[petsc-users] Diagnosing Convergence Issue in Fieldsplit Problem
Colton Bryant
coltonbryant2021 at u.northwestern.edu
Thu May 23 13:43:16 CDT 2024
Yes, the original operator definitely has a constant null space
corresponding to the constant pressure mode. I am currently handling this
by using the MatSetNullSpace function when the matrix is being created.
Does this information get passed to the submatrices of the fieldsplit?
-Colton
On Thu, May 23, 2024 at 12:36 PM Barry Smith <bsmith at petsc.dev> wrote:
> Ok,
> So what is happening is that GMRES with a restart of 30 is running on
> the Schur complement system with no preconditioning and LU (as a direct
> solver) is being used in the application of S (the Schur complement). The
> convergence of GMRES is stagnating after getting about 8 digits of accuracy
> in the residual. Then at the second GMRES
> restart it is comparing the explicitly computing residual b - Ax with that
> computed inside the GMRES algorithm (via a recursive formula) and finding a
> large difference so generating an error. Since you are using a direct
> solver on the A_{00} block and it is well-conditioned this problem is not
> expected.
> Is it possible that the S operator has a null space (perhaps of the
> constant vector)? Or, relatedly, does your original full matrix have a null
> space?
> We have a way to associated null spaces of the submatrices in
> PCFIELDSPLIT by attaching them to the IS that define the fields, but
> unfortunately not trivially when using -pc_fieldsplit_detect_saddle_point.
> And sadly the current support seems completely undocumented.
> Barry
> On May 23, 2024, at 2:16 PM, Colton Bryant <
> coltonbryant2021 at u.northwestern.edu> wrote:
> Hi Barry,
> I saw that was reporting as an unused option and the error message I sent
> was run with -fieldsplit_0_ksp_type preonly.
> -Colton
> On Thu, May 23, 2024 at 12:13 PM Barry Smith <bsmith at petsc.dev> wrote:
>> Sorry I gave the wrong option. Use -fieldsplit_0_ksp_type preonly
>> Barry
>> On May 23, 2024, at 12:51 PM, Colton Bryant <
>> That produces the error:
>> [0]PETSC ERROR: Residual norm computed by GMRES recursion formula
>> 2.68054e-07 is far from the computed residual norm 6.86309e-06 at restart,
>> residual norm at start of cycle 2.68804e-07
>> The rest of the error is identical.
>> On Thu, May 23, 2024 at 10:46 AM Barry Smith <bsmith at petsc.dev> wrote:
>>> Use -pc_fieldsplit_0_ksp_type preonly
>>> On May 23, 2024, at 12:43 PM, Colton Bryant <
>>> That produces the following error:
>>> 2.79175e-07 is far from the computed residual norm 0.000113154 at restart,
>>> residual norm at start of cycle 2.83065e-07
>>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!aHWJfYufqSwgiA17iAHR0cE5dtx0vFkWJgFdirxQmSy__IYOi9ZtKDa3Qu9Ikh-Yj15tnuGl678edZxCaWoiSHFkTcL1O5l1oWPACScr9kM$ for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.21.0, unknown
>>> [0]PETSC ERROR: ./mainOversetLS_exe on a arch-linux-c-opt named glass by
>>> colton Thu May 23 10:41:09 2024
>>> [0]PETSC ERROR: Configure options --download-mpich --with-cc=gcc
>>> --with-cxx=g++ --with-debugging=no --with-fc=gfortran COPTFLAGS=-O3
>>> CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 PETSC_ARCH=arch-linux-c-opt --download-sowing
>>> [0]PETSC ERROR: #1 KSPGMRESCycle() at
>>> /home/colton/petsc/src/ksp/ksp/impls/gmres/gmres.c:115
>>> [0]PETSC ERROR: #2 KSPSolve_GMRES() at
>>> /home/colton/petsc/src/ksp/ksp/impls/gmres/gmres.c:227
>>> [0]PETSC ERROR: #3 KSPSolve_Private() at
>>> /home/colton/petsc/src/ksp/ksp/interface/itfunc.c:905
>>> [0]PETSC ERROR: #4 KSPSolve() at
>>> /home/colton/petsc/src/ksp/ksp/interface/itfunc.c:1078
>>> [0]PETSC ERROR: #5 PCApply_FieldSplit_Schur() at
>>> /home/colton/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c:1203
>>> [0]PETSC ERROR: #6 PCApply() at
>>> /home/colton/petsc/src/ksp/pc/interface/precon.c:497
>>> [0]PETSC ERROR: #7 KSP_PCApply() at
>>> /home/colton/petsc/include/petsc/private/kspimpl.h:409
>>> [0]PETSC ERROR: #8 KSPFGMRESCycle() at
>>> /home/colton/petsc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c:123
>>> [0]PETSC ERROR: #9 KSPSolve_FGMRES() at
>>> /home/colton/petsc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c:235
>>> [0]PETSC ERROR: #10 KSPSolve_Private() at
>>> [0]PETSC ERROR: #11 KSPSolve() at
>>> [0]PETSC ERROR: #12 solveStokes() at cartesianStokesGrid.cpp:1403
>>> On Thu, May 23, 2024 at 10:33 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>> Run the failing case with also -ksp_error_if_not_converged so we see
>>>> exactly where the problem is first detected.
>>>> On May 23, 2024, at 11:51 AM, Colton Bryant <
>>>> Hi Barry,
>>>> Thanks for letting me know about the need to use fgmres in this case. I
>>>> ran a smaller problem (1230 in the first block) and saw similar behavior in
>>>> the true residual.
>>>> I also ran the same problem with the options -fieldsplit_0_pc_type svd
>>>> -fieldsplit_0_pc_svd_monitor and get the following output:
>>>> SVD: condition number 1.933639985881e+03, 0 of 1230 singular
>>>> values are (nearly) zero
>>>> SVD: smallest singular values: 4.132036392141e-03
>>>> 4.166444542385e-03 4.669534028645e-03 4.845532162256e-03 5.047038625390e-03
>>>> SVD: largest singular values : 7.947990616611e+00
>>>> 7.961437414477e+00 7.961851612473e+00 7.971335373142e+00 7.989870790960e+00
>>>> I would be surprised if the A_{00} block is ill conditioned as it's
>>>> just a standard discretization of the laplacian with some rows replaced
>>>> with ones on the diagonal due to interpolations from the overset mesh. I'm
>>>> wondering if I'm somehow violating a solvability condition of the problem?
>>>> Thanks for the help!
>>>> -Colton
>>>> On Wed, May 22, 2024 at 6:09 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>> Thanks for the info. I see you are using GMRES inside the Schur
>>>>> complement solver, this is ok but when you do you need to use fgmres as the
>>>>> outer solver. But this is unlikely to be the cause of the exact problem you
>>>>> are seeing.
>>>>> I'm not sure why the Schur complement KSP is suddenly seeing a large
>>>>> increase in the true residual norm. Is it possible the A_{00} block is
>>>>> ill-conditioned?
>>>>> Can you run with a smaller problem? Say 2,000 or so in the first
>>>>> block? Is there still a problem?
>>>>> On May 22, 2024, at 6:00 PM, Colton Bryant <
>>>>> Hi Barry,
>>>>> I have not used any other solver parameters in the code and the full
>>>>> set of solver related command line options are those I mentioned in the
>>>>> previous email.
>>>>> Below is the output from -ksp_view:
>>>>> KSP Object: (back_) 1 MPI process
>>>>> type: gmres
>>>>> restart=30, using Classical (unmodified) Gram-Schmidt
>>>>> Orthogonalization with no iterative refinement
>>>>> happy breakdown tolerance 1e-30
>>>>> maximum iterations=10000, initial guess is zero
>>>>> tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
>>>>> left preconditioning
>>>>> using PRECONDITIONED norm type for convergence test
>>>>> PC Object: (back_) 1 MPI process
>>>>> type: fieldsplit
>>>>> FieldSplit with Schur preconditioner, blocksize = 1, factorization
>>>>> FULL
>>>>> Preconditioner for the Schur complement formed from S itself
>>>>> Split info:
>>>>> Split number 0 Defined by IS
>>>>> Split number 1 Defined by IS
>>>>> KSP solver for A00 block
>>>>> KSP Object: (back_fieldsplit_0_) 1 MPI process
>>>>> type: gmres
>>>>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>>>>> PC Object: (back_fieldsplit_0_) 1 MPI process
>>>>> type: lu
>>>>> out-of-place factorization
>>>>> tolerance for zero pivot 2.22045e-14
>>>>> matrix ordering: nd
>>>>> factor fill ratio given 5., needed 8.83482
>>>>> Factored matrix follows:
>>>>> Mat Object: (back_fieldsplit_0_) 1 MPI process
>>>>> type: seqaij
>>>>> rows=30150, cols=30150
>>>>> package used to perform factorization: petsc
>>>>> total: nonzeros=2649120, allocated nonzeros=2649120
>>>>> using I-node routines: found 15019 nodes, limit used
>>>>> is 5
>>>>> linear system matrix = precond matrix:
>>>>> type: seqaij
>>>>> total: nonzeros=299850, allocated nonzeros=299850
>>>>> total number of mallocs used during MatSetValues calls=0
>>>>> using I-node routines: found 15150 nodes, limit used is 5
>>>>> KSP solver for S = A11 - A10 inv(A00) A01
>>>>> KSP Object: (back_fieldsplit_1_) 1 MPI process
>>>>> type: gmres
>>>>> PC Object: (back_fieldsplit_1_) 1 MPI process
>>>>> type: none
>>>>> Mat Object: (back_fieldsplit_1_) 1 MPI process
>>>>> type: schurcomplement
>>>>> rows=15000, cols=15000
>>>>> Schur complement A11 - A10 inv(A00) A01
>>>>> A11
>>>>> type: seqaij
>>>>> total: nonzeros=74700, allocated nonzeros=74700
>>>>> calls=0
>>>>> not using I-node routines
>>>>> A10
>>>>> Mat Object: 1 MPI process
>>>>> type: seqaij
>>>>> rows=15000, cols=30150
>>>>> total: nonzeros=149550, allocated nonzeros=149550
>>>>> calls=0
>>>>> KSP solver for A00 block viewable with the additional
>>>>> option -back_fieldsplit_0_ksp_view
>>>>> A01
>>>>> type: seqaij
>>>>> rows=30150, cols=15000
>>>>> calls=0
>>>>> is 5
>>>>> Mat Object: (back_) 1 MPI process
>>>>> type: seqaij
>>>>> rows=45150, cols=45150
>>>>> total: nonzeros=673650, allocated nonzeros=673650
>>>>> has attached null space
>>>>> Thanks again!
>>>>> -Colton
>>>>> On Wed, May 22, 2024 at 3:39 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>> Are you using any other command line options or did you hardwire
>>>>>> any solver parameters in the code with, like, KSPSetXXX() or PCSetXXX()
>>>>>> Please send all of them.
>>>>>> Something funky definitely happened when the true residual norms
>>>>>> jumped up.
>>>>>> Could you run the same thing with -ksp_view and don't use any thing
>>>>>> like -ksp_error_if_not_converged so we can see exactly what is being run.
>>>>>> Barry
>>>>>> On May 22, 2024, at 3:21 PM, Colton Bryant <
>>>>>> This Message Is From an External Sender
>>>>>> This message came from outside your organization.
>>>>>> Hello,
>>>>>> I am solving the Stokes equations on a MAC grid discretized by finite
>>>>>> differences using a DMSTAG object. I have tested the solver quite
>>>>>> extensively on manufactured problems and it seems to work well. As I am
>>>>>> still just trying to get things working and not yet worried about speed I
>>>>>> am using the following solver options:
>>>>>> -pc_type fieldsplit
>>>>>> -fieldsplit_0_pc_type lu
>>>>>> -fieldsplit_1_ksp_rtol 1.e-8
>>>>>> However I am now using this solver as an inner step of a larger code
>>>>>> and have run into issues. The code repeatedly solves the Stokes equations
>>>>>> with varying right hand sides coming from changing problem geometry (the
>>>>>> solver is a part of an overset grid scheme coupled to a level set method
>>>>>> evolving in time). After a couple timesteps I observe the following output
>>>>>> when running with -fieldsplit_1_ksp_converged_reason
>>>>>> -fieldsplit_1_ksp_monitor_true_residual:
>>>>>> Residual norms for back_fieldsplit_1_ solve.
>>>>>> 0 KSP preconditioned resid norm 2.826514299465e-02 true resid
>>>>>> norm 2.826514299465e-02 ||r(i)||/||b|| 1.000000000000e+00
>>>>>> 1 KSP preconditioned resid norm 7.286621865915e-03 true resid
>>>>>> norm 7.286621865915e-03 ||r(i)||/||b|| 2.577953300039e-01
>>>>>> 2 KSP preconditioned resid norm 1.500598474492e-03 true resid
>>>>>> norm 1.500598474492e-03 ||r(i)||/||b|| 5.309007192273e-02
>>>>>> 3 KSP preconditioned resid norm 3.796396924978e-04 true resid
>>>>>> norm 3.796396924978e-04 ||r(i)||/||b|| 1.343137349666e-02
>>>>>> 4 KSP preconditioned resid norm 8.091057439816e-05 true resid
>>>>>> norm 8.091057439816e-05 ||r(i)||/||b|| 2.862556697960e-03
>>>>>> 5 KSP preconditioned resid norm 3.689113122359e-05 true resid
>>>>>> norm 3.689113122359e-05 ||r(i)||/||b|| 1.305181128239e-03
>>>>>> 6 KSP preconditioned resid norm 2.116450533352e-05 true resid
>>>>>> norm 2.116450533352e-05 ||r(i)||/||b|| 7.487846545662e-04
>>>>>> 7 KSP preconditioned resid norm 3.968234031201e-06 true resid
>>>>>> norm 3.968234031200e-06 ||r(i)||/||b|| 1.403932055801e-04
>>>>>> 8 KSP preconditioned resid norm 6.666949419511e-07 true resid
>>>>>> norm 6.666949419506e-07 ||r(i)||/||b|| 2.358717739644e-05
>>>>>> 9 KSP preconditioned resid norm 1.941522884928e-07 true resid
>>>>>> norm 1.941522884931e-07 ||r(i)||/||b|| 6.868965372998e-06
>>>>>> 10 KSP preconditioned resid norm 6.729545258682e-08 true resid
>>>>>> norm 6.729545258626e-08 ||r(i)||/||b|| 2.380863687793e-06
>>>>>> 11 KSP preconditioned resid norm 3.009070131709e-08 true resid
>>>>>> norm 3.009070131735e-08 ||r(i)||/||b|| 1.064586912687e-06
>>>>>> 12 KSP preconditioned resid norm 7.849353009588e-09 true resid
>>>>>> norm 7.849353009903e-09 ||r(i)||/||b|| 2.777043445840e-07
>>>>>> 13 KSP preconditioned resid norm 2.306283345754e-09 true resid
>>>>>> norm 2.306283346677e-09 ||r(i)||/||b|| 8.159461097060e-08
>>>>>> 14 KSP preconditioned resid norm 9.336302495083e-10 true resid
>>>>>> norm 9.336302502503e-10 ||r(i)||/||b|| 3.303115255517e-08
>>>>>> 15 KSP preconditioned resid norm 6.537456143401e-10 true resid
>>>>>> norm 6.537456141617e-10 ||r(i)||/||b|| 2.312903968982e-08
>>>>>> 16 KSP preconditioned resid norm 6.389159552788e-10 true resid
>>>>>> norm 6.389159550304e-10 ||r(i)||/||b|| 2.260437724130e-08
>>>>>> 17 KSP preconditioned resid norm 6.380905134246e-10 true resid
>>>>>> norm 6.380905136023e-10 ||r(i)||/||b|| 2.257517372981e-08
>>>>>> 18 KSP preconditioned resid norm 6.380440605992e-10 true resid
>>>>>> norm 6.380440604688e-10 ||r(i)||/||b|| 2.257353025207e-08
>>>>>> 19 KSP preconditioned resid norm 6.380427156582e-10 true resid
>>>>>> norm 6.380427157894e-10 ||r(i)||/||b|| 2.257348267830e-08
>>>>>> 20 KSP preconditioned resid norm 6.380426714897e-10 true resid
>>>>>> norm 6.380426714004e-10 ||r(i)||/||b|| 2.257348110785e-08
>>>>>> 21 KSP preconditioned resid norm 6.380426656970e-10 true resid
>>>>>> norm 6.380426658839e-10 ||r(i)||/||b|| 2.257348091268e-08
>>>>>> 22 KSP preconditioned resid norm 6.380426650538e-10 true resid
>>>>>> norm 6.380426650287e-10 ||r(i)||/||b|| 2.257348088242e-08
>>>>>> 23 KSP preconditioned resid norm 6.380426649918e-10 true resid
>>>>>> norm 6.380426645888e-10 ||r(i)||/||b|| 2.257348086686e-08
>>>>>> 24 KSP preconditioned resid norm 6.380426649803e-10 true resid
>>>>>> norm 6.380426644294e-10 ||r(i)||/||b|| 2.257348086122e-08
>>>>>> 25 KSP preconditioned resid norm 6.380426649796e-10 true resid
>>>>>> norm 6.380426649774e-10 ||r(i)||/||b|| 2.257348088061e-08
>>>>>> 26 KSP preconditioned resid norm 6.380426649795e-10 true resid
>>>>>> norm 6.380426653788e-10 ||r(i)||/||b|| 2.257348089481e-08
>>>>>> 27 KSP preconditioned resid norm 6.380426649795e-10 true resid
>>>>>> norm 6.380426646744e-10 ||r(i)||/||b|| 2.257348086989e-08
>>>>>> 28 KSP preconditioned resid norm 6.380426649795e-10 true resid
>>>>>> norm 6.380426650818e-10 ||r(i)||/||b|| 2.257348088430e-08
>>>>>> 29 KSP preconditioned resid norm 6.380426649795e-10 true resid
>>>>>> norm 6.380426649518e-10 ||r(i)||/||b|| 2.257348087970e-08
>>>>>> 30 KSP preconditioned resid norm 6.380426652142e-10 true resid
>>>>>> norm 6.380426652142e-10 ||r(i)||/||b|| 2.257348088898e-08
>>>>>> 31 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426646799e-10 ||r(i)||/||b|| 2.257348087008e-08
>>>>>> 32 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426648077e-10 ||r(i)||/||b|| 2.257348087460e-08
>>>>>> 33 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426649048e-10 ||r(i)||/||b|| 2.257348087804e-08
>>>>>> 34 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426648142e-10 ||r(i)||/||b|| 2.257348087483e-08
>>>>>> 35 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426651079e-10 ||r(i)||/||b|| 2.257348088522e-08
>>>>>> 36 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426650433e-10 ||r(i)||/||b|| 2.257348088294e-08
>>>>>> 37 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426649765e-10 ||r(i)||/||b|| 2.257348088057e-08
>>>>>> 38 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426650364e-10 ||r(i)||/||b|| 2.257348088269e-08
>>>>>> 39 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426650051e-10 ||r(i)||/||b|| 2.257348088159e-08
>>>>>> 40 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426651154e-10 ||r(i)||/||b|| 2.257348088549e-08
>>>>>> 41 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426650246e-10 ||r(i)||/||b|| 2.257348088227e-08
>>>>>> 42 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426650702e-10 ||r(i)||/||b|| 2.257348088389e-08
>>>>>> 43 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426651686e-10 ||r(i)||/||b|| 2.257348088737e-08
>>>>>> 44 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426650870e-10 ||r(i)||/||b|| 2.257348088448e-08
>>>>>> 45 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426651208e-10 ||r(i)||/||b|| 2.257348088568e-08
>>>>>> 46 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426651441e-10 ||r(i)||/||b|| 2.257348088650e-08
>>>>>> 47 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426650955e-10 ||r(i)||/||b|| 2.257348088478e-08
>>>>>> 48 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426650877e-10 ||r(i)||/||b|| 2.257348088451e-08
>>>>>> 49 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426651240e-10 ||r(i)||/||b|| 2.257348088579e-08
>>>>>> 50 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426650534e-10 ||r(i)||/||b|| 2.257348088329e-08
>>>>>> 51 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426648615e-10 ||r(i)||/||b|| 2.257348087651e-08
>>>>>> 52 KSP preconditioned resid norm 6.380426652141e-10 true resid
>>>>>> norm 6.380426649523e-10 ||r(i)||/||b|| 2.257348087972e-08
>>>>>> 53 KSP preconditioned resid norm 6.380426652140e-10 true resid
>>>>>> norm 6.380426652601e-10 ||r(i)||/||b|| 2.257348089061e-08
>>>>>> 54 KSP preconditioned resid norm 6.380426652125e-10 true resid
>>>>>> norm 6.380427512852e-10 ||r(i)||/||b|| 2.257348393411e-08
>>>>>> 55 KSP preconditioned resid norm 6.380426651849e-10 true resid
>>>>>> norm 6.380603444402e-10 ||r(i)||/||b|| 2.257410636701e-08
>>>>>> 56 KSP preconditioned resid norm 6.380426646751e-10 true resid
>>>>>> norm 6.439925413105e-10 ||r(i)||/||b|| 2.278398313542e-08
>>>>>> 57 KSP preconditioned resid norm 6.380426514019e-10 true resid
>>>>>> norm 2.674218007058e-09 ||r(i)||/||b|| 9.461186902765e-08
>>>>>> 58 KSP preconditioned resid norm 6.380425077384e-10 true resid
>>>>>> norm 2.406759314486e-08 ||r(i)||/||b|| 8.514937691775e-07
>>>>>> 59 KSP preconditioned resid norm 6.380406171326e-10 true resid
>>>>>> norm 3.100137288622e-07 ||r(i)||/||b|| 1.096805803957e-05
>>>>>> Linear back_fieldsplit_1_ solve did not converge due to
>>>>>> DIVERGED_BREAKDOWN iterations 60
>>>>>> Any advice on steps I could take to elucidate the issue would be
>>>>>> greatly appreciated. Thanks so much for any help in advance!
>>>>>> Best,
>>>>>> Colton Bryant
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240523/386d9416/attachment-0001.html>
