[petsc-users] Modify matrix nonzero structure
Adrian Croucher
a.croucher at auckland.ac.nz
Mon May 27 21:42:23 CDT 2024
Hmm, that's a bit weird. I haven't modified the test code - I checked
the file date to make sure. I also tried deleting my PETSc build dir and
rebuilding it, then rebuilding the test code. I still get the error if I
run on 2 ranks with -dm_mat_type (or -mat_type) baij or mpibaij, but
it's fine on aij or mpiaij.
My actual (non-test) code is however working ok now, in serial or
parallel. So I don't think this should hold up merging your bugfix.
- Adrian
On 28/05/24 2:13 pm, Barry Smith wrote:
> When I run the exact code you sent with two ranks and—mat_type
> mpibaij, it runs as expected. If you modified the code in any way to
> demonstrate the bug, please send the modified code.
>> On May 27, 2024, at 9:37 PM, Adrian Croucher
>> <a.croucher at auckland.ac.nz> wrote:
>> hi Barry,
>> On 28/05/24 7:46 am, Barry Smith wrote:
>>> Thanks for reporting this. It is a bug. I have a fixed branch
>>> *barry/2024-05-27/fix-bug-baij-setvaluesblocked/release * and
>>> associated merge request
>>> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7578__;!!G_uCfscf7eWS!dtDmIxQzHvnehLcuzdtJxWThxViUdu26r8fjum7PCvvKQp2PyZxpEZ0D1gvG1OsEvRs-sAisLmK-51Z7g4GONJEssSbd8xUJ$
>> Thanks very much, that does appear to fix the bug when I run my test
>> program in serial.
>> If I run it on 2 processes, it is OK with AIJ matrix type, but with
>> BAIJ I get an error (see below). Is there another problem, or I am
>> doing something else wrong?
>> - Adrian
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Petsc has generated inconsistent data
>> [0]PETSC ERROR: Incorrect colmap
>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!dtDmIxQzHvnehLcuzdtJxWThxViUdu26r8fjum7PCvvKQp2PyZxpEZ0D1gvG1OsEvRs-sAisLmK-51Z7g4GONJEssfaywInx$ for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.21.1, unknown
>> [0]PETSC ERROR: ./matmodify on a main-debug named EN438880 by acro018
>> Tue May 28 13:33:46 2024
>> [0]PETSC ERROR: Configure options --with-x --download-hdf5
>> --download-zlib --download-netcdf --download-pnetcdf
>> --download-exodusii --download-triangle --download-ptscotch
>> --download-chaco --download-hypre
>> [0]PETSC ERROR: #1 MatSetValuesBlocked_MPIBAIJ() at
>> /home/acro018/software/PETSc/code/src/mat/impls/baij/mpi/mpibaij.c:448
>> [0]PETSC ERROR: #2 MatSetValuesBlocked() at
>> /home/acro018/software/PETSc/code/src/mat/interface/matrix.c:2030
>> [0]PETSC ERROR: It appears a new error in the code was triggered
>> after a previous error, possibly because:
>> [0]PETSC ERROR: - The first error was not properly handled via
>> (for example) the use of
>> [0]PETSC ERROR: PetscCall(TheFunctionThatErrors()); or
>> [0]PETSC ERROR: - The second error was triggered while handling
>> the first error.
>> [0]PETSC ERROR: Above is the traceback for the previous unhandled
>> error, below the traceback for the next error
>> [0]PETSC ERROR: ALL ERRORS in the PETSc libraries are fatal, you
>> should add the appropriate error checking to the code
>> [0]PETSC ERROR: #2 MatAssemblyEnd_MPIBAIJ() at
>> /home/acro018/software/PETSc/code/src/mat/impls/baij/mpi/mpibaij.c:943
>> [0]PETSC ERROR: #3 MatAssemblyEnd() at
>> /home/acro018/software/PETSc/code/src/mat/interface/matrix.c:5820
>> [0]PETSC ERROR: #4 matmodify.F90:40
>>> Barry
>>>> On May 26, 2024, at 10:45 PM, Adrian Croucher
>>>> hi,
>>>> I've been trying creating a matrix with DMCreateMatrix() and then
>>>> adding extra blocks of nonzeros into it using
>>>> MatSetValuesBlocked(), but getting some unexpected results if I set
>>>> the matrix type to BAIJ. It seems to behave as expected if I use
>>>> matrix type AIJ.
>>>> I've attached a minimal example program. It reads in the DMPlex
>>>> from file, sets up a section on it, creates a matrix (blocksize 2)
>>>> and then inserts a single 2x2 block at global block indices (0,7).
>>>> It views the matrix before and after the insertion.
>>>> If I run with "-dm_mat_type aij" it gives the expected results, but
>>>> with "-dm_mat_type baij" it doesn't - e.g. if run in serial, it
>>>> adds the new nonzeros in the right place but also adds a whole lot
>>>> of other duplicated entries in block row 0.
>>>> Is there something I'm not understanding about BAIJ, or about
>>>> MatSetValuesBlocked()? or possibly some other mistake?
>>>> - Adrian
>>>> On 20/05/24 12:24 pm, Barry Smith wrote:
>>>>> You can call MatSetOption(mat,MAT_NEW_NONZERO_LOCATION_ERR)
>>>>> then insert the new values. If it is just a handful of new
>>>>> insertions the extra time should be small.
>>>>> Making a copy of the matrix won't give you a new matrix that
>>>>> is any faster to insert into so best to just use the same matrix.
>>>>> Barry
>>>>>> On May 19, 2024, at 7:44 PM, Adrian Croucher
>>>>>> This Message Is From an External Sender
>>>>>> This message came from outside your organization.
>>>>>> hi,
>>>>>> I have a Jacobian matrix created using DMCreateMatrix(). What would be
>>>>>> the best way to add extra nonzero entries into it?
>>>>>> I'm guessing that DMCreateMatrix() allocates the storage so the nonzero
>>>>>> structure can't really be easily modified. Would it be a case of
>>>>>> creating a new matrix, copying the nonzero entries from the original one
>>>>>> and then adding the extra ones, before calling MatSetUp() or similar? If
>>>>>> so, how exactly would you copy the nonzero structure from the original
>>>>>> matrix?
>>>>>> Background: the flow problem I'm solving (on a DMPlex with finite volume
>>>>>> method) has complex source terms that depend on the solution (e.g.
>>>>>> pressure), and can also depend on other source terms. A simple example
>>>>>> is when fluid is extracted from one location, with a pressure-dependent
>>>>>> flow rate, and some of it is then reinjected in another location. This
>>>>>> can result in poor nonlinear solver convergence. I think the reason is
>>>>>> that there are effectively missing Jacobian entries in the row for the
>>>>>> reinjection cell, which should have an additional dependence on the
>>>>>> solution in the cell where fluid is extracted.
>>>>>> - Adrian
>>>>>> Dr Adrian Croucher
>>>>>> Senior Research Fellow
>>>>>> Department of Engineering Science
>>>>>> Waipapa Taumata Rau / University of Auckland, New Zealand
>>>>>> email:a.croucher at auckland.ac.nz
>>>>>> tel: +64 (0)9 923 4611
>>>> Dr Adrian Croucher
>>>> <3x3grid.exo><matmodify.F90>
>> Dr Adrian Croucher
Dr Adrian Croucher
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240528/6fa43d81/attachment-0001.html>
