: #15 SolveCurrentStage() at SolverClass.cpp:502
>> In the function SNESSetUpMatrices the source looks as follows
>>  784   } else if (!snes->jacobian_pre) {
>>  785     PetscDS   prob;
>>  786     Mat       J, B;
>>  787     PetscBool hasPrec = PETSC_FALSE;
>>  788
>>  789     J = snes->jacobian;
>>  790     PetscCall(DMGetDS(dm, &prob));
>>  791     if (prob) PetscCall(PetscDSHasJacobianPreconditioner(prob, &hasPrec));
>>  792     if (J) PetscCall(PetscObjectReference((PetscObject)J));
>>  793     else if (hasPrec) PetscCall(DMCreateMatrix(snes->dm, &J));
>>  794     PetscCall(DMCreateMatrix(snes->dm, &B));
>>  795     PetscCall(SNESSetJacobian(snes, J ? J : B, B, NULL, NULL));
>>  796     PetscCall(MatDestroy(&J));
>>  797     PetscCall(MatDestroy(&B));
>>  798   }
>> It looks like in line 794 it is attempted to create the preconditioner, because it was (intentionally) not provided.
>> Hence my question. Is it possible to use matrix-free SNES with a user provided matrix vector product (via MatShell) and a user provided preconditioner operation without SNES allocating the memory for a dense matrix? If so, what do I need to change in the construction above to make it work?
>> If needed, I can provide the source code for which this problem occurs.
>> Thanks,
>> Edwin
>> Edwin van der Weide
>> Department of Mechanical Engineering
>> University of Twente
>> Enschede, the Netherlands
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241106/505f3c66/attachment-0001.html>
