[petsc-users] How to specify different MPI communication patterns.
Randall Mackie
rlmackie862 at gmail.com
Tue May 21 10:55:38 CDT 2024
Dear PETSc team,
A few years ago we were having some issue with MPI communications with large numbers of processes and subcomms, see this thread here:
https://urldefense.us/v3/__https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2020-April/040976.html__;!!G_uCfscf7eWS!fyPrzMKC4KZmxGO-HI0xUlOCbgwXod4O8q2h_6MjHqPLPj9ppLkgFkJUig-KqXgu6AX7pMhYtEpWOP_cCesCWcCk_Q$
We are once again encountering strange issues when running our code on a new cluster and after a month of various tests we have not found a solution, but we think it has something to do with network traffic and high MPI communications, similar perhaps to the thread from 3 years ago.
Is it still possible to change the communication pattern with the option -build_twosided_allreduce (and is that the right syntax?).
Are there other runtime options that we can try to change the MPI communication type for all underlying communications?
Thank you,
Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240521/24f39dd4/attachment.html>
