[petsc-users] GMSH entities
Adrian Croucher a.croucher at auckland.ac.nz
Tue May 14 22:09:06 CDT 2024
hi Matt,
On 15/05/24 6:05 am, Matthew Knepley wrote:
> On Tue, May 14, 2024 at 9:07 AM Matthew Knepley <knepley at gmail.com> wrote:
>     On Mon, May 13, 2024 at 10:04 PM Adrian Croucher
>     <a.croucher at auckland.ac.nz> wrote:
>         On 14/05/24 1:44 pm, Matthew Knepley wrote:
>>         I wish GMsh was clearer about what is optional:
>>         https://urldefense.us/v3/__https://gmsh.info/doc/texinfo/gmsh.html*MSH-file-format__;Iw!!G_uCfscf7eWS!dbZ8R9PicaYRx4Y2IkPxvCoLlJ4lpsMbIAFBKbKZK5h5-2OTX5Ne-AwgOBHv2mJaHqg9uo5orDQYs2PaoAcpDmS65Au1g9uw$
>>         <https://urldefense.us/v3/__https://gmsh.info/doc/texinfo/gmsh.html*MSH-file-format__;Iw!!G_uCfscf7eWS!dbZ8R9PicaYRx4Y2IkPxvCoLlJ4lpsMbIAFBKbKZK5h5-2OTX5Ne-AwgOBHv2mJaHqg9uo5orDQYs2PaoAcpDmS65Au1g9uw$ >
>>         They do talk about it, but not exhaustively. GMsh always
>>         writes and $Entities block from what I can tell.
>>         I can make it optional, it just might take until after the
>>         PETSc Meeting.
>         Looks like $Entities are optional:
>         https://urldefense.us/v3/__https://gitlab.onelab.info/gmsh/gmsh/-/commit/b5feba2af57181ffa946d3f0c494b014603c6efa__;!!G_uCfscf7eWS!dbZ8R9PicaYRx4Y2IkPxvCoLlJ4lpsMbIAFBKbKZK5h5-2OTX5Ne-AwgOBHv2mJaHqg9uo5orDQYs2PaoAcpDmS65ISaNx6E$
>         <https://urldefense.us/v3/__https://gitlab.onelab.info/gmsh/gmsh/-/commit/b5feba2af57181ffa946d3f0c494b014603c6efa__;!!G_uCfscf7eWS!dbZ8R9PicaYRx4Y2IkPxvCoLlJ4lpsMbIAFBKbKZK5h5-2OTX5Ne-AwgOBHv2mJaHqg9uo5orDQYs2PaoAcpDmS65ISaNx6E$ >
>         I can also load a GMSH 4.1 file without $Entities into GMSH
>         itself and it doesn't complain, suggesting that they are
>         indeed optional.
>     Yes, but they are not careful to specify when a file can be
>     inconsistent. For instance, omitting the $Entities, but then
>     specifying entity numbers in the $Nodes block. I think they also
>     thought this was inconsistent, but then got user complaints. The
>     minimal example they show does exactly this.
>         If the $Entities aren't strictly needed for anything in DMPlex
>         (which I'm guessing they aren't, as the GMSH file format 2.2
>         doesn't even have them) then it would be useful not to require
>         them.
>     I put in some code for this:
>     https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7546__;!!G_uCfscf7eWS!dbZ8R9PicaYRx4Y2IkPxvCoLlJ4lpsMbIAFBKbKZK5h5-2OTX5Ne-AwgOBHv2mJaHqg9uo5orDQYs2PaoAcpDmS65MnfH9Hr$
>     <https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7546__;!!G_uCfscf7eWS!dbZ8R9PicaYRx4Y2IkPxvCoLlJ4lpsMbIAFBKbKZK5h5-2OTX5Ne-AwgOBHv2mJaHqg9uo5orDQYs2PaoAcpDmS65MnfH9Hr$ >
>     It just ignores entity numbers when there is no section.
> This merged, so now it should be fixed for you.
Thanks, that seems to fix the problem. Great!
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
Waipapa Taumata Rau / University of Auckland, New Zealand
email:a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240515/659db35e/attachment.html>
