[petsc-users] Diagnosing Convergence Issue in Fieldsplit Problem
Colton Bryant coltonbryant2021 at u.northwestern.edu
Thu May 30 14:15:07 CDT 2024
Hi Barry,
Do you know of an example that demonstrates this approach? I have tried
implementing this using DMStagCreateISFromStencils and then calling
PCFieldSplitSetIS with fields named "velocity" and "pressure" respectively,
but when I look at -ksp_view the fields are being set to "fieldsplit_face"
and "fieldsplit_element" and as problems are not converging I expect the
constant null space is not being attached.
Colton
On Thu, May 23, 2024 at 12:55 PM Barry Smith <bsmith at petsc.dev> wrote:
>    Unfortunately it cannot automatically because
> -pc_fieldsplit_detect_saddle_point just grabs part of the matrix (having no
> concept of "what part" so doesn't know to grab the null space information.
>    It would be possible for PCFIELDSPLIT to access the null space of the
> larger matrix directly as vectors and check if they are all zero in the 00
> block, then it would know that the null space only applied to the second
> block and could use it for the Schur complement.
>    Matt, Jed, Stefano, Pierre does this make sense?
>    Colton,
>     Meanwhile the quickest thing you can do is to generate the IS the
> defines the first and second block (instead of using
> -pc_fieldsplit_detect_saddle_point) and use PetscObjectCompose to attach
> the constant null space to the second block with the name "nullspace".
> PCFIELDSPLIT will then use this null space for the Schur complement solve.
>   Barry
> On May 23, 2024, at 2:43 PM, Colton Bryant <
> coltonbryant2021 at u.northwestern.edu> wrote:
> Yes, the original operator definitely has a constant null space
> corresponding to the constant pressure mode. I am currently handling this
> by using the MatSetNullSpace function when the matrix is being created.
> Does this information get passed to the submatrices of the fieldsplit?
> -Colton
> On Thu, May 23, 2024 at 12:36 PM Barry Smith <bsmith at petsc.dev> wrote:
>>    Ok,
>>     So what is happening is that GMRES with a restart of 30 is running on
>> the Schur complement system with no preconditioning and LU (as a direct
>> solver) is being used in the application of S (the Schur complement).  The
>> convergence of GMRES is stagnating after getting about 8 digits of accuracy
>> in the residual. Then at the second GMRES
>> restart it is comparing the explicitly computing residual b - Ax with
>> that computed inside the GMRES algorithm (via a recursive formula) and
>> finding a large difference so generating an error.  Since you are using a
>> direct solver on the A_{00} block and it is well-conditioned this problem
>> is not expected.
>>    Is it possible that the S operator has a null space (perhaps of the
>> constant vector)? Or, relatedly, does your original full matrix have a null
>> space?
>>    We have a way to associated null spaces of the submatrices in
>> PCFIELDSPLIT by attaching them to the IS that define the fields, but
>> unfortunately not trivially when using -pc_fieldsplit_detect_saddle_point.
>> And sadly the current support seems completely undocumented.
>>   Barry
>> On May 23, 2024, at 2:16 PM, Colton Bryant <
>> Hi Barry,
>> I saw that was reporting as an unused option and the error message I sent
>> was run with -fieldsplit_0_ksp_type preonly.
>> -Colton
>> On Thu, May 23, 2024 at 12:13 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>    Sorry I gave the wrong option. Use  -fieldsplit_0_ksp_type preonly
>>> Barry
>>> On May 23, 2024, at 12:51 PM, Colton Bryant <
>>> That produces the error:
>>> [0]PETSC ERROR: Residual norm computed by GMRES recursion formula
>>> 2.68054e-07 is far from the computed residual norm 6.86309e-06 at restart,
>>> residual norm at start of cycle 2.68804e-07
>>> The rest of the error is identical.
>>> On Thu, May 23, 2024 at 10:46 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>>   Use -pc_fieldsplit_0_ksp_type preonly
>>>> On May 23, 2024, at 12:43 PM, Colton Bryant <
>>>> That produces the following error:
>>>> 2.79175e-07 is far from the computed residual norm 0.000113154 at restart,
>>>> residual norm at start of cycle 2.83065e-07
>>>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!eHxid0vR_Oq4B4_2xQfLg8TwCHSypxeshF2stG1z1p0_AqRPJ0nwTZlAyhArCS__aZuybvfmGtTLuAtMLsCePBg6n627v_VOQ313YZE5bEg$  for trouble
>>>> shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.21.0, unknown
>>>> [0]PETSC ERROR: ./mainOversetLS_exe on a arch-linux-c-opt named glass
>>>> by colton Thu May 23 10:41:09 2024
>>>> [0]PETSC ERROR: Configure options --download-mpich --with-cc=gcc
>>>> --with-cxx=g++ --with-debugging=no --with-fc=gfortran COPTFLAGS=-O3
>>>> CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=arch-linux-c-opt --download-sowing
>>>> [0]PETSC ERROR: #1 KSPGMRESCycle() at
>>>> /home/colton/petsc/src/ksp/ksp/impls/gmres/gmres.c:115
>>>> [0]PETSC ERROR: #2 KSPSolve_GMRES() at
>>>> /home/colton/petsc/src/ksp/ksp/impls/gmres/gmres.c:227
>>>> [0]PETSC ERROR: #3 KSPSolve_Private() at
>>>> /home/colton/petsc/src/ksp/ksp/interface/itfunc.c:905
>>>> [0]PETSC ERROR: #4 KSPSolve() at
>>>> /home/colton/petsc/src/ksp/ksp/interface/itfunc.c:1078
>>>> [0]PETSC ERROR: #5 PCApply_FieldSplit_Schur() at
>>>> /home/colton/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c:1203
>>>> [0]PETSC ERROR: #6 PCApply() at
>>>> /home/colton/petsc/src/ksp/pc/interface/precon.c:497
>>>> [0]PETSC ERROR: #7 KSP_PCApply() at
>>>> /home/colton/petsc/include/petsc/private/kspimpl.h:409
>>>> [0]PETSC ERROR: #8 KSPFGMRESCycle() at
>>>> /home/colton/petsc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c:123
>>>> [0]PETSC ERROR: #9 KSPSolve_FGMRES() at
>>>> /home/colton/petsc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c:235
>>>> [0]PETSC ERROR: #10 KSPSolve_Private() at
>>>> [0]PETSC ERROR: #11 KSPSolve() at
>>>> [0]PETSC ERROR: #12 solveStokes() at cartesianStokesGrid.cpp:1403
>>>> On Thu, May 23, 2024 at 10:33 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>   Run the failing case with also -ksp_error_if_not_converged so we see
>>>>> exactly where the problem is first detected.
>>>>> On May 23, 2024, at 11:51 AM, Colton Bryant <
>>>>> Hi Barry,
>>>>> Thanks for letting me know about the need to use fgmres in this case.
>>>>> I ran a smaller problem (1230 in the first block) and saw similar behavior
>>>>> in the true residual.
>>>>> I also ran the same problem with the options -fieldsplit_0_pc_type svd
>>>>> -fieldsplit_0_pc_svd_monitor and get the following output:
>>>>>       SVD: condition number 1.933639985881e+03, 0 of 1230 singular
>>>>> values are (nearly) zero
>>>>>       SVD: smallest singular values: 4.132036392141e-03
>>>>> 4.166444542385e-03 4.669534028645e-03 4.845532162256e-03 5.047038625390e-03
>>>>>       SVD: largest singular values : 7.947990616611e+00
>>>>> 7.961437414477e+00 7.961851612473e+00 7.971335373142e+00 7.989870790960e+00
>>>>> I would be surprised if the A_{00} block is ill conditioned as it's
>>>>> just a standard discretization of the laplacian with some rows replaced
>>>>> with ones on the diagonal due to interpolations from the overset mesh. I'm
>>>>> wondering if I'm somehow violating a solvability condition of the problem?
>>>>> Thanks for the help!
>>>>> -Colton
>>>>> On Wed, May 22, 2024 at 6:09 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>   Thanks for the info. I see you are using GMRES inside the Schur
>>>>>> complement solver, this is ok but when you do you need to use fgmres as the
>>>>>> outer solver. But this is unlikely to be the cause of the exact problem you
>>>>>> are seeing.
>>>>>>   I'm not sure why the Schur complement KSP is suddenly seeing a
>>>>>> large increase in the true residual norm.  Is it possible the A_{00} block
>>>>>> is ill-conditioned?
>>>>>>    Can you run with a smaller problem? Say 2,000 or so in the first
>>>>>> block? Is there still a problem?
>>>>>> On May 22, 2024, at 6:00 PM, Colton Bryant <
>>>>>> Hi Barry,
>>>>>> I have not used any other solver parameters in the code and the full
>>>>>> set of solver related command line options are those I mentioned in the
>>>>>> previous email.
>>>>>> Below is the output from -ksp_view:
>>>>>> KSP Object: (back_) 1 MPI process
>>>>>>   type: gmres
>>>>>>     restart=30, using Classical (unmodified) Gram-Schmidt
>>>>>> Orthogonalization with no iterative refinement
>>>>>>     happy breakdown tolerance 1e-30
>>>>>>   maximum iterations=10000, initial guess is zero
>>>>>>   tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
>>>>>>   left preconditioning
>>>>>>   using PRECONDITIONED norm type for convergence test
>>>>>> PC Object: (back_) 1 MPI process
>>>>>>   type: fieldsplit
>>>>>>     FieldSplit with Schur preconditioner, blocksize = 1,
>>>>>> factorization FULL
>>>>>>     Preconditioner for the Schur complement formed from S itself
>>>>>>     Split info:
>>>>>>     Split number 0 Defined by IS
>>>>>>     Split number 1 Defined by IS
>>>>>>     KSP solver for A00 block
>>>>>>       KSP Object: (back_fieldsplit_0_) 1 MPI process
>>>>>>         type: gmres
>>>>>>         tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>>>>>>       PC Object: (back_fieldsplit_0_) 1 MPI process
>>>>>>         type: lu
>>>>>>           out-of-place factorization
>>>>>>           tolerance for zero pivot 2.22045e-14
>>>>>>           matrix ordering: nd
>>>>>>           factor fill ratio given 5., needed 8.83482
>>>>>>             Factored matrix follows:
>>>>>>               Mat Object: (back_fieldsplit_0_) 1 MPI process
>>>>>>                 type: seqaij
>>>>>>                 rows=30150, cols=30150
>>>>>>                 package used to perform factorization: petsc
>>>>>>                 total: nonzeros=2649120, allocated nonzeros=2649120
>>>>>>                   using I-node routines: found 15019 nodes, limit
>>>>>> used is 5
>>>>>>         linear system matrix = precond matrix:
>>>>>>           type: seqaij
>>>>>>           total: nonzeros=299850, allocated nonzeros=299850
>>>>>>           total number of mallocs used during MatSetValues calls=0
>>>>>>             using I-node routines: found 15150 nodes, limit used is 5
>>>>>>     KSP solver for S = A11 - A10 inv(A00) A01
>>>>>>       KSP Object: (back_fieldsplit_1_) 1 MPI process
>>>>>>         type: gmres
>>>>>>       PC Object: (back_fieldsplit_1_) 1 MPI process
>>>>>>         type: none
>>>>>>         Mat Object: (back_fieldsplit_1_) 1 MPI process
>>>>>>           type: schurcomplement
>>>>>>           rows=15000, cols=15000
>>>>>>             Schur complement A11 - A10 inv(A00) A01
>>>>>>             A11
>>>>>>                 type: seqaij
>>>>>>                 total: nonzeros=74700, allocated nonzeros=74700
>>>>>> calls=0
>>>>>>                   not using I-node routines
>>>>>>             A10
>>>>>>               Mat Object: 1 MPI process
>>>>>>                 type: seqaij
>>>>>>                 rows=15000, cols=30150
>>>>>>                 total: nonzeros=149550, allocated nonzeros=149550
>>>>>> calls=0
>>>>>>             KSP solver for A00 block viewable with the additional
>>>>>> option -back_fieldsplit_0_ksp_view
>>>>>>             A01
>>>>>>                 type: seqaij
>>>>>>                 rows=30150, cols=15000
>>>>>> calls=0
>>>>>> used is 5
>>>>>>   Mat Object: (back_) 1 MPI process
>>>>>>     type: seqaij
>>>>>>     rows=45150, cols=45150
>>>>>>     total: nonzeros=673650, allocated nonzeros=673650
>>>>>>       has attached null space
>>>>>> Thanks again!
>>>>>> -Colton
>>>>>> On Wed, May 22, 2024 at 3:39 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>>   Are you using any other command line options or did you hardwire
>>>>>>> any solver parameters in the code with, like, KSPSetXXX() or PCSetXXX()
>>>>>>> Please send all of them.
>>>>>>>   Something funky definitely happened when the true residual norms
>>>>>>> jumped up.
>>>>>>>   Could you run the same thing with -ksp_view and don't use any
>>>>>>> thing like -ksp_error_if_not_converged so we can see exactly what is being
>>>>>>> run.
>>>>>>>   Barry
>>>>>>> On May 22, 2024, at 3:21 PM, Colton Bryant <
>>>>>>> This Message Is From an External Sender
>>>>>>> This message came from outside your organization.
>>>>>>> Hello,
>>>>>>> I am solving the Stokes equations on a MAC grid discretized by
>>>>>>> finite differences using a DMSTAG object. I have tested the solver quite
>>>>>>> extensively on manufactured problems and it seems to work well. As I am
>>>>>>> still just trying to get things working and not yet worried about speed I
>>>>>>> am using the following solver options:
>>>>>>> -pc_type fieldsplit
>>>>>>> -fieldsplit_0_pc_type lu
>>>>>>> -fieldsplit_1_ksp_rtol 1.e-8
>>>>>>> However I am now using this solver as an inner step of a larger code
>>>>>>> and have run into issues. The code repeatedly solves the Stokes equations
>>>>>>> with varying right hand sides coming from changing problem geometry (the
>>>>>>> solver is a part of an overset grid scheme coupled to a level set method
>>>>>>> evolving in time). After a couple timesteps I observe the following output
>>>>>>> when running with -fieldsplit_1_ksp_converged_reason
>>>>>>> -fieldsplit_1_ksp_monitor_true_residual:
>>>>>>> Residual norms for back_fieldsplit_1_ solve.
>>>>>>>     0 KSP preconditioned resid norm 2.826514299465e-02 true resid
>>>>>>> norm 2.826514299465e-02 ||r(i)||/||b|| 1.000000000000e+00
>>>>>>>     1 KSP preconditioned resid norm 7.286621865915e-03 true resid
>>>>>>> norm 7.286621865915e-03 ||r(i)||/||b|| 2.577953300039e-01
>>>>>>>     2 KSP preconditioned resid norm 1.500598474492e-03 true resid
>>>>>>> norm 1.500598474492e-03 ||r(i)||/||b|| 5.309007192273e-02
>>>>>>>     3 KSP preconditioned resid norm 3.796396924978e-04 true resid
>>>>>>> norm 3.796396924978e-04 ||r(i)||/||b|| 1.343137349666e-02
>>>>>>>     4 KSP preconditioned resid norm 8.091057439816e-05 true resid
>>>>>>> norm 8.091057439816e-05 ||r(i)||/||b|| 2.862556697960e-03
>>>>>>>     5 KSP preconditioned resid norm 3.689113122359e-05 true resid
>>>>>>> norm 3.689113122359e-05 ||r(i)||/||b|| 1.305181128239e-03
>>>>>>>     6 KSP preconditioned resid norm 2.116450533352e-05 true resid
>>>>>>> norm 2.116450533352e-05 ||r(i)||/||b|| 7.487846545662e-04
>>>>>>>     7 KSP preconditioned resid norm 3.968234031201e-06 true resid
>>>>>>> norm 3.968234031200e-06 ||r(i)||/||b|| 1.403932055801e-04
>>>>>>>     8 KSP preconditioned resid norm 6.666949419511e-07 true resid
>>>>>>> norm 6.666949419506e-07 ||r(i)||/||b|| 2.358717739644e-05
>>>>>>>     9 KSP preconditioned resid norm 1.941522884928e-07 true resid
>>>>>>> norm 1.941522884931e-07 ||r(i)||/||b|| 6.868965372998e-06
>>>>>>>    10 KSP preconditioned resid norm 6.729545258682e-08 true resid
>>>>>>> norm 6.729545258626e-08 ||r(i)||/||b|| 2.380863687793e-06
>>>>>>>    11 KSP preconditioned resid norm 3.009070131709e-08 true resid
>>>>>>> norm 3.009070131735e-08 ||r(i)||/||b|| 1.064586912687e-06
>>>>>>>    12 KSP preconditioned resid norm 7.849353009588e-09 true resid
>>>>>>> norm 7.849353009903e-09 ||r(i)||/||b|| 2.777043445840e-07
>>>>>>>    13 KSP preconditioned resid norm 2.306283345754e-09 true resid
>>>>>>> norm 2.306283346677e-09 ||r(i)||/||b|| 8.159461097060e-08
>>>>>>>    14 KSP preconditioned resid norm 9.336302495083e-10 true resid
>>>>>>> norm 9.336302502503e-10 ||r(i)||/||b|| 3.303115255517e-08
>>>>>>>    15 KSP preconditioned resid norm 6.537456143401e-10 true resid
>>>>>>> norm 6.537456141617e-10 ||r(i)||/||b|| 2.312903968982e-08
>>>>>>>    16 KSP preconditioned resid norm 6.389159552788e-10 true resid
>>>>>>> norm 6.389159550304e-10 ||r(i)||/||b|| 2.260437724130e-08
>>>>>>>    17 KSP preconditioned resid norm 6.380905134246e-10 true resid
>>>>>>> norm 6.380905136023e-10 ||r(i)||/||b|| 2.257517372981e-08
>>>>>>>    18 KSP preconditioned resid norm 6.380440605992e-10 true resid
>>>>>>> norm 6.380440604688e-10 ||r(i)||/||b|| 2.257353025207e-08
>>>>>>>    19 KSP preconditioned resid norm 6.380427156582e-10 true resid
>>>>>>> norm 6.380427157894e-10 ||r(i)||/||b|| 2.257348267830e-08
>>>>>>>    20 KSP preconditioned resid norm 6.380426714897e-10 true resid
>>>>>>> norm 6.380426714004e-10 ||r(i)||/||b|| 2.257348110785e-08
>>>>>>>    21 KSP preconditioned resid norm 6.380426656970e-10 true resid
>>>>>>> norm 6.380426658839e-10 ||r(i)||/||b|| 2.257348091268e-08
>>>>>>>    22 KSP preconditioned resid norm 6.380426650538e-10 true resid
>>>>>>> norm 6.380426650287e-10 ||r(i)||/||b|| 2.257348088242e-08
>>>>>>>    23 KSP preconditioned resid norm 6.380426649918e-10 true resid
>>>>>>> norm 6.380426645888e-10 ||r(i)||/||b|| 2.257348086686e-08
>>>>>>>    24 KSP preconditioned resid norm 6.380426649803e-10 true resid
>>>>>>> norm 6.380426644294e-10 ||r(i)||/||b|| 2.257348086122e-08
>>>>>>>    25 KSP preconditioned resid norm 6.380426649796e-10 true resid
>>>>>>> norm 6.380426649774e-10 ||r(i)||/||b|| 2.257348088061e-08
>>>>>>>    26 KSP preconditioned resid norm 6.380426649795e-10 true resid
>>>>>>> norm 6.380426653788e-10 ||r(i)||/||b|| 2.257348089481e-08
>>>>>>>    27 KSP preconditioned resid norm 6.380426649795e-10 true resid
>>>>>>> norm 6.380426646744e-10 ||r(i)||/||b|| 2.257348086989e-08
>>>>>>>    28 KSP preconditioned resid norm 6.380426649795e-10 true resid
>>>>>>> norm 6.380426650818e-10 ||r(i)||/||b|| 2.257348088430e-08
>>>>>>>    29 KSP preconditioned resid norm 6.380426649795e-10 true resid
>>>>>>> norm 6.380426649518e-10 ||r(i)||/||b|| 2.257348087970e-08
>>>>>>>    30 KSP preconditioned resid norm 6.380426652142e-10 true resid
>>>>>>> norm 6.380426652142e-10 ||r(i)||/||b|| 2.257348088898e-08
>>>>>>>    31 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426646799e-10 ||r(i)||/||b|| 2.257348087008e-08
>>>>>>>    32 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426648077e-10 ||r(i)||/||b|| 2.257348087460e-08
>>>>>>>    33 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426649048e-10 ||r(i)||/||b|| 2.257348087804e-08
>>>>>>>    34 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426648142e-10 ||r(i)||/||b|| 2.257348087483e-08
>>>>>>>    35 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426651079e-10 ||r(i)||/||b|| 2.257348088522e-08
>>>>>>>    36 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426650433e-10 ||r(i)||/||b|| 2.257348088294e-08
>>>>>>>    37 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426649765e-10 ||r(i)||/||b|| 2.257348088057e-08
>>>>>>>    38 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426650364e-10 ||r(i)||/||b|| 2.257348088269e-08
>>>>>>>    39 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426650051e-10 ||r(i)||/||b|| 2.257348088159e-08
>>>>>>>    40 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426651154e-10 ||r(i)||/||b|| 2.257348088549e-08
>>>>>>>    41 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426650246e-10 ||r(i)||/||b|| 2.257348088227e-08
>>>>>>>    42 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426650702e-10 ||r(i)||/||b|| 2.257348088389e-08
>>>>>>>    43 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426651686e-10 ||r(i)||/||b|| 2.257348088737e-08
>>>>>>>    44 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426650870e-10 ||r(i)||/||b|| 2.257348088448e-08
>>>>>>>    45 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426651208e-10 ||r(i)||/||b|| 2.257348088568e-08
>>>>>>>    46 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426651441e-10 ||r(i)||/||b|| 2.257348088650e-08
>>>>>>>    47 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426650955e-10 ||r(i)||/||b|| 2.257348088478e-08
>>>>>>>    48 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426650877e-10 ||r(i)||/||b|| 2.257348088451e-08
>>>>>>>    49 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426651240e-10 ||r(i)||/||b|| 2.257348088579e-08
>>>>>>>    50 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426650534e-10 ||r(i)||/||b|| 2.257348088329e-08
>>>>>>>    51 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426648615e-10 ||r(i)||/||b|| 2.257348087651e-08
>>>>>>>    52 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>>> norm 6.380426649523e-10 ||r(i)||/||b|| 2.257348087972e-08
>>>>>>>    53 KSP preconditioned resid norm 6.380426652140e-10 true resid
>>>>>>> norm 6.380426652601e-10 ||r(i)||/||b|| 2.257348089061e-08
>>>>>>>    54 KSP preconditioned resid norm 6.380426652125e-10 true resid
>>>>>>> norm 6.380427512852e-10 ||r(i)||/||b|| 2.257348393411e-08
>>>>>>>    55 KSP preconditioned resid norm 6.380426651849e-10 true resid
>>>>>>> norm 6.380603444402e-10 ||r(i)||/||b|| 2.257410636701e-08
>>>>>>>    56 KSP preconditioned resid norm 6.380426646751e-10 true resid
>>>>>>> norm 6.439925413105e-10 ||r(i)||/||b|| 2.278398313542e-08
>>>>>>>    57 KSP preconditioned resid norm 6.380426514019e-10 true resid
>>>>>>> norm 2.674218007058e-09 ||r(i)||/||b|| 9.461186902765e-08
>>>>>>>    58 KSP preconditioned resid norm 6.380425077384e-10 true resid
>>>>>>> norm 2.406759314486e-08 ||r(i)||/||b|| 8.514937691775e-07
>>>>>>>    59 KSP preconditioned resid norm 6.380406171326e-10 true resid
>>>>>>> norm 3.100137288622e-07 ||r(i)||/||b|| 1.096805803957e-05
>>>>>>>     Linear back_fieldsplit_1_ solve did not converge due to
>>>>>>> DIVERGED_BREAKDOWN iterations 60
>>>>>>> Any advice on steps I could take to elucidate the issue would be
>>>>>>> greatly appreciated. Thanks so much for any help in advance!
>>>>>>> Best,
>>>>>>> Colton Bryant
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240530/7d8ba77b/attachment-0001.html>
