[petsc-users] Can not find the header file for OpenMPI
Satish Balay
balay at mcs.anl.gov
Mon May 13 13:07:24 CDT 2024
> Includes: -I/usr/lib64/openmpi/include (*This is not the right include directory*)
So this is the only issue? Does this dir not exist? If so, you can try the following fix:
https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7545__;!!G_uCfscf7eWS!a7OhWBQn8Zp5RfRnLqjH2JjyNYkp3CksuvTPa8FN5YXKhfigeeaNOYe29DFk4jQywze4XBM6KGVRw1AFXd6_vj0$
However if this dir exists [i.e when --with-pkg-dir=DIR is specified and DIR/include exists] - configure will have no way of figuring out that this location is incorrect. And it should cause no harm to include it in compile commands.
Satish
On Mon, 13 May 2024, Satish Balay via petsc-users wrote:
> On Mon, 13 May 2024, neil liu wrote:
> > I also tried the 2nd way, it didn't work.
> configure.log attached is successful.
> Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --download-fblaslapack --with-mpi-dir=/usr/lib64/openmpi
> Compilers:
> C Compiler: /usr/lib64/openmpi/bin/mpicc -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -g3 -O0
> Version: gcc (GCC) 11.4.1 20231218 (Red Hat 11.4.1-3)
> C++ Compiler: /usr/lib64/openmpi/bin/mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-psabi -fstack-protector -fvisibility=hidden -g -O0 -std=gnu++20 -fPIC
> Version: g++ (GCC) 11.4.1 20231218 (Red Hat 11.4.1-3)
> Fortran Compiler: /usr/lib64/openmpi/bin/mpif90 -fPIC -Wall -ffree-line-length-none -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -g -O0
> Version: GNU Fortran (GCC) 11.4.1 20231218 (Red Hat 11.4.1-3)
> So the correct compilers from the specified mpi location /usr/lib64/openmpi got used.
> What problem are you seeing with this build?
> Satish
