[petsc-users] Question on MatMatmult
Zhang, Hong
hzhang at mcs.anl.gov
Wed May 29 09:37:24 CDT 2024
Frank,
We do not have support of MatMatMult() for BAIJ*BAIJ matrices. For BAIJ matrix, we only support BAIJ*DENSE. You may have to convert BAIJ to AIJ to use MatMatMult().
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Frank Bramkamp <bramkamp at nsc.liu.se>
Sent: Wednesday, May 29, 2024 9:23 AM
To: petsc-users <petsc-users at mcs.anl.gov>
Subject: [petsc-users] Question on MatMatmult
Dear PETSc Team, I would like to make a matrix-matrix product of two matrices. I try to use CALL MatMatMult(Mat_A,MAT_B,MAT_INITIAL_MATRIX,PETSC_DEFAULT_REAL,MAT_AB,IERROR). // calling from fortran When I try to use this function I get the
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Dear PETSc Team,
I try to use
When I try to use this function I get the following error message:
"Unspecified symbolic phase for product AB with A seqbaij, B seqbaij. The product is not supported”
I am using the seqbaij matrix format. Is MatMatMult and MatProductSymbolic
only defined for the standard point-wise matrix format but not for a blocked format ?!
In the documentation, I could not see a hint on supported matrix formats or any limitations.
The examples also just use a point-wise format (AIJ), as I can see so far.
Greetings, Frank Bramkamp
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240529/6cd59548/attachment.html>
