[petsc-users] MUMPS Metis options
Pierre Jolivet
pierre at joliv.et
Tue Mar 5 08:26:57 CST 2024
> On 5 Mar 2024, at 2:20 PM, Michal Habera <michal.habera at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear all,
> MUMPS allows custom configuration of the METIS library which it uses
> for symmetric permutations using "mumps_par%METIS OPTIONS",
> see p. 35 of https://urldefense.us/v3/__https://mumps-solver.org/doc/userguide_5.6.2.pdf__;!!G_uCfscf7eWS!YlgQB0Z4fqIbHPr0NbNaJZivhlC-hjMLgRjRGox9nvwZQ1ptSyRvtQHlzqAJwdQgbUWP0HpQWM-NV5C0TiKNzA$ <https://urldefense.us/v3/__https://mumps-solver.org/doc/userguide_5.6.2.pdf__;!!G_uCfscf7eWS!aqzhWg_iCZLsu1jTz2sWKIpVkAIDvmvt-_4ojHy5ZtC2eWYBRlCU3zlqh72rGtso5KuDhEuf9yFxMNOGRhHoQBLH_kmf$>.
> Is it possible to provide these options to MUMPS via PETSc API? I can
> only find a way to control integer and real control parameters.
It is not possible, but I guess we could add something like MatMumpsSetMetisOptions(Mat A, PetscInt index, PetscInt value), just like MatMumpsSetIcntl().
Pierre
> Kind regards,
> Michal Habera
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240305/07ce49ca/attachment-0001.html>
