[petsc-users] Help with SLEPc eigenvectors convergence.
Pierre Jolivet pierre at joliv.et
Thu Mar 7 01:01:00 CST 2024
It seems your A is rank-deficient.
If you slightly regularize the GEVP, e.g., -st_target 1.0E-6, you’ll get errors closer to 0.
Pierre
> On 6 Mar 2024, at 8:57 PM, Eric Chamberland via petsc-users <petsc-users at mcs.anl.gov> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Hi,
> we have a simple generalized Hermitian problem  (Kirchhoff plate
> vibration) for which we are comparing SLEPc results with Matlab results.
> SLEPc computes eigenvalues correctly, as Matlab does.
> However, the output eigenvectors are not fully converged and we are
> trying to understand where we have missed a convergence parameter or
> anything else about eigenvectors.
> SLEPc warns us at the end of EPSSolve with this message:
>   Problem: some of the first 10 relative errors are higher than the
> tolerance
> And in fact, when we import the resulting vectors into Matlab,
> "A*x-B*Lambda*x" isn't close to 0.
> Here are attached the EPS view output as the A and B matrices used.
> Any help or insights will be appreciated! :)
> Thanks,
> Eric
> <epsview.txt><matrice0_gen.m><matrice1_gen.m>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240307/b153bc85/attachment-0001.html>
