[petsc-users] Can not find the header file for OpenMPI
Mon May 13 10:57:04 CDT 2024
If you are using mpicc/mpif90 as compilers from you pre-installed MPI - you don't need to list --with-mpi-include, --with-mpi-lib options.
As mentioned - you can do this either with:
[if you have then in PATH] --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
or:
--with-cc=MPI-DIR/bin/mpicc --with-cxx=MPI-DIR/bin/mpicxx --with-fc=MPI-DIR/bin/mpif90
or
--with-mpi-dir=MPI-DIR
If you are having trouble with any of the above modes - resend configure.log for it.
Satish
On Mon, 13 May 2024, neil liu wrote:
> Thanks. I want to use the preinstalled OpenMPI to configure petsc. For the
> preinstalled OpenMPI, the lib and include dir are at different places.
> Then how should I configure with this preinstalled OpenMPI?
> Thanks,
> $ mpicc --show
> gcc -I/usr/include/openmpi-x86_64 -Wl,-rpath -Wl,/usr/lib64/openmpi/lib
> -Wl,--enable-new-dtags -L/usr/lib64/openmpi/lib -lmpi
> [liuneil at localhost petsc]$ mpif90 --show
> gfortran -I/usr/include/openmpi-x86_64 -I/usr/lib64/openmpi/lib -Wl,-rpath
> -Wl,/usr/lib64/openmpi/lib -Wl,--enable-new-dtags -L/usr/lib64/openmpi/lib
> -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi
> On Mon, May 13, 2024 at 11:42 AM Satish Balay <balay at mcs.anl.gov> wrote:
> > You are misinterpreting  --with-mpi-include --with-mpi-lib options.
> > Any particular reason you want to use these options instead of mpi
> > compilers?
> > balay at p1 /home/balay
> > $ mpicc -show
> > gcc -I/home/balay/soft/mpich-4.0.1/include
> > -L/home/balay/soft/mpich-4.0.1/lib -Wl,-rpath
> > -Wl,/home/balay/soft/mpich-4.0.1/lib -Wl,--enable-new-dtags -lmpi
> > $ mpif90 -show
> > gfortran -fallow-argument-mismatch -I/home/balay/soft/mpich-4.0.1/include
> > -I/home/balay/soft/mpich-4.0.1/include -L/home/balay/soft/mpich-4.0.1/lib
> > -lmpifort -Wl,-rpath -Wl,/home/balay/soft/mpich-4.0.1/lib
> > i.e here I would use:
> > --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> > --with-mpi-include=/home/balay/soft/mpich-4.0.1/include
> > --with-mpi-lib="-L/home/balay/soft/mpich-4.0.1/lib -Wl,-rpath
> > -Wl,/home/balay/soft/mpich-4.0.1/lib -lmpifort -lmpi"
> > Satish
> > > Thanks, I tried the following, and it didn't work.
> > > ./configure --download-fblaslapack --with-mpi-lib=/usr/lib64/openmpi/lib
> > > --with-mpi-include=/usr/include/openmpi-x86_64
> > >                          Configuring PETSc to compile on your system
> > > TESTING: check from
> > > config.libraries(config/BuildSystem/config/libraries.py:186)
> > >            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > > details):
> > >   --with-mpi-lib=['/usr/lib64/openmpi/lib'] and
> > >   --with-mpi-include=['/usr/include/openmpi-x86_64'] did not work
> > > On Mon, May 13, 2024 at 11:32 AM Satish Balay <balay at mcs.anl.gov> wrote:
> > > > > Dear Petsc developers,
> > > > > I am trying to install Petsc with a preinstalled OpenMPi.
> > > > > ./configure --download-fblaslapack --with-mpi-dir=/usr/lib64/openmpi
> > > > --with-mpi-dir=DIR is a bit unique [wrt other pkg-dir options].
> > > > It means:
> > > > --with-cc=DIR/bin/mpicc --with-cxx=DIR/bin/mpicxx
> > --with-fc=DIR/bin/mpif90
> > > > > --with-mpi-incdir=/usr/include/openmpi-x86_64
> > > > There is no such configure option
> > > > > But the final information shows,
> > > > >   MPI:
> > > > >   Version:    3
> > > > >   Includes:   -I/usr/lib64/openmpi/include (*This is not the right
> > > > include
> > > > > directory*)
> > > > Can you send configure.log for this build [perhaps to petsc-maint]
> > > > Satish
> > > > >   mpiexec: /usr/lib64/openmpi/bin/mpiexec
> > > > >   Implementation: openmpi
> > > > >   OMPI_VERSION: 4.1.1
> > > > > Did I use the wrong way to include the incdir?
> > > > > Thanks,
> > > > > Xiaodong
