[petsc-users] Using CUDA Graphs with MatComputeOperator
Junchao Zhang
junchao.zhang at gmail.com
Tue May 14 22:15:25 CDT 2024
I haven't used CUDA graph with PETSc. Do you happen to have a working
example so we can debug?
--Junchao Zhang
On Tue, May 14, 2024 at 6:08 PM Sreeram R Venkat <srvenkat at utexas.edu>
wrote:
> I have a MatShell object that I want to convert to a MATDENSECUDA.
> Normally, I use MatComputeOperator for this. However, I would now also like
> to use a CUDA Graph so that all the calls to MatMult are captured. I can
> wrap a code like for (int
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> wrap a code like
> for (int i = 0; i < N; i++)
> MatMult(A, x,y);
> in a CUDA Graph, and it runs fine. If I try to wrap MatComputeOperator in
> a graph, I get runtime errors like
> cuda error 906 (cudaErrorStreamCaptureImplicit) : operation would make
> the legacy stream depend on a capturing blocking stream
> I tried modifying the MatConvert_Shell routine to only put the graph
> around the main for loop, but that still gives the same errors. Is there a
> way to use CUDA Graphs here (either through a modified MatConvert_Shell or
> otherwise)?
> Thanks,
> Sreeram
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240514/0f2002a3/attachment-0001.html>
