[petsc-users] DMPlex periodic face coordinates
Matteo Semplice
matteo.semplice at uninsubria.it
Wed May 15 11:07:26 CDT 2024
Il 14/05/24 15:02, Matthew Knepley ha scritto:
> On Tue, May 14, 2024 at 12:14 AM Matteo Semplice
> <matteo.semplice at uninsubria.it> wrote:
> Dear petsc-users, I am playing with DMPlexGetCellCoordinates and
> observing that it returns correct periodic coordinates for cells,
> but not for faces. More precisely, adding
> PetscCall(DMPlexGetHeightStratum(dm, 1, &fStart, &fEnd)); for
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> Dear petsc-users,
> I am playing with DMPlexGetCellCoordinates and observing that
> it returns correct periodic coordinates for cells, but not for faces.
> for (f = fStart; f < fEnd; ++f) {
> const PetscScalar *array;
> PetscScalar *x = NULL;
> PetscInt ndof;
> PetscBool isDG;
> PetscCall(DMPlexGetCellCoordinates(dm, f, &isDG, &ndof,
> &array, &x));
> PetscCheck(ndof % cdim == 0, PETSC_COMM_SELF,
> PETSC_ERR_ARG_INCOMP, "ndof not divisible by cdim");
> PetscCall(PetscPrintf(PETSC_COMM_SELF, "Face #%"
> PetscInt_FMT " coordinates\n", f - fStart));
> for (PetscInt i = 0; i < ndof; i += cdim)
> PetscCall(PetscScalarView(cdim, &x[i], PETSC_VIEWER_STDOUT_SELF));
> PetscCall(DMPlexRestoreCellCoordinates(dm, f, &isDG, &ndof,
> &array, &x));
> to src/dm/impls/plex/tutorials/ex8.c, I get
> $ ./ex8 -dm_plex_dim 2 -petscspace_degree 1 -dm_plex_simplex 0
> -dm_plex_box_faces 3,2 -dm_plex_box_bd periodic,none -dm_view
> -view_coord
> DM Object: box 1 MPI process
> type: plex
> box in 2 dimensions:
> Number of 0-cells per rank: 9
> Number of 1-cells per rank: 15
> Number of 2-cells per rank: 6
> Periodic mesh (PERIODIC, NONE) coordinates localized
> Element #2 coordinates
> 0: 6.6667e-01 0.0000e+00
> 0: 1.0000e+00 0.0000e+00 <<<----- correct
> 0: 1.0000e+00 5.0000e-01
> 0: 6.6667e-01 5.0000e-01
> Face #0 coordinates
> 0: 0.0000e+00 0.0000e+00
> 0: 3.3333e-01 0.0000e+00
> Face #1 coordinates
> Face #2 coordinates
> 0: 0.0000e+00 0.0000e+00 <<<---- should be (0.66,0.00) and
> (1.00,0.00)
> Is there a way to recover correct periodic coordinates in the case
> of periodic DMPLex?
> The way that periodic coordinates work is that it stores a DG
> coordinate field by cell. Faces default back to the vertices. You
> could think about also putting DG coordinates on faces, but no one
> had asked, and it is potentially expensive.
> If you really need them to keep going, face coordinates can be
> extracted from cell coordinates. Otherwise, I can do it after the
> PETSc Meeting. Or, we are happy to take contributions adding this.
Hi.
I mainly wanted to check that this was expected and not a result of a
setup of my DM. No need to change Petsc now except maybe issuing a
warning if the fallback to continuous coordinates will give wrong
results. As for my code, I think I can extract the info from the cell
coordinates in a pre-processing phase and if this crazy FV methods I am
implementing will survive for long enough, I'll think about contributing.
Just to double-check, can I assume that the order in which
DMPlexGetCellCoordinates returns the coordinates matches the ordering of
vertices in DMPlexGetCone for the uninterpolated DM, right?
Best
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240515/d54b9a7f/attachment-0001.html>
