[petsc-users] Compiling PETSc in Polaris with gnu
Satish Balay
balay at mcs.anl.gov
Thu May 2 10:58:21 CDT 2024
I just tried a build (used default versions) - and the following builds for me [on the login node].
module use /soft/modulefiles
module load PrgEnv-gnu
module load cudatoolkit-standalone
module load cray-libsci
./configure --with-cc=cc --with-fc=ftn --with-cxx=CC --with-make-np=4 --with-cuda=1 --with-cudac=nvcc --with-cuda-arch=80 \
--with-debugging=0 COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 CUDAOPTFLAGS=-O2 --download-kokkos --download-kokkos-kernels
make
Satish
balay at polaris-login-01:~> module list
Currently Loaded Modules:
1) libfabric/1.15.2.0 4) darshan/3.4.4 7) cray-dsmml/0.2.2 10) cray-pals/1.3.4 13) PrgEnv-gnu/8.5.0
2) craype-network-ofi 5) gcc-native/12.3 8) cray-mpich/8.1.28 11) cray-libpals/1.3.4 14) cudatoolkit-standalone/12.2.2
3) perftools-base/23.12.0 6) craype/2.7.30 9) cray-pmi/6.1.13 12) craype-x86-milan 15) cray-libsci/23.12.5
On Thu, 2 May 2024, Junchao Zhang wrote:
> I used cudatoolkit-standalone/12.4.1 and gcc-12.3.
> Be sure to use the latest petsc/main or petsc/release, which contains fixes
> for Polaris.
> --Junchao Zhang
> On Thu, May 2, 2024 at 10:23 AM Satish Balay via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Try:
> > Satish
> > On Thu, 2 May 2024, Vanella, Marcos (Fed) via petsc-users wrote:
> > > Hi all, it seems the modules in Polaris have changed (can't find
> > cudatoolkit-standalone anymore).
> > > Does anyone have recent experience compiling the library with gnu and
> > cuda in the machine?
> > > Thank you!
> > > Marcos
