[petsc-users] HDF5 time step count
Matthew Knepley
knepley at gmail.com
Fri May 10 11:12:40 CDT 2024
On Fri, May 10, 2024 at 1:01 AM Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> hi Matt,
> On 10/05/24 12:15 am, Matthew Knepley wrote:
> I just tried to test it, but there doesn't seem to be a Fortran interface
>> for DMGetOutputSequenceLength().
> Pushed.
> Thanks. I tried it out and the error below was raised, looks like it's
> when it tries to destroy the viewer. It still runs ok when
> DMGetOutputSequenceLength() isn't called.
> Sorry, it looks like I did not close the group. I pushed an update. If
that is alright, I will merge it.
Thanks
Matt
> - Adrian
> [0]PETSC ERROR: Error in external library
> [0]PETSC ERROR: Error in HDF5 call H5Fclose() Status -1
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!cr7LJSXkch_z_JwHbQJLw6lOHNHIwlYHSs2EKuOgdO4WPY3yBsl64nAdyRiQX9blQC8KVSJZObA0YA9zG9uD$ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.21.1-124-g2d06e2faec8
> GIT Date: 2024-05-08 19:31:33 +0000
> [0]PETSC ERROR: ./initial_test on a main-debug named EN438880 by acro018
> Fri May 10 16:55:34 2024
> [0]PETSC ERROR: Configure options --with-x --download-hdf5 --download-zlib
> --download-netcdf --download-pnetcdf --download-exodusii
> --download-triangle --download-ptscotch --download-chaco --download-hypre
> [0]PETSC ERROR: #1 PetscViewerFileClose_HDF5() at
> /home/acro018/software/PETSc/code/src/sys/classes/viewer/impls/hdf5/hdf5v.c:107
> [0]PETSC ERROR: #2 PetscViewerDestroy_HDF5() at
> /home/acro018/software/PETSc/code/src/sys/classes/viewer/impls/hdf5/hdf5v.c:126
> [0]PETSC ERROR: #3 PetscViewerDestroy() at
> /home/acro018/software/PETSc/code/src/sys/classes/viewer/interface/view.c:101
> [0]PETSC ERROR: #4 ../src/initial.F90:497
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> Waipapa Taumata Rau / University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cr7LJSXkch_z_JwHbQJLw6lOHNHIwlYHSs2EKuOgdO4WPY3yBsl64nAdyRiQX9blQC8KVSJZObA0YLHcR0C8$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cr7LJSXkch_z_JwHbQJLw6lOHNHIwlYHSs2EKuOgdO4WPY3yBsl64nAdyRiQX9blQC8KVSJZObA0YDfia_zg$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240510/c7838566/attachment-0001.html>
