[petsc-users] Trying to develop my own Krylov solver
Julien BRUCHON
bruchon at emse.fr
Fri Jun 28 10:30:53 CDT 2024
Thank you for your answers, it woks well.
Julien
De: "Barry Smith" <bsmith at petsc.dev>
À: "Matthew Knepley" <knepley at gmail.com>
Cc: "Julien BRUCHON" <bruchon at emse.fr>, "petsc-users" <petsc-users at mcs.anl.gov>
Envoyé: Mardi 25 Juin 2024 19:14:52
Objet: Re: [petsc-users] Trying to develop my own Krylov solver
Make sure that you are using the latest PETSc if at all possible
Also copy over a makefile from the cg directory (you do not need to edit any makefiles)
You also need to add it to KSPRegisterAll()
You will need to do make clean before running make all to compiler your new code.
Barry
On Jun 25, 2024, at 1:11 PM, Matthew Knepley <knepley at gmail.com> wrote:
This Message Is From an External Sender
This message came from outside your organization.
On Tue, Jun 25, 2024 at 12:05 PM Julien BRUCHON via petsc-users < [ mailto:petsc-users at mcs.anl.gov | petsc-users at mcs.anl.gov ] > wrote:
BQ_BEGIN
Based on 'cg.c', I'm trying to develop my own Krylov solver (a projected conjugate gradient). I want to integrate this into my C++ code, where I already have an interface for PETSC which works well. However, I have the following questions :
- Where am I sensed to put my 'cg_projected.c' and 'pcgimpl.h' files? Should they go in a directory petsc/src/ksp/ksp/impls/pcg/? If so, how do I compile that? Is it simply by adding this directory to the Makefile in petsc/src/ksp/ksp/impls/?
Yes.
Matt
BQ_BEGIN
- I have also tried the basic approach of putting these two files in directories of my own C++ code and compiling. However, I have this error at the link edition:
[100%] Linking CXX shared library [ https://urldefense.us/v3/__http://libcoeur.so/__;!!G_uCfscf7eWS!eJ5wDIF503lmkSoc9ckRL6Hf7-ac1BL99ksSTDaYQ0VLXGrgZJzkMOQhSpDEOSQpkux5LxL9PqMV1b4f3-nU3A$ | libcoeur.so ]
/usr/bin/ld: src/solvers/libsolvers.a(cg_projected.c.o): warning: relocation against `petscstack' in read-only section `.text'
/usr/bin/ld: src/solvers/libsolvers.a(cg_projected.c.o): relocation R_X86_64_PC32 against symbol `petscstack' can not be used when making a shared object; recompilé avec -fPIC
/usr/bin/ld : échec de l'édition de liens finale : bad value
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/coeur.dir/build.make:121 : [ https://urldefense.us/v3/__http://libcoeur.so/__;!!G_uCfscf7eWS!eJ5wDIF503lmkSoc9ckRL6Hf7-ac1BL99ksSTDaYQ0VLXGrgZJzkMOQhSpDEOSQpkux5LxL9PqMV1b4f3-nU3A$ | libcoeur.so ] ] Erreur 1
make[1]: *** [CMakeFiles/Makefile2:286 : CMakeFiles/coeur.dir/all] Erreur 2
make: *** [Makefile:91 : all] Erreur 2
Could you please tell me what is the right way to proceed?
Thank you,
Julien
Julien Bruchon
Professeur IMT - Responsable du département MPE
LGF - UMR CNRS 5307 - [ https://urldefense.us/v3/__https://www.mines-stetienne.fr/lgf/__;!!G_uCfscf7eWS!dQgv-IRWC7OgdDf1X9Oew4nHSgleq2ty0AszuRPj70bBiFeCcT4RibQVAvv6FFeD081W1yY8IczRHAHopA0crg$ | https://urldefense.us/v3/__https://www.mines-stetienne.fr/lgf/__;!!G_uCfscf7eWS!eJ5wDIF503lmkSoc9ckRL6Hf7-ac1BL99ksSTDaYQ0VLXGrgZJzkMOQhSpDEOSQpkux5LxL9PqMV1b7q0tC0Xw$ ]
Mines Saint-Étienne, une école de l'Institut Mines-Télécom
[ https://urldefense.us/v3/__https://gitlab.emse.fr/bruchon/Coeur/-/wikis/home__;!!G_uCfscf7eWS!dQgv-IRWC7OgdDf1X9Oew4nHSgleq2ty0AszuRPj70bBiFeCcT4RibQVAvv6FFeD081W1yY8IczRHAG6pz3FrQ$ | Librairie Éléments Finis Coeur ]
0477420072
BQ_END
-- Norbert Wiener
[ https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZSMOgmxB-aRx34PmTC3s7ZkDC-zT09xxpmLjhj_vx8oVkTvDSORUOeoTe8ZdEFCHVCUxSrs3eOz346S6E1L_$ | https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eJ5wDIF503lmkSoc9ckRL6Hf7-ac1BL99ksSTDaYQ0VLXGrgZJzkMOQhSpDEOSQpkux5LxL9PqMV1b50sR16ZQ$ ]
BQ_END
Julien Bruchon
LGF - UMR CNRS 5307 - [ https://urldefense.us/v3/__https://www.mines-stetienne.fr/lgf/__;!!G_uCfscf7eWS!eJ5wDIF503lmkSoc9ckRL6Hf7-ac1BL99ksSTDaYQ0VLXGrgZJzkMOQhSpDEOSQpkux5LxL9PqMV1b7q0tC0Xw$ | https://urldefense.us/v3/__https://www.mines-stetienne.fr/lgf/__;!!G_uCfscf7eWS!eJ5wDIF503lmkSoc9ckRL6Hf7-ac1BL99ksSTDaYQ0VLXGrgZJzkMOQhSpDEOSQpkux5LxL9PqMV1b7q0tC0Xw$ ]
[ https://urldefense.us/v3/__https://gitlab.emse.fr/bruchon/Coeur/-/wikis/home__;!!G_uCfscf7eWS!eJ5wDIF503lmkSoc9ckRL6Hf7-ac1BL99ksSTDaYQ0VLXGrgZJzkMOQhSpDEOSQpkux5LxL9PqMV1b4DLBtKFA$ | Librairie Éléments Finis Coeur ]
0477420072
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240628/20a0af4c/attachment-0001.html>
