[petsc-users] Running CG with HYPRE AMG preconditioner in AMD GPUs
Mark Adams
mfadams at lbl.gov
Tue Mar 5 13:41:45 CST 2024
You can run with -log_view_gpu_time to get rid of the nans and get more
data.
You can run with -ksp_view to get more info on the solver and send that
output.
-options_left is also good to use so we can see what parameters you used.
The last 100 in this row:
KSPSolve 1197 0.0 2.0291e+02 0.0 2.55e+11 0.0 3.9e+04 8.0e+04
3.1e+04 12 100 100 100 49 12 100 100 100 98 2503 -nan 0 1.80e-05
0 0.00e+00 100
tells us that all the flops were logged on GPUs.
You do need at least 100K equations per GPU to see speedup, so don't worry
about small problems.
On Tue, Mar 5, 2024 at 12:52 PM Vanella, Marcos (Fed) via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi all, I compiled the latest PETSc source in Frontier using gcc+kokkos
> and hip options: ./configure COPTFLAGS="-O3" CXXOPTFLAGS="-O3"
> FOPTFLAGS="-O3" FCOPTFLAGS="-O3" HIPOPTFLAGS="-O3" --with-debugging=0
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> and hip options:
> ./configure COPTFLAGS="-O3" CXXOPTFLAGS="-O3" FOPTFLAGS="-O3"
> FCOPTFLAGS="-O3" HIPOPTFLAGS="-O3" --with-debugging=0 --with-cc=cc
> --with-cxx=CC --with-fc=ftn --with-hip --with-hipc=hipcc
> --LIBS="-L${MPICH_DIR}/lib -lmpi ${PE_MPICH_GTL_DIR_amd_gfx90a}
> ${PE_MPICH_GTL_LIBS_amd_gfx90a}" --download-kokkos
> --download-kokkos-kernels --download-suitesparse --download-hypre
> --download-cmake
> and have started testing our code solving a Poisson linear system with CG
> + HYPRE preconditioner. Timings look rather high compared to compilations
> done on other machines that have NVIDIA cards. They are also not changing
> when using more than one GPU for the simple test I doing.
> Does anyone happen to know if HYPRE has an hip GPU implementation for
> Boomer AMG and is it compiled when configuring PETSc?
> Thanks!
> Marcos
> PS: This is what I see on the log file (-log_view) when running the case
> with 2 GPUs in the node:
> ------------------------------------------------------------------ PETSc
> Performance Summary:
> /ccs/home/vanellam/Firemodels_fork/fds/Build/mpich_gnu_frontier/fds_mpich_gnu_frontier
> on a arch-linux-frontier-opt-gcc named frontier04119 with 4 processors, by
> vanellam Tue Mar 5 12:42:29 2024
> Using Petsc Development GIT revision: v3.20.5-713-gabdf6bc0fcf GIT Date:
> 2024-03-05 01:04:54 +0000
> Max Max/Min Avg Total
> Time (sec): 8.368e+02 1.000 8.368e+02
> Objects: 0.000e+00 0.000 0.000e+00
> Flops: 2.546e+11 0.000 1.270e+11 5.079e+11
> Flops/sec: 3.043e+08 0.000 1.518e+08 6.070e+08
> MPI Msg Count: 1.950e+04 0.000 9.748e+03 3.899e+04
> MPI Msg Len (bytes): 1.560e+09 0.000 7.999e+04 3.119e+09
> MPI Reductions: 6.331e+04 2877.545
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> e.g., VecAXPY() for real vectors of length N
> --> 2N flops
> and VecAXPY() for complex vectors of length N
> --> 8N flops
> Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages
> --- -- Message Lengths -- -- Reductions --
> Avg %Total Avg %Total Count
> %Total Avg %Total Count %Total
> 0: Main Stage: 8.3676e+02 100.0% 5.0792e+11 100.0% 3.899e+04
> 100.0% 7.999e+04 100.0% 3.164e+04 50.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
> Count: number of times phase was executed
> Time and Flop: Max - maximum over all processors
> Ratio - ratio of maximum to minimum over all processors
> Mess: number of messages sent
> AvgLen: average message length (bytes)
> Reduct: number of global reductions
> Global: entire computation
> Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
> %T - percent time in this phase %F - percent flop in this
> phase
> %M - percent messages in this phase %L - percent message lengths
> in this phase
> %R - percent reductions in this phase
> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over
> all processors)
> GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU
> time over all processors)
> CpuToGpu Count: total number of CPU to GPU copies per processor
> CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per
> processor)
> GpuToCpu Count: total number of GPU to CPU copies per processor
> GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per
> processor)
> GPU %F: percent flops on GPU in this event
> Event Count Time (sec) Flop
> --- Global --- --- Stage ---- Total GPU - CpuToGpu - -
> GpuToCpu - GPU
> Max Ratio Max Ratio Max Ratio Mess AvgLen
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s Mflop/s Count Size
> Count Size %F
> --- Event Stage 0: Main Stage
> BuildTwoSided 1201 0.0 nan nan 0.00e+00 0.0 2.0e+00 4.0e+00
> 6.0e+02 0 0 0 0 1 0 0 0 0 2 -nan -nan 0 0.00e+00 0
> 0.00e+00 0
> BuildTwoSidedF 1200 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> MatMult 19494 0.0 nan nan 1.35e+11 0.0 3.9e+04 8.0e+04
> 0.0e+00 7 53 100 100 0 7 53 100 100 0 -nan -nan 0 1.80e-05
> 0 0.00e+00 100
> MatConvert 3 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.5e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0
> 0.00e+00 0
> MatAssemblyBegin 2 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0
> 0.00e+00 0
> MatAssemblyEnd 2 0.0 nan nan 0.00e+00 0.0 4.0e+00 2.0e+04
> 3.5e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0
> 0.00e+00 0
> VecTDot 41382 0.0 nan nan 4.14e+10 0.0 0.0e+00 0.0e+00
> 2.1e+04 0 16 0 0 33 0 16 0 0 65 -nan -nan 0 0.00e+00 0
> 0.00e+00 100
> VecNorm 20691 0.0 nan nan 2.07e+10 0.0 0.0e+00 0.0e+00
> 1.0e+04 0 8 0 0 16 0 8 0 0 33 -nan -nan 0 0.00e+00 0
> 0.00e+00 100
> VecCopy 2394 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0
> 0.00e+00 0
> VecSet 21888 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> VecAXPY 38988 0.0 nan nan 3.90e+10 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 15 0 0 0 0 15 0 0 0 -nan -nan 0 0.00e+00 0
> 0.00e+00 100
> VecAYPX 18297 0.0 nan nan 1.83e+10 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 7 0 0 0 0 7 0 0 0 -nan -nan 0 0.00e+00 0
> 0.00e+00 100
> VecAssemblyBegin 1197 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> VecAssemblyEnd 1197 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> VecScatterBegin 19494 0.0 nan nan 0.00e+00 0.0 3.9e+04 8.0e+04
> 0.0e+00 0 0 100 100 0 0 0 100 100 0 -nan -nan 0 1.80e-05
> 0 0.00e+00 0
> VecScatterEnd 19494 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> SFSetGraph 1 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> SFSetUp 1 0.0 nan nan 0.00e+00 0.0 4.0e+00 2.0e+04
> 5.0e-01 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0
> 0.00e+00 0
> SFPack 19494 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 1.80e-05 0
> 0.00e+00 0
> SFUnpack 19494 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> KSPSetUp 1 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> 0 0.00e+00 100
> PCSetUp 1 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> PCApply 20691 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 5 0 0 0 0 5 0 0 0 0 -nan -nan 0 0.00e+00 0
> 0.00e+00 0
> Object Type Creations Destructions. Reports information only
> for process 0.
> Matrix 7 3
> Vector 7 1
> Index Set 2 2
> Star Forest Graph 1 0
> Krylov Solver 1 0
> Preconditioner 1 0
> Average time to get PetscTime(): 3.01e-08
> Average time for MPI_Barrier(): 3.8054e-06
> Average time for zero size MPI_Send(): 7.101e-06
> #PETSc Option Table entries:
> -log_view # (source: command line)
> -mat_type mpiaijkokkos # (source: command line)
> -vec_type kokkos # (source: command line)
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure options: COPTFLAGS=-O3 CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
> FCOPTFLAGS=-O3 HIPOPTFLAGS=-O3 --with-debugging=0 --with-cc=cc
> --LIBS="-L/opt/cray/pe/mpich/8.1.23/ofi/gnu/9.1/lib -lmpi
> -L/opt/cray/pe/mpich/8.1.23/gtl/lib -lmpi_gtl_hsa" --download-kokkos
> --download-cmake
> Libraries compiled on 2024-03-05 17:04:36 on login08
> Machine characteristics:
> Linux-5.14.21-150400.24.46_12.0.83-cray_shasta_c-x86_64-with-glibc2.3.4
> Using PETSc directory: /autofs/nccs-svm1_home1/vanellam/Software/petsc
> Using PETSc arch: arch-linux-frontier-opt-gcc
> Using C compiler: cc -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas
> -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector
> -fvisibility=hidden -O3
> Using Fortran compiler: ftn -fPIC -Wall -ffree-line-length-none
> -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -O3
> Using include paths:
> -I/autofs/nccs-svm1_home1/vanellam/Software/petsc/include
> -I/autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc/include
> -I/autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc/include/suitesparse
> -I/opt/rocm-5.4.0/include
> Using C linker: cc
> Using Fortran linker: ftn
> Using libraries:
> -Wl,-rpath,/autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc/lib
> -L/autofs/nccs-svm1_home1/vanellam/Software/petsc/arch-linux-frontier-opt-gcc/lib
> -lpetsc
> -Wl,-rpath,/opt/rocm-5.4.0/lib -L/opt/rocm-5.4.0/lib
> -Wl,-rpath,/opt/cray/pe/mpich/8.1.23/ofi/gnu/9.1/lib
> -Wl,-rpath,/opt/cray/pe/mpich/8.1.23/gtl/lib
> -L/opt/cray/pe/mpich/8.1.23/gtl/lib -Wl,-rpath,/opt/cray/pe/libsci/
> 22.12.1.1/GNU/9.1/x86_64/lib -L/opt/cray/pe/libsci/
> -Wl,-rpath,/sw/frontier/spack-envs/base/opt/cray-sles15-zen3/gcc-12.2.0/darshan-runtime-3.4.0-ftq5gccg3qjtyh5xeo2bz4wqkjayjhw3/lib
> -L/sw/frontier/spack-envs/base/opt/cray-sles15-zen3/gcc-12.2.0/darshan-runtime-3.4.0-ftq5gccg3qjtyh5xeo2bz4wqkjayjhw3/lib
> -Wl,-rpath,/opt/cray/pe/dsmml/0.2.2/dsmml/lib
> -L/opt/cray/pe/dsmml/0.2.2/dsmml/lib -Wl,-rpath,/opt/cray/pe/pmi/6.1.8/lib
> -L/opt/cray/pe/pmi/6.1.8/lib
> -Wl,-rpath,/opt/cray/xpmem/2.6.2-2.5_2.22__gd067c3f.shasta/lib64
> -L/opt/cray/xpmem/2.6.2-2.5_2.22__gd067c3f.shasta/lib64
> -Wl,-rpath,/opt/cray/pe/gcc/12.2.0/snos/lib/gcc/x86_64-suse-linux/12.2.0
> -L/opt/cray/pe/gcc/12.2.0/snos/lib/gcc/x86_64-suse-linux/12.2.0
> -Wl,-rpath,/opt/cray/pe/gcc/12.2.0/snos/lib64
> -L/opt/cray/pe/gcc/12.2.0/snos/lib64 -Wl,-rpath,/opt/rocm-5.4.0/llvm/lib
> -L/opt/rocm-5.4.0/llvm/lib -Wl,-rpath,/opt/cray/pe/gcc/12.2.0/snos/lib
> -L/opt/cray/pe/gcc/12.2.0/snos/lib -lHYPRE -lspqr -lumfpack -lklu -lcholmod
> -lamd -lkokkoskernels -lkokkoscontainers -lkokkoscore -lkokkossimd
> -lhipsparse -lhipblas -lhipsolver -lrocsparse -lrocsolver -lrocblas
> -lrocrand -lamdhip64 -lmpi -lmpi_gtl_hsa -ldarshan -lz -ldl -lxpmem
> -lgfortran -lm -lmpifort_gnu_91 -lmpi_gnu_91 -lsci_gnu_82_mpi -lsci_gnu_82
> -ldsmml -lpmi -lpmi2 -lgfortran -lquadmath -lpthread -lm -lgcc_s -lstdc++
> -lquadmath -lmpi -lmpi_gtl_hsa
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240305/d9d634cf/attachment-0001.html>
