[petsc-users] ex19: Segmentation Violation when run with MUMPS on MacOS (arm64)
Fri Mar 29 10:48:27 CDT 2024
Could you:
- reinstall brew after the xcode upgrade (not just update) https://urldefense.us/v3/__https://petsc.org/main/install/install/*installing-on-macos__;Iw!!G_uCfscf7eWS!fr-mLHdhIQgT2IBZhK9C2IQMUAmTmneTF38VsNLrywxooidf1uunovfx8qJrr8-Y73tICazCqyaZ6SJ6ca6JXnQ$
- not use --LDFLAGS=-Wl,-ld_classic
And see if the problem persists?
Satish
On Fri, 29 Mar 2024, zeyu xia wrote:
> Dear PETSc team:
>         Recently I installed firedrake on MacOS (arm64) with the latest
> Xcode, and there seems some error with mumps. I ran two times of the
> command `make check`. The first time it just output wrong results, and the
> second time it raised an error with Segmentation Violation. Please see the
> files “make check.txt” and “configure.log” in the attachment.
>         I will certainly be happy and grateful if you can take some time to
> deal with this problem. Thanks for your patience.
> Best wishes,
> Zeyu Xia
