[petsc-users] Does ILU(15) still make sense or should just use LU?
Zhang, Hong hzhang at mcs.anl.gov
Wed Mar 27 16:59:46 CDT 2024
Ling,
ILU(level) is used for saving storage space with more computations. Normally, we use level=1 or 2. It does not make sense to use level 15. If you have sufficient space, LU would be the best.
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Zou, Ling via petsc-users <petsc-users at mcs.anl.gov>
Sent: Wednesday, March 27, 2024 4:24 PM
To: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: [petsc-users] Does ILU(15) still make sense or should just use LU?
Hi, I’d like to avoid using LU, but in some cases to use ILU and still converge, I have to go to ILU(15), i.e., `-pc_factor_levels 15`. Does it still make sense, or should I give it up and switch to LU?
For this particular case, ~2k DoF, and both ILU(15) and LU perform similarly in terms of wall time.
-Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240327/363d3172/attachment.html>
