[petsc-users] Diagnosing Convergence Issue in Fieldsplit Problem
Colton Bryant
coltonbryant2021 at u.northwestern.edu
Thu May 23 10:51:34 CDT 2024
Hi Barry,
Thanks for letting me know about the need to use fgmres in this case. I ran
a smaller problem (1230 in the first block) and saw similar behavior in the
true residual.
I also ran the same problem with the options -fieldsplit_0_pc_type svd
-fieldsplit_0_pc_svd_monitor and get the following output:
SVD: condition number 1.933639985881e+03, 0 of 1230 singular values
are (nearly) zero
SVD: smallest singular values: 4.132036392141e-03 4.166444542385e-03
4.669534028645e-03 4.845532162256e-03 5.047038625390e-03
SVD: largest singular values : 7.947990616611e+00 7.961437414477e+00
7.961851612473e+00 7.971335373142e+00 7.989870790960e+00
I would be surprised if the A_{00} block is ill conditioned as it's just a
standard discretization of the laplacian with some rows replaced with ones
on the diagonal due to interpolations from the overset mesh. I'm wondering
if I'm somehow violating a solvability condition of the problem?
Thanks for the help!
-Colton
On Wed, May 22, 2024 at 6:09 PM Barry Smith <bsmith at petsc.dev> wrote:
> Thanks for the info. I see you are using GMRES inside the Schur
> complement solver, this is ok but when you do you need to use fgmres as the
> outer solver. But this is unlikely to be the cause of the exact problem you
> are seeing.
> I'm not sure why the Schur complement KSP is suddenly seeing a large
> increase in the true residual norm. Is it possible the A_{00} block is
> ill-conditioned?
> Can you run with a smaller problem? Say 2,000 or so in the first block?
> Is there still a problem?
> On May 22, 2024, at 6:00 PM, Colton Bryant <
> coltonbryant2021 at u.northwestern.edu> wrote:
> Hi Barry,
> I have not used any other solver parameters in the code and the full set
> of solver related command line options are those I mentioned in the
> previous email.
> Below is the output from -ksp_view:
> KSP Object: (back_) 1 MPI process
> type: gmres
> restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object: (back_) 1 MPI process
> type: fieldsplit
> FieldSplit with Schur preconditioner, blocksize = 1, factorization FULL
> Preconditioner for the Schur complement formed from S itself
> Split info:
> Split number 0 Defined by IS
> Split number 1 Defined by IS
> KSP solver for A00 block
> KSP Object: (back_fieldsplit_0_) 1 MPI process
> type: gmres
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> PC Object: (back_fieldsplit_0_) 1 MPI process
> type: lu
> out-of-place factorization
> tolerance for zero pivot 2.22045e-14
> matrix ordering: nd
> factor fill ratio given 5., needed 8.83482
> Factored matrix follows:
> Mat Object: (back_fieldsplit_0_) 1 MPI process
> type: seqaij
> rows=30150, cols=30150
> package used to perform factorization: petsc
> total: nonzeros=2649120, allocated nonzeros=2649120
> using I-node routines: found 15019 nodes, limit used is 5
> linear system matrix = precond matrix:
> type: seqaij
> total: nonzeros=299850, allocated nonzeros=299850
> total number of mallocs used during MatSetValues calls=0
> using I-node routines: found 15150 nodes, limit used is 5
> KSP solver for S = A11 - A10 inv(A00) A01
> KSP Object: (back_fieldsplit_1_) 1 MPI process
> type: gmres
> PC Object: (back_fieldsplit_1_) 1 MPI process
> type: none
> Mat Object: (back_fieldsplit_1_) 1 MPI process
> type: schurcomplement
> rows=15000, cols=15000
> Schur complement A11 - A10 inv(A00) A01
> A11
> type: seqaij
> total: nonzeros=74700, allocated nonzeros=74700
> not using I-node routines
> A10
> Mat Object: 1 MPI process
> type: seqaij
> rows=15000, cols=30150
> total: nonzeros=149550, allocated nonzeros=149550
> KSP solver for A00 block viewable with the additional option
> -back_fieldsplit_0_ksp_view
> A01
> type: seqaij
> rows=30150, cols=15000
> Mat Object: (back_) 1 MPI process
> type: seqaij
> rows=45150, cols=45150
> total: nonzeros=673650, allocated nonzeros=673650
> has attached null space
> Thanks again!
> -Colton
> On Wed, May 22, 2024 at 3:39 PM Barry Smith <bsmith at petsc.dev> wrote:
>> Are you using any other command line options or did you hardwire any
>> solver parameters in the code with, like, KSPSetXXX() or PCSetXXX() Please
>> send all of them.
>> Something funky definitely happened when the true residual norms jumped
>> up.
>> Could you run the same thing with -ksp_view and don't use any thing
>> like -ksp_error_if_not_converged so we can see exactly what is being run.
>> Barry
>> On May 22, 2024, at 3:21 PM, Colton Bryant <
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> Hello,
>> I am solving the Stokes equations on a MAC grid discretized by finite
>> differences using a DMSTAG object. I have tested the solver quite
>> extensively on manufactured problems and it seems to work well. As I am
>> still just trying to get things working and not yet worried about speed I
>> am using the following solver options:
>> -pc_type fieldsplit
>> -pc_fieldsplit_detect_saddle_point
>> -fieldsplit_0_pc_type lu
>> -fieldsplit_1_ksp_rtol 1.e-8
>> However I am now using this solver as an inner step of a larger code and
>> have run into issues. The code repeatedly solves the Stokes equations with
>> varying right hand sides coming from changing problem geometry (the solver
>> is a part of an overset grid scheme coupled to a level set method evolving
>> in time). After a couple timesteps I observe the following output when
>> running with -fieldsplit_1_ksp_converged_reason
>> -fieldsplit_1_ksp_monitor_true_residual:
>> Residual norms for back_fieldsplit_1_ solve.
>> 0 KSP preconditioned resid norm 2.826514299465e-02 true resid norm
>> 2.826514299465e-02 ||r(i)||/||b|| 1.000000000000e+00
>> 1 KSP preconditioned resid norm 7.286621865915e-03 true resid norm
>> 7.286621865915e-03 ||r(i)||/||b|| 2.577953300039e-01
>> 2 KSP preconditioned resid norm 1.500598474492e-03 true resid norm
>> 1.500598474492e-03 ||r(i)||/||b|| 5.309007192273e-02
>> 3 KSP preconditioned resid norm 3.796396924978e-04 true resid norm
>> 3.796396924978e-04 ||r(i)||/||b|| 1.343137349666e-02
>> 4 KSP preconditioned resid norm 8.091057439816e-05 true resid norm
>> 8.091057439816e-05 ||r(i)||/||b|| 2.862556697960e-03
>> 5 KSP preconditioned resid norm 3.689113122359e-05 true resid norm
>> 3.689113122359e-05 ||r(i)||/||b|| 1.305181128239e-03
>> 6 KSP preconditioned resid norm 2.116450533352e-05 true resid norm
>> 2.116450533352e-05 ||r(i)||/||b|| 7.487846545662e-04
>> 7 KSP preconditioned resid norm 3.968234031201e-06 true resid norm
>> 3.968234031200e-06 ||r(i)||/||b|| 1.403932055801e-04
>> 8 KSP preconditioned resid norm 6.666949419511e-07 true resid norm
>> 6.666949419506e-07 ||r(i)||/||b|| 2.358717739644e-05
>> 9 KSP preconditioned resid norm 1.941522884928e-07 true resid norm
>> 1.941522884931e-07 ||r(i)||/||b|| 6.868965372998e-06
>> 10 KSP preconditioned resid norm 6.729545258682e-08 true resid norm
>> 6.729545258626e-08 ||r(i)||/||b|| 2.380863687793e-06
>> 11 KSP preconditioned resid norm 3.009070131709e-08 true resid norm
>> 3.009070131735e-08 ||r(i)||/||b|| 1.064586912687e-06
>> 12 KSP preconditioned resid norm 7.849353009588e-09 true resid norm
>> 7.849353009903e-09 ||r(i)||/||b|| 2.777043445840e-07
>> 13 KSP preconditioned resid norm 2.306283345754e-09 true resid norm
>> 2.306283346677e-09 ||r(i)||/||b|| 8.159461097060e-08
>> 14 KSP preconditioned resid norm 9.336302495083e-10 true resid norm
>> 9.336302502503e-10 ||r(i)||/||b|| 3.303115255517e-08
>> 15 KSP preconditioned resid norm 6.537456143401e-10 true resid norm
>> 6.537456141617e-10 ||r(i)||/||b|| 2.312903968982e-08
>> 16 KSP preconditioned resid norm 6.389159552788e-10 true resid norm
>> 6.389159550304e-10 ||r(i)||/||b|| 2.260437724130e-08
>> 17 KSP preconditioned resid norm 6.380905134246e-10 true resid norm
>> 6.380905136023e-10 ||r(i)||/||b|| 2.257517372981e-08
>> 18 KSP preconditioned resid norm 6.380440605992e-10 true resid norm
>> 6.380440604688e-10 ||r(i)||/||b|| 2.257353025207e-08
>> 19 KSP preconditioned resid norm 6.380427156582e-10 true resid norm
>> 6.380427157894e-10 ||r(i)||/||b|| 2.257348267830e-08
>> 20 KSP preconditioned resid norm 6.380426714897e-10 true resid norm
>> 6.380426714004e-10 ||r(i)||/||b|| 2.257348110785e-08
>> 21 KSP preconditioned resid norm 6.380426656970e-10 true resid norm
>> 6.380426658839e-10 ||r(i)||/||b|| 2.257348091268e-08
>> 22 KSP preconditioned resid norm 6.380426650538e-10 true resid norm
>> 6.380426650287e-10 ||r(i)||/||b|| 2.257348088242e-08
>> 23 KSP preconditioned resid norm 6.380426649918e-10 true resid norm
>> 6.380426645888e-10 ||r(i)||/||b|| 2.257348086686e-08
>> 24 KSP preconditioned resid norm 6.380426649803e-10 true resid norm
>> 6.380426644294e-10 ||r(i)||/||b|| 2.257348086122e-08
>> 25 KSP preconditioned resid norm 6.380426649796e-10 true resid norm
>> 6.380426649774e-10 ||r(i)||/||b|| 2.257348088061e-08
>> 26 KSP preconditioned resid norm 6.380426649795e-10 true resid norm
>> 6.380426653788e-10 ||r(i)||/||b|| 2.257348089481e-08
>> 27 KSP preconditioned resid norm 6.380426649795e-10 true resid norm
>> 6.380426646744e-10 ||r(i)||/||b|| 2.257348086989e-08
>> 28 KSP preconditioned resid norm 6.380426649795e-10 true resid norm
>> 6.380426650818e-10 ||r(i)||/||b|| 2.257348088430e-08
>> 29 KSP preconditioned resid norm 6.380426649795e-10 true resid norm
>> 6.380426649518e-10 ||r(i)||/||b|| 2.257348087970e-08
>> 30 KSP preconditioned resid norm 6.380426652142e-10 true resid norm
>> 6.380426652142e-10 ||r(i)||/||b|| 2.257348088898e-08
>> 31 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426646799e-10 ||r(i)||/||b|| 2.257348087008e-08
>> 32 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426648077e-10 ||r(i)||/||b|| 2.257348087460e-08
>> 33 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426649048e-10 ||r(i)||/||b|| 2.257348087804e-08
>> 34 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426648142e-10 ||r(i)||/||b|| 2.257348087483e-08
>> 35 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426651079e-10 ||r(i)||/||b|| 2.257348088522e-08
>> 36 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426650433e-10 ||r(i)||/||b|| 2.257348088294e-08
>> 37 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426649765e-10 ||r(i)||/||b|| 2.257348088057e-08
>> 38 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426650364e-10 ||r(i)||/||b|| 2.257348088269e-08
>> 39 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426650051e-10 ||r(i)||/||b|| 2.257348088159e-08
>> 40 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426651154e-10 ||r(i)||/||b|| 2.257348088549e-08
>> 41 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426650246e-10 ||r(i)||/||b|| 2.257348088227e-08
>> 42 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426650702e-10 ||r(i)||/||b|| 2.257348088389e-08
>> 43 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426651686e-10 ||r(i)||/||b|| 2.257348088737e-08
>> 44 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426650870e-10 ||r(i)||/||b|| 2.257348088448e-08
>> 45 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426651208e-10 ||r(i)||/||b|| 2.257348088568e-08
>> 46 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426651441e-10 ||r(i)||/||b|| 2.257348088650e-08
>> 47 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426650955e-10 ||r(i)||/||b|| 2.257348088478e-08
>> 48 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426650877e-10 ||r(i)||/||b|| 2.257348088451e-08
>> 49 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426651240e-10 ||r(i)||/||b|| 2.257348088579e-08
>> 50 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426650534e-10 ||r(i)||/||b|| 2.257348088329e-08
>> 51 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426648615e-10 ||r(i)||/||b|| 2.257348087651e-08
>> 52 KSP preconditioned resid norm 6.380426652141e-10 true resid norm
>> 6.380426649523e-10 ||r(i)||/||b|| 2.257348087972e-08
>> 53 KSP preconditioned resid norm 6.380426652140e-10 true resid norm
>> 6.380426652601e-10 ||r(i)||/||b|| 2.257348089061e-08
>> 54 KSP preconditioned resid norm 6.380426652125e-10 true resid norm
>> 6.380427512852e-10 ||r(i)||/||b|| 2.257348393411e-08
>> 55 KSP preconditioned resid norm 6.380426651849e-10 true resid norm
>> 6.380603444402e-10 ||r(i)||/||b|| 2.257410636701e-08
>> 56 KSP preconditioned resid norm 6.380426646751e-10 true resid norm
>> 6.439925413105e-10 ||r(i)||/||b|| 2.278398313542e-08
>> 57 KSP preconditioned resid norm 6.380426514019e-10 true resid norm
>> 2.674218007058e-09 ||r(i)||/||b|| 9.461186902765e-08
>> 58 KSP preconditioned resid norm 6.380425077384e-10 true resid norm
>> 2.406759314486e-08 ||r(i)||/||b|| 8.514937691775e-07
>> 59 KSP preconditioned resid norm 6.380406171326e-10 true resid norm
>> 3.100137288622e-07 ||r(i)||/||b|| 1.096805803957e-05
>> Linear back_fieldsplit_1_ solve did not converge due to
>> DIVERGED_BREAKDOWN iterations 60
>> Any advice on steps I could take to elucidate the issue would be greatly
>> appreciated. Thanks so much for any help in advance!
>> Best,
>> Colton Bryant
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240523/ec3a32b6/attachment-0001.html>
