[petsc-users] Problem about compiling PETSc-3.21.2 under Cygwin
Gang Li ligang0309 at gmail.com
Thu Jun 27 21:26:05 CDT 2024
Hi Satish,
Thanks for your help.
The same error happens after I used tar (the attached file).
Sincerely,
Gang
---- Replied Message ----
FromSatish Balay<balay.anl at fastmail.org>Date6/26/2024 05:06ToGang Li<ligang0309 at gmail.com>Ccpetsc-users<petsc-users at mcs.anl.gov>SubjectRe: [petsc-users] Problem about compiling PETSc-3.21.2 under Cygwin
On Tue, 25 Jun 2024, Gang Li wrote:
The same error when I restart this build using a fresh tarball.
Did you use winzip or similar windows utility to 'untar' the tarball?
Can you try from cygwin shell:
tar -czf petsc-3.21.2.tar.gz
And see if the build works here?
Alternatively use cygwin git and see if that makes a difference
git clone -b release https://urldefense.us/v3/__https://gitlab.com/petsc/petsc.git__;!!G_uCfscf7eWS!cbu0xpk1rHAOkguuYVHMSeA6o7-j5fVq5G2wTZDREAeyAYIovFxqPWeacYu299Sx8OW69AYzSza10erOU2OH4zoI$
Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240628/d5bd576d/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240628/d5bd576d/attachment-0001.jpg>
