[petsc-users] Advice on setting BCs in a PLEX
Aldo Bonfiglioli
aldo.bonfiglioli at unibas.it
Mon Nov 4 12:48:08 CST 2024
Dear users,
I have been using petsc's KSP for over 20 years and I am considering
using DMPLEX to replace my own data structure in a mixed FEM/FVM CFD code.
To do so, I am trying to understand DMPLEX by writing a 1D code that
solves u_t = u_xx using PSEUDOTS.
In order to prescribe Dirichlet BCs at the endpoints of the 1D box, I
use PetscSectionSetConstraintDof when building the PetscSection.
> A global vector is missing both the shared dofs which are not owned by
> this process, as well as /constrained/ dofs. These constraints
> represent essential (Dirichlet) boundary conditions. They are dofs
> that have a given fixed value, so they are present in local vectors
> for assembly purposes, but absent from global vectors since they are
> never solved for during algebraic solves.
My global Vec has indeed two entries less than the local one.
When initializing the solution or evaluating the rhs function I transfer
data from the global to local representation, do the calculation, then
transfer back.
I am doing something wrong, though, which shows up in the attached log file.
My simple code is also attached.
Thank you for your advice.
Aldo
Dr. Aldo Bonfiglioli
Associate professor of Fluid Machines
Scuola di Ingegneria
Universita' della Basilicata
V.le dell'Ateneo lucano, 10 85100 Potenza ITALY
tel:+39.0971.205203 fax:+39.0971.205215
web:https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!cWgDpzKW9KGEkqxu775gDU488CBQ5itLl2l_HUsDKcPstbcuSm0_bZPHkMciXajTi3539fuMPe8TD1YZuirDfmSBMSXXxrQZWns$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241104/e493a95c/attachment.html>
DM Object: box 1 MPI process
type: plex
box in 1 dimension:
Number of 0-cells per rank: 11
Number of 1-cells per rank: 10
Labels:
marker: 1 strata with value/size (1 (2))
Face Sets: 2 strata with value/size (1 (1), 2 (1))
depth: 2 strata with value/size (0 (11), 1 (10))
celltype: 2 strata with value/size (0 (11), 1 (10))
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Point 10: Global dof 0 != 1 size - number of constraints
[0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
[0]PETSC ERROR: Option left: name:-ts_max_steps value: 10 source: command line
[0]PETSC ERROR: Option left: name:-ts_monitor (no value) source: command line
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.22.0, Sep 28, 2024
[0]PETSC ERROR: ./ex15f90 with 1 MPI process(es) and PETSC_ARCH linux_gnu on DESKTOP-04AR6V6.lan by abonfi Mon Nov 4 19:28:00 2024
[0]PETSC ERROR: Configure options: --with-mpi=1 --with-mpi-dir=/usr/lib64/mpi/gcc/mpich --with-shared-libraries=1 --with-debugging=1 --with-blas-lib=/usr/lib64/libblas.a --with-lapack-lib=/usr/lib64/liblapack.a --with-triangle=1 --download-triangle=yes
[0]PETSC ERROR: #1 PetscSFSetGraphSection() at /home/abonfi/src/petsc-3.22.0/src/vec/is/sf/utils/sfutils.c:179
[0]PETSC ERROR: #2 DMCreateSectionSF() at /home/abonfi/src/petsc-3.22.0/src/dm/interface/dm.c:4783
[0]PETSC ERROR: #3 DMGetSectionSF() at /home/abonfi/src/petsc-3.22.0/src/dm/interface/dm.c:4722
[0]PETSC ERROR: #4 DMGlobalToLocalBegin() at /home/abonfi/src/petsc-3.22.0/src/dm/interface/dm.c:2851
[0]PETSC ERROR: #5 DMGlobalToLocal() at /home/abonfi/src/petsc-3.22.0/src/dm/interface/dm.c:2812
[0]PETSC ERROR: #6 ex15f90.F90:280
Abort(62) on node 0 (rank 0 in comm 16): application called MPI_Abort(MPI_COMM_SELF, 62) - process 0
there are 11 entries in depth: 0
there are 10 entries in depth: 1
Setting up a section on 11 meshpoints with 1 dofs
The DM is marked
Point 10 is a boundary point
Point 20 is a boundary point
Array u has type : seq
(Global) Array u has size : 9
coordVec has size 11
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241104/e493a95c/attachment.bin>
