[petsc-users] snes matrix-free jacobian fails with preconditioner shape mismatch
Yi Hu
y.hu at mpie.de
Thu Mar 14 16:43:37 CDT 2024
Dear Mark,
Thanks for your response. I found the bug. I used wrong M N when
MatCreateShell(). Now it works in both uniprocessor and mpirun cases.
Best,
Yi
On 3/11/24 13:10, Mark Adams wrote:
> I think you misunderstand "global" vector. The global solution is
> never on one processor. A global vector in this case seems to have 81
> global values and 27 local values.
> It looks like you create a "global" vector that has 81 local values
> that should never be created other than for debigging.
> GlobalToLocal refers to a "local" vector with ghost cells, so it would
> have > 27 values in this case and you use it for local operations only
> (its communicator is PETSC_COMM_SELF).
> Hope this helps,
> Mark
> On Mon, Mar 11, 2024 at 4:48 AM Yi Hu <y.hu at mpie.de> wrote:
> Dear Barry,
> Thanks for your response. Now I am doing simple debugging for my
> customized mat_mult_op of my shell jacobian matrix. As far as I
> understand, because the input and output of shell jacobian are all
> global vectors, I need to do the global to local mapping of my
> input vector (dF) by myself. Before starting debugging the
> mapping, I first try to verify the size match of input and output.
> Because the input and output of a mat_mult_op of my shell matrix
> should have the same size. So I tried just equating them in my
> customized mat_mult_op. Basically like this
> subroutineGK_op(Jac,dF_global,output_global,err_PETSc)
> DM :: dm_local ! Yi: later for is,ie
> Vec :: dF_global
> Vec :: output_global
> PetscErrorCode :: err_PETSc
> real(pREAL), pointer,dimension(:,:,:,:) ::dF_scal, output_scal
> callSNESGetDM(SNES_mech,dm_local,err_PETSc)
> CHKERRQ(err_PETSc)
> output_global =dF_global
> end subroutineGK_op
> When I run with mpirun -np 3, it gives me similar error like
> previous, “Preconditioner number of local rows 27 does not equal
> input vector size 81”, (I changed my problem size so the numbers
> are different).
> Maybe simple equating input and output is not valid (due to
> ownership of different portion of a global vector). Then it may
> give me different error message. In fact my global dF has size
> 9*3*3*3, when running on 3 processors, the local dF has size
> 9*3*3*1 (I split my domain in z direction). The error message
> seems to suggest I am using a local dF rather than a global dF.
> And the output and input vector sizes seems to be different. Do I
> miss something here?
> Best regards,
> Yi
> *From:*Barry Smith <bsmith at petsc.dev>
> *Sent:* Sunday, March 10, 2024 6:45 PM
> *To:* Yi Hu <y.hu at mpie.de>
> *Cc:* Mark Adams <mfadams at lbl.gov>; petsc-users
> <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] snes matrix-free jacobian fails with
> On Mar 10, 2024, at 10:16 AM, Yi Hu <y.hu at mpie.de> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear Mark,
> Thanks for your reply. I see this mismatch. In fact my global
> DoF is 324. It seems like I always get the local size = global
> Dof / np^2, np is my processor number. By the way, I used
> DMDASNESsetFunctionLocal() to set my form function. Is it
> eligible to mix DMDASNESsetFunctionLocal() and a native
> SNESSetJacobian()?
> Yes
> Best,
> Yi
> On 3/10/24 13:55, Mark Adams wrote:
> It looks like your input vector is the global vector, size
> 162, and the local matrix size is 81.
> Mark
> [1]PETSC ERROR: Preconditioner number of local rows 81
> does not equal
> input vector size 162
> On Sun, Mar 10, 2024 at 7:21 AM Yi Hu <y.hu at mpie.de> wrote:
> *This Message Is From an External Sender*
> Dear petsc team,
> I implemented a matrix-free jacobian, and it can run
> sequentially. But
> running parallel I got the pc error like this (running
> with mpirun -np
> 2, only error from rank1 is presented here)
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Nonconforming object sizes
> does not equal
> [1]PETSC ERROR: See
> https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ahmistzr4wD3TJ0OvI0JWxB9aVSIbP78Jcs2X_6KMb4LdoR8drLB_DkHvaguhrca22RgFer0PlyUrtdfCA$
> <https://urldefense.us/v3/__https:/petsc.org/release/faq/__;!!G_uCfscf7eWS!ahmistzr4wD3TJ0OvI0JWxB9aVSIbP78Jcs2X_6KMb4LdoR8drLB_DkHvaguhrca22RgFer0PlyUrtdfCA$>
> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.17.3, Jun 29, 2022
> [1]PETSC ERROR:
> /home/yi/workspace/DAMASK_yi/bin/DAMASK_grid on a
> arch-linux-c-opt named carbon-x1 by yi Sun Mar 10
> 12:01:46 2024
> [1]PETSC ERROR: Configure options --download-fftw
> --download-hdf5
> --with-hdf5-fortran-bindings --download-fblaslapack
> --download-chaco
> --download-hypre --download-metis --download-mumps
> --download-parmetis
> --download-scalapack --download-suitesparse
> --download-superlu
> --download-superlu_dist --download-triangle
> --download-zlib
> --download-cmake --with-cxx-dialect=C++11 --with-c2html=0
> --with-debugging=0 --with-ssl=0 --with-x=0
> COPTFLAGS=-O3 CXXOPTFLAGS=-O3
> FOPTFLAGS=-O3
> [1]PETSC ERROR: #1 PCApply() at
> /home/yi/App/petsc-3.17.3/src/ksp/pc/interface/precon.c:424
> [1]PETSC ERROR: #2 KSP_PCApply() at
> /home/yi/App/petsc-3.17.3/include/petsc/private/kspimpl.h:376
> [1]PETSC ERROR: #3 KSPInitialResidual() at
> /home/yi/App/petsc-3.17.3/src/ksp/ksp/interface/itres.c:64
> [1]PETSC ERROR: #4 KSPSolve_GMRES() at
> /home/yi/App/petsc-3.17.3/src/ksp/ksp/impls/gmres/gmres.c:242
> [1]PETSC ERROR: #5 KSPSolve_Private() at
> /home/yi/App/petsc-3.17.3/src/ksp/ksp/interface/itfunc.c:902
> [1]PETSC ERROR: #6 KSPSolve() at
> /home/yi/App/petsc-3.17.3/src/ksp/ksp/interface/itfunc.c:1078
> [1]PETSC ERROR: #7 SNESSolve_NEWTONLS() at
> /home/yi/App/petsc-3.17.3/src/snes/impls/ls/ls.c:222
> [1]PETSC ERROR: #8 SNESSolve() at
> /home/yi/App/petsc-3.17.3/src/snes/interface/snes.c:4756
> [1]PETSC ERROR: #9 User provided function() at User file:0
> However, from snes matrix-free documentation
> (https://urldefense.us/v3/__https://petsc.org/release/manual/snes/*matrix-free-methods__;Iw!!G_uCfscf7eWS!ahmistzr4wD3TJ0OvI0JWxB9aVSIbP78Jcs2X_6KMb4LdoR8drLB_DkHvaguhrca22RgFer0Ply6ZbywOw$
> <https://urldefense.us/v3/__https:/petsc.org/release/manual/snes/*matrix-free-methods__;Iw!!G_uCfscf7eWS!ahmistzr4wD3TJ0OvI0JWxB9aVSIbP78Jcs2X_6KMb4LdoR8drLB_DkHvaguhrca22RgFer0Ply6ZbywOw$>),
> it is said
> matrix-free is used with pcnone. So I assume it would
> not apply
> preconditioner, but it did use preconditioning
> probably the same as my
> matrix-free shell matrix. Here is how i initialize my
> shell matrix and
> the corresponding customized multiplication.
> call
> MatCreateShell(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,&
> int(9*product(cells(1:2))*cells3,pPETSCINT),&
> F_PETSc,Jac_PETSc,err_PETSc)
> call
> MatShellSetOperation(Jac_PETSc,MATOP_MULT,GK_op,err_PETSc)
> call SNESSetDM(SNES_mech,DM_mech,err_PETSc)
> call
> SNESSetJacobian(SNES_mech,Jac_PETSc,Jac_PETSc,PETSC_NULL_FUNCTION,0,err_PETSc)
> call SNESGetKSP(SNES_mech,ksp,err_PETSc)
> call PCSetType(pc,PCNONE,err_PETSc)
> And my GK_op is like
> subroutine GK_op(Jac,dF_global,output_local,err_PETSc)
> DM :: dm_local
> Vec :: dF_global,
> dF_local, output_local
> Mat :: Jac
> real(pREAL), pointer,dimension(:,:,:,:) :: dF_scal,
> output_scal
> real(pREAL), dimension(3,3,cells(1),cells(2),cells3)
> dF
> output
> call SNESGetDM(SNES_mech,dm_local,err_PETSc)
> call DMGetLocalVector(dm_local,dF_local,err_PETSc)
> call
> DMGlobalToLocalBegin(dm_local,dF_global,INSERT_VALUES,dF_local,err_PETSc)
> call
> DMGlobalToLocalEnd(dm_local,dF_global,INSERT_VALUES,dF_local,err_PETSc)
> call
> DMDAVecGetArrayReadF90(dm_local,dF_local,dF_scal,err_PETSc)
> dF = reshape(dF_scal, [3,3,cells(1),cells(2),cells3])
> call
> DMDAVecRestoreArrayF90(dm_local,output_local,output_scal,err_PETSc)
> CHKERRQ(err_PETSc)
> call
> DMDAVecRestoreArrayF90(dm_local,dF_local,dF_scal,err_PETSc)
> CHKERRQ(err_PETSc)
> end subroutine GK_op
> I checked my cells3, it corresponds to my local size,
> and it seems the
> local size of dF_local is ok.
> I am a bit lost here to find the reason for the
> preconditioner bug.
> Could you help me on this? Thanks.
> Best regards,
> Yi
> Stay up to date and follow us on LinkedIn, Twitter and
> YouTube.
> Max-Planck-Institut für Eisenforschung GmbH
> Max-Planck-Straße 1
> D-40237 Düsseldorf
> Handelsregister B 2533
> Amtsgericht Düsseldorf
> Geschäftsführung
> Prof. Dr. Gerhard Dehm
> Prof. Dr. Jörg Neugebauer
> Prof. Dr. Dierk Raabe
> Dr. Kai de Weldige
> Ust.-Id.-Nr.: DE 11 93 58 514
> Steuernummer: 105 5891 1000
> Please consider that invitations and e-mails of our
> institute are
> only valid if they end with …@mpie.de
> <https://urldefense.us/v3/__http:/mpie.de__;!!G_uCfscf7eWS!eslPb6ZEnby8M7NKRe_U_RT-95w2J8O2ngsc8rmrQVlMpEcB6ZTKlN2g65crXCWv7D2F9ubkzYI5nDpoeQ$>.
> If you are not sure of the validity please contact
> rco at mpie.de
> Bitte beachten Sie, dass Einladungen zu
> Veranstaltungen und E-Mails
> aus unserem Haus nur mit der Endung …@mpie.de
> gültig sind.
> In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
> Stay up to date and follow us on LinkedIn, Twitter and YouTube.
> Max-Planck-Straße 1
> D-40237 Düsseldorf
> Geschäftsführung
> Dr. Kai de Weldige
> Please consider that invitations and e-mails of our institute are
> only valid if they end with …@mpie.de <https://urldefense.us/v3/__http://mpie.de__;!!G_uCfscf7eWS!cggahkQVL4itzNc4xCIuB95w85Py0YzJ_d0ueBg3CxKFPTOpO7ANg7u8XPX1w9DBPF_tpI5-RXi12HTwVA$ >.
> If you are not sure of the validity please contact rco at mpie.de
> <mailto:rco at mpie.de>
> Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
> <https://urldefense.us/v3/__http://mpie.de__;!!G_uCfscf7eWS!cggahkQVL4itzNc4xCIuB95w85Py0YzJ_d0ueBg3CxKFPTOpO7ANg7u8XPX1w9DBPF_tpI5-RXi12HTwVA$ > gültig sind.
> Max-Planck-Straße 1
> D-40237 Düsseldorf
> Geschäftsführung
> Dr. Kai de Weldige
Max-Planck-Straße 1
D-40237 Düsseldorf
Geschäftsführung
Dr. Kai de Weldige
only valid if they end with …@mpie.de.
aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240314/65d3394a/attachment-0001.html>
