[petsc-users] GMSH entities
Matthew Knepley
knepley at gmail.com
Mon May 13 20:44:14 CDT 2024
On Mon, May 13, 2024 at 9:33 PM Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> hi, We often create meshes in GMSH format using the meshio library. This
> works OK if we stick to GMSH file format 2. 2. If we use GMSH file format
> 4. 1, DMPlex can't read them because it expects the "Entities" section to
> be present: [0]PETSC
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> hi,
> works OK if we stick to GMSH file format 2.2.
> If we use GMSH file format 4.1, DMPlex can't read them because it
> expects the "Entities" section to be present:
> [0]PETSC ERROR: Unexpected data in file
> [0]PETSC ERROR: File is not a valid Gmsh file, expecting $Entities, not
> $Nodes
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ZfBS1KM5EBZ7ZJIu6lBKFcclVMmXteXsW8m9HBEZ5tIf0u_3duEFt9eXKF7FcorQSAQqD5SbJrYh4C8rX676S_IMI_sp6naX$ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision:
> v3.21.1-124-g2d06e2faec8 GIT Date: 2024-05-08 19:31:33 +0000
> [0]PETSC ERROR: waiwera on a main-debug named EN438880 by acro018 Tue
> May 14 11:25:54 2024
> [0]PETSC ERROR: Configure options --with-x --download-hdf5
> --download-zlib --download-netcdf --download-pnetcdf --download-exodusii
> --download-triangle --download-ptscotch --download-chaco --download-hypre
> [0]PETSC ERROR: #1 GmshExpect() at
> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexgmsh.c:270
> [0]PETSC ERROR: #2 DMPlexCreateGmsh() at
> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexgmsh.c:1608
> [0]PETSC ERROR: #3 DMPlexCreateGmshFromFile() at
> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexgmsh.c:1469
> [0]PETSC ERROR: #4 DMPlexCreateFromFile() at
> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexcreate.c:5804
> By default meshio doesn't seem to write the Entities section. From what
> I can gather, it is optional.
> Am I right that this section is not optional in DMPlex?
I wish GMsh was clearer about what is optional:
https://urldefense.us/v3/__https://gmsh.info/doc/texinfo/gmsh.html*MSH-file-format__;Iw!!G_uCfscf7eWS!fS2tI8aC3rUnGOv-LbLPj1PRyijAPB-EO54CwUBP6pNFD-VKeGE98pOHepNMSTP_krHBKTZNk92Bx01NrC-T$
They do talk about it, but not exhaustively. GMsh always writes and
$Entities block from what I can tell.
I can make it optional, it just might take until after the PETSc Meeting.
Matt
- Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> Waipapa Taumata Rau / University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fS2tI8aC3rUnGOv-LbLPj1PRyijAPB-EO54CwUBP6pNFD-VKeGE98pOHepNMSTP_krHBKTZNk92Bx1gj7y2J$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fS2tI8aC3rUnGOv-LbLPj1PRyijAPB-EO54CwUBP6pNFD-VKeGE98pOHepNMSTP_krHBKTZNk92Bx_9VtYPq$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240513/7c5c4e36/attachment-0001.html>
